VWVortex.com - 2011 Mercedes-Benz C-Class Oil Change DIY (24 Pictures)
    The Car Lounge
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 79
    Thread: 2011 Mercedes-Benz C-Class Oil Change DIY (24 Pictures)
      May 24th, 2011
      Alberta, Canada
      2004 Phaeton 4.2 V8, 2015 Touareg 3.6 FSI VR6, Pre: 2011 Golf 2.5 L5, 2011 Mercedes-Benz C250 V6 RWD
      11-27-2011 02:20 AM #1
      This is a traditional way(using drain plug instead of a suction pump)of changing oil for a 2011 Mercedes-Benz C250.
      You do need a special oil filter wrench (14 Points, 74mm),as the new german cars are using a cartridge type oil filter. I got mine from ebay, made of cast aluminium, works like a charm.
      Other hand tools you will need are:
      Ramp (Or jack and jack stands if you prefer)
      8mm socket for the under pan screws
      13mm socket for the drain plug
      Torque Wrench
      Gloves (in case of hot oil burn)
      A used oil catching pan
      Ratchet
      Materials you will need:
      8 Litre of Mobil 1 0W-40 European Car Formula
      Mann HU 718/5X oil filter with new o-rings
      New copper drain plug washer
      1. First drive the car onto the ramp, let the engine run for a few minutes as the hot oil is easier to drain
      2. Pop the hood and take out the front half of the plastic engine cover
      3. Remove two under pans by removing 12 screws with 8mm socket
      4. The un-covered oil pan
      5. Open the oil filler cap, ready to drain the oil
      6. Use the ratchet and 13mm socket remove the drain plug and drain the oil to the catching pan, do remember to wear your gloves because the oil could be very hot
      7. While the old oil is draining, time to remove the old oil filter, attach the special oil filter wrench to the ratchet and remove the oil filter housing
      8. Take out the old filter and o-ring, then install the new filter and three new o-rings
      9. Screw back the oil filter housing with the new filter, and use torque wrench to torque it to 25NM.
      10. The used engine oil with 7481 KMs on it
      11.Screw back the drain plug with the new copper washer
      12.Fill the engine with new oil, I poured in 7 litres first, then start the engine, drive down the ramp, let it run for a few minutes, then shut it down and let it sit for a while and then add the last litre, check with dip stick to make sure not to overfill the engine.
      And to reset the Service Indicator, do the following:
      1.Doors and windows closed.Turn your ignition to first position (only the airbag light lit
      up),press OK to clear service reminder message if it comes up.
      2.Press and hold the accept call button on the right side of the steering wheel,
      immediately press and hold OK button on left of steering wheel, hold both for about 5
      seconds until the hidden service menu comes up.
      3.Arrow down to ASSYST PLUS and press OK
      Arrow down to FULL SERVICE and press OK
      Arrow down to CONFIRM FULL SERVICE and press OK
      Arrow down to YES and press OK
      Thanks for reading!
      Tomas
    2. Member mellbergVWfan's Avatar
      Jan 31st, 2008
      Bay Area, CA
      81 Scirocco S, 99 Cobra
      11-27-2011 02:27 AM #2
      Dang I wish the filter was that easy to replace in every car. You have to be a contortionist to reach it in my Camry.
      My 16v Swap thread
    3. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      11-27-2011 02:30 AM #3
      Great write up!
      Standard mercedes v6 oil change.
      How do you like yours so far?
    4. 11-27-2011 02:47 AM #4
      8 quarts for a V6 3.5? ****ing nuts. MY MKV R32 is slightly smaller 3.2 VR6 only takes 5.8 quarts. I thought that was alot already.
    5. Member mx5er's Avatar
      Apr 28th, 2001
      NY
      11-27-2011 02:47 AM #5
      Where's the dip stick? Or is it like recent BMWs
    6. 11-27-2011 02:59 AM #6
      Quote Originally Posted by mach gti View Post
      he said it was a c250... so its a 2.5 v6
      very good thread OP...
      Do you think the same will go for my 2011 glk 350?
    7. 11-27-2011 03:03 AM #7
      Quote Originally Posted by six_banger View Post
      Ohs but damn thats even worse for a 2.5 liter.
    8. Member Jan PL S6's Avatar
      Apr 22nd, 2010
      NJ
      1995 urS6, 2005 A8L
      11-27-2011 03:22 AM #8
      WOW the germans put an oil filter in an easy to reach/convenient spot? Now thats unheard of
    9. Senior Member patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      EJ251, EJ255, EZ30D(R)
      11-27-2011 03:29 AM #9
      The Audi 2.8 in my Passat usually takes a bit more than 6.5. The Benz seems like it has a bit of extra plumbing in order to get that filter in such an easy location. Most of the filter relocation kits I am familiar with add 1-2 qts to capacity.
      I feel like this has all happened before.
      Support Your Local Homebrewery
    10. Member 92skirmishgti's Avatar
      Sep 5th, 2005
      Sunny Los Angeles
      11-27-2011 03:30 AM #10
      You're going to need 9qt's of oil....
    11. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      11-27-2011 03:36 AM #11
      Quote Originally Posted by Jan PL S6 View Post
      It's been like that for the inline 6 bmws for a couple of decades now.
    12. Member someguy123's Avatar
      Sep 30th, 2005
      The Financial Lounge
      Handed in my car enthusiast 'card'.
      11-27-2011 03:54 AM #12
      I feel bad for those 8th and 9th(?) generation Civic DIYers. You have to remove the right front wheel to get to the oil filter.
    13. Member Süsser Tod's Avatar
      Aug 3rd, 2001
      Mexico City, Mexico
      KLE650, XJR1300
      11-27-2011 04:09 AM #13
      And I guess removing all the tupperware over and under the engine, without breaking it, is a walk in the park, right?
      Sure, the filter is easy to reach, but I think that's as far as they went to help the DIY people.
    14. Member dfischer1's Avatar
      May 20th, 2004
      Washington DC
      1966 Porsche 911, 2013 Volvo XC60 RD
      11-27-2011 04:10 AM #14
      That's nothing. My 2.0 liter Porsche needs 11 quarts of oil.
    15. Member alex_bgnet's Avatar
      Jan 6th, 2004
      DC
      '13 Golf TDI
      11-27-2011 05:20 AM #15
      I service my father's Crossfire, I use 9 quarts of the same oil. Oil filter is at the same easy place.
    16. Member
      Mar 5th, 2004
      WI
      S80, CRV
      11-27-2011 05:32 AM #16
      Doing an oil change on my 1983 300d was the easiest oil change I have ever done. Everything was easily accessible. I used a suction pump for the oil, meaning the entire job could be done on the top side of the engine.
      to Mercedes for making some things easy
    17. Geriatric Member J-Tim's Avatar
      May 26th, 2000
      Kangaroo-infested Austria
      German/American/Italian
      11-27-2011 05:47 AM #17
      Looks to be exact same procedure as on my e46. Perhaps the easiest oil change I've ever done.
      In fact, I've used the same brand and spec oil too, which is an BMW LL-01.
      And now for something completley different...A Scotsman on a horse.
    18. Member LiGuangming1981's Avatar
      Jun 22nd, 2016
      Shanghai / 中国上海
      A few two-wheelers
      11-27-2011 06:11 AM #18
      Looks very similar to changing the oil in my old Mazda 6 2.3L.
      Formerly "The Chemist"
    19. Member Aguilar's Avatar
      Jan 28th, 2006
      VA
      2.7tt F150, Mk7 GTI
      11-27-2011 06:24 AM #19
      Very similar to the VW 2.0t TSI. I use the same oil, except I only need 4.8 qt.
    20. Member MCTB's Avatar
      Dec 30th, 2005
      The Northern of Virginia
      '12 Focus SE, '15 Outback Limited
      11-27-2011 06:42 AM #20
      Quote Originally Posted by 92skirmishgti View Post
      9 quarts! Holy crap.
      Looking for a car event on the East Coast? Check here
      I have an idea, we will try it my way first...and then we will finish.
      Pictures Ive taken of stuff
    21. 11-27-2011 06:52 AM #21
      Quote Originally Posted by dfischer1 View Post
      came here to post porsche oil amount requirements...
    22. Geriatric Member J-Tim's Avatar
      May 26th, 2000
      11-27-2011 07:37 AM #22
      Quote Originally Posted by morecarsthanbrains View Post
      I thought 6.5 quarts for my BMW was a lot.
    23. Member bhtooefr's Avatar
      Dec 22nd, 2005
      Newark, OH
      16 Prius, 00 Miata, 11 TerraTrike Path 8
      11-27-2011 09:23 AM #23
      Needing lots of oil isn't a bad thing.
      Lots of oil means that the oil will absorb thermal shocks (so it's less likely to sludge - see the B5 Passat and B5/B6 Audi A4 1.8T for why you want lots of oil), and the oil lasts longer between changes.
      (That's also part of why the aircooled 911s have so much oil - the oil is performing more of a cooling function in those cars, so more is needed to keep the oil from cooking.)
    24. Member
      May 27th, 2008
      Malvern, PA
      2015 GMC Sierra, 1998 TJ 5.3L/465/Atlas, 1996 F250
      11-27-2011 09:47 AM #24
      OP, your filter kit did not come with a new O ring for the oil filter cap?
      Also, MB should look at the underside of their competitor BMW, they might get a good idea for an access door for the oil drain plug, instead of removing all that plastic...
    25. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      11-27-2011 10:06 AM #25
      That old oil and filter look really really dirty for having only about 4700 miles on them.
      2008 VW Jetta SE 2.5
      1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
