Originally Posted by
najel
I think that the S2 sensor is the one behind the cat. Should be easy enough to replace, find where it is plugged in (you probably have to remove a cover to get to that) unplug, then unscrew preferably using O2 sensor wrench. If you have a spark plug thread chase, use that to clear the threads, will make it easier to install the new sensor. Now screw new sensor in carefully after applying antiseize if it doesn't have any (if OEM it should) plug in, replace cover, clear codes, run guided readiness or just drive and keep an eye on CEL.
