Results 1 to 14 of 14
Thread: FS: '84 Scirocco 8v
  1. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    11-30-2011 01:49 PM #1
    It's time for to get rid of this project. It has been in my possession since 2000, it was my daily driver from 2000 until 2009.
    The Bad: It would still fire up when it was parked in 2009. This was after the front end collision, so even after the front end damage the car started and drove. Since it has been sitting for the past 2 years the engine seems to have seized up. The cam still turns in the head, but the block seems to be frozen. The engine is original and has about 309000 miles on it. There might be a problem with the fuel pump relay. We hard wired it to a switch and the fuel pump works fine but didn't spend a lot of time diagnosing the problem.
    The car suffered some front end damage (as can be seen in pictures) like I said above the car still ran and drove after the accident, it just didn't look quite as pretty. The body also has some rust areas (again see the pictures). The passenger door won't open, I can't figure out what is wrong and I haven't wanted to destroy the door panel to get to the inside of the door and figure out what is going on.
    The good: The car is complete. I have all the parts (even though some might not be pictured i.e. the front bumper, drivers' seat and rear seat). The starter still attempts to turn the car over when the key is turned. The car has eurosport front and rear strut bars, and it has the eurosport lower tie bar that goes between the control arms essentially. I replaced the suspension with Bilstein shocks and Neuspeed springs (I think the race ones) at all 4 corners. I also did the 16v brake swap so the car has 10.1" discs up front and the smaller discs (7.9") in the rear, stainless lines were also installed at the same time. Sway bars front and rear were replaced with Autotech hollow 25mm front, 28mm rear, respectively. Battery was relocated to the rear passenger seat area. It also has the front cross member reinforcement piece that was developed and produced by a member on here on the board. I can try to look up that info if you want it. There are other little things I think I am forgetting but feel free to ask any questions.
    I think this could be a nice project for someone or make a great 24 hours of Lemons car (this is the route I would take but already have a team with 2 Lemons cars in the works). I would like to get $500 for the car, and would be willing to send the 2.0l ABA block that I bought thinking I would do the swap for a bit of extra cash since the 1.8l is seized.
    Please let me know if you have any additional questions or need pictures of anything else. And I'm sorry but I don't have time to remove and sell parts at this time, work and life are keeping me too busy to even work on the car
    Oct 8th, 2005
    MN
    1986 scirocco 16v
    11-30-2011 02:45 PM #2
    Good deal car looks pretty solid would make someone a nice project wish I had the room for another one.
  3. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    12-22-2011 03:34 PM #3
    Bump.
  4. Junior Member
    Nov 22nd, 2011
    Pottsville, Pa
    84 rocco shell. 85 rocco 1.8l 8v smashed. 86 rocco 1.8l 16v. 86 cabriolet 1.8 8v. 87 rocco 1.8 8v
    12-27-2011 05:29 PM #4
    where are you located?
  5. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    01-05-2012 01:28 AM #5
    Car is located just outside Chicago, in Palatine, IL.
  6. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    02-21-2012 04:32 PM #6
    No reasonable offer refused, I just need this thing gone!
  7. 02-23-2012 11:44 PM #7
    I may be interested....i would need to figure out a way to get it to rockford tho....Does it roll well or easily? emergency brake works? Or maybe a car dolley could work? Is the battery still good? (for hazards to work) And how do you know the crank doesnt turn if it still cranks over with starter? Is the timing belt disconnected if you have moved the cams? Sorry for all the questions at once. And are you close to 90? THanks
    Woot! 600 post only took me like 3 years or so
    Oct 13th, 2004
    Frankfort, IL
    1980 Rocco S Race Car, 1982 Rabbit Race Car, 1980 Caddy Outlaw Race Truck, 1983 Jetta Coupe, more
    03-01-2012 11:25 AM #8
    PM Sent
    Check out my Ebay auctions for Earl's Performance Braided Hose ends - NOS pieces for 50-60% the price of new. My Ebay Auctions
  9. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    03-05-2012 11:11 PM #9
    Quote Originally Posted by GKSRGTI View Post
    Sent PM.
  10. Member
    Oct 13th, 2004
    Frankfort, IL
    03-08-2012 05:08 PM #10
    sent PM.
    call me or send me your number.
  11. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    08-30-2012 08:42 PM #11
    Up to the top! Car is still here
  12. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    09-23-2012 11:46 PM #12
    Car is going to the junkyard in a week, any offer entertained.
  13. Member
    Oct 13th, 2004
    Frankfort, IL
    09-28-2012 09:58 AM #13
    offer sent via email.
  14. Member RoccinStrybs84's Avatar
    Jan 2nd, 2002
    Chicago, IL
    10-09-2012 10:14 PM #14
    Sold
