VWVortex.com - Corrado SLC Parts for sale...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 47
    Thread: Corrado SLC Parts for sale...
    1. Member greenraVR6's Avatar
      Mar 10th, 2008
      B'ham WA
      '80 Caddy, '88 Vanagon GL, '97 Jetta GLX, '07 Passat wagon, '11 Suburban z71
      11-30-2011 04:23 PM #1
      Parting out 2 '93 corrado slc cars...360 820-3060 for a text or jhelm29@yahoo.com are the easiest ways to reach me. Please NO PHONE CALLS.
      Both cars are green (LC6U) and have tan leather interior. One had a obd2 coilpack vr and the other is a dizzy obd1...
      MECHANICAL PARTS
      VR6 engine "cover" $20
      clutch master cylinder $30
      clutch master cylinder with lines $40
      K frame with control arms and sway bar $140
      cable shifter assembly $75
      pass side axle $40, driver side SOLD
      stock vr flywheel $50
      complete rear brakes assemblies $125 - rotors (new), calipers, pads, hubs, bearings, stub axles
      rear trailing arm $40.00, or $140 with complete rear brakes
      front crossmember - SOLD
      wiper assembly/motor - SOLD
      power steering rack - SOLD
      complete front brake assemblies - SOLD
      manual pedal assembly - SOLD
      5speed o2a tranny, code is CDW - SOLD
      obd2 maf sensor - SOLD
      abs pump - SOLD
      a/c lines - SOLD
      oem catalytic converter - SOLD
      stock cat back exhaust system - SOLD
      Neuspeed stainless steel cat back exhaust system - SOLD
      Engine stuff:
      200K longblock with OBD1 dizzy head $175, all accessories for sale separately
      obd1 upper intake manifold $50
      obd1 lower intake mani $25
      obd1 maf sensor $50
      distributor $150
      plug wires $40
      distributor engine ignition coil $30
      p/s pump with pulley $25
      alternator $40.00
      exhaust manifolds $30/pair
      oil filter housing $25.00
      rear motor mount bracket $20
      front motor mount bracket $40
      combi valve $20
      secondary air pump $40
      brand new non AC belt, had it on the car for 200 miles $15
      water pump with pulley $20.00
      130K longblock with OBD2 head - SOLD
      ISV - SOLD
      obd1 throttle body - SOLD
      tranny mount brace - SOLD
      obd1 dizzy ECU - SOLD
      obd2 engine harness - SOLD
      obd2 vr6 ECU - SOLD
      v belt tensioner - SOLD
      coilpack - SOLD
      secondary water pump - SOLD
      EXTERIOR PARTS
      upper rad support with small dent $100
      driver side door $100
      rear hatch w/glass, has 2 small rust spots $50.00
      rear hatch w/glass in perfect condition $100
      hatch spoiler $30.00, 2 to choose from
      door handle stiker with pin $20 shipped
      rear bumper $100
      oem Hella amber side marker lights $25
      door latches $40 each
      upper rad support in perfect condition - SOLD
      passenger side door - SOLD
      hood with dent on front - SOLD
      15" Speedline wheels - SOLD
      front bumper - SOLD
      lower rad support - SOLD
      driver side fender - SOLD
      grill - SOLD
      hood in perfect condition - SOLD
      oem Hella headlights - SOLD
      oem Hella fog lights - SOLD
      oem Hella tail lights - SOLD
      oem Hella turn signals - SOLD
      driver door handle -SOLD
      pass door handle - SOLD
      driver side mirror - SOLD
      pass side mirror - SOLD
      INTERIOR PARTS
      driver door pull/mirror control $30
      sunroof assembly $65
      rear spoiler motor $100
      auto seatbelt relays $20 each
      rear seatbelts $30 each
      ABS control module $65
      sunvisors $15 each
      sunroof motor $50.00
      automatic front seatbelt - PASS side only $60
      tan leather rear seats, good shape $65
      tan leather door/rear panels $100.00 for the set, the leather is coming loose in areas on the edges
      glove box $40.00
      dash switches $20 each defrost, spoiler, headlights, fog lights, seat heater SOLD
      hvac control cover plate $15
      rear spoiler control module $40
      alarm/door lock module $30.00
      cruise control module $30
      black dashboard $65
      lots of wiring, pulled out and labled by the general circuit - front end lighting, rear lighting, auto seatbelts, power sunroof, ABS, dash, etc...make an offer on the one you need
      dash vents - SOLD
      fuse panel with all fuses and relays - SOLD
      ash tray - SOLD
      pass door pull - SOLD
      oem steering wheel - SOLD
      inner door handle surround trim - SOLD
      voltmeter/oil pressure gauge - SOLD
      center dash bezel piece - SOLD
      hvac controls - SOLD
      black dome light assembly with sunroof control - SOLD
      windshield wiper harness - SOLD
      gauge cluster - SOLD
      rear window decklid - SOLD
      shift boot/plastic - SOLD
      power window control module - SOLD
      tan leather front seats - SOLD
      power window switches - SOLD
    2. Awaiting Email Confirmation jcorm's Avatar
      Sep 28th, 2009
      Vancouver WA
      98 Jetta GLX, 93 Corrado SLC
      11-30-2011 04:40 PM #2
      I need the foglights, clamshell, and the rear hatch.
      If you decide to part it out let me know how much for them
    3. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      2000 VR6 Jetta, 1990 BMW 525i
      11-30-2011 06:11 PM #3
      Pics? I am interested in a few interior parts, front bumper, door handles, window module. Let me know when you are going to start parting it out.
    4. 12-01-2011 11:35 AM #4
      How much do you want for a complete vr swap?
      Quote Originally Posted by mrnicejetta View Post
      you lie very poorly, you're just a S.O.B., you're looking for internet fame, or some combination of the aforementioned. I pity you.
      Mar 9th, 2011
      S. Everett
      09 GMC Sierra,E36 M3
      12-01-2011 01:28 PM #5
      Does it have any mods?
    6. Member VW4Life66's Avatar
      Apr 21st, 2006
      Spokane WA
      91 Corrado G60, 91 GTI VR6, 94 Audi URS4
      12-01-2011 03:41 PM #6
      Nooooo don't part it!
      Quote Originally Posted by MikkiJayne View Post
      "double Ds belong on chicks, not 'rados"? The one saving grace of 'raddo' is that it makes me think of boobies
    7. 12-01-2011 10:45 PM #7
      PM me a price for everything I need for a vr swap please
      Also, staying 4 lug so wont need the brakes etc.
    8. Member BlitzkriegB.C.'s Avatar
      Dec 13th, 2009
      Tacoma, WA
      91' Golf-GTI(LB6Z), 91' Golf-GTI Vr6 (L90E)
      12-01-2011 10:45 PM #8
      how much for the entire dash, cluster etc. for a swap
      Broke\_/Bucket
    9. Member BlitzkriegB.C.'s Avatar
      Dec 13th, 2009
      Tacoma, WA
      12-02-2011 04:09 AM #9
      $100.
      Broke\_/Bucket
    10. Member BlitzkriegB.C.'s Avatar
      Dec 13th, 2009
      Tacoma, WA
      12-02-2011 04:24 AM #10
      Well give me a price if your going to shoot down my offer..
      Broke\_/Bucket
    11. Member ltvinny's Avatar
      Jul 5th, 2005
      Where ever the Air Force sends me...
      Imola Yellow 2011 Audi S4; Moonlight Blue 1995 Corrado VR6
      12-02-2011 11:23 PM #11
      If this car is bone stock then it's OBDI not OBDII.
      2011 Imola Yellow Audi S4
      1995 Moonlight Blue VW Corrado
    12. Member greenraVR6's Avatar
      Mar 10th, 2008
      B'ham WA
      12-03-2011 01:47 AM #12
      Quote Originally Posted by ltvinny View Post
      the original distributor engine blew a hole in the block and was replaced with a coilpack obd2 engine. I have the obd1 ecu and coilpack engine harness for sale as well if anyone needs those.
    13. 12-03-2011 11:16 AM #13
      pm sent
    14. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Beaverton, Or
      MK7 Sportwagen TSI, mk5 GTI Dsg, Nissan hardbody 4x4, HPI Baja 5T
      12-03-2011 01:47 PM #14
      why are you parting it out? how much for the whole car?
    15. Senior Member cyclops594's Avatar
      Sep 28th, 2005
      NorCal(Mudville)
      1991 Jetta GLI 16V
      12-05-2011 01:13 PM #15
      Quote Originally Posted by greenraVR6 View Post
      if the car had any resale value and there was actually a person around that would buy it for a decent price, then I wouldn't part it. But that doesn't appear to be the case with rados and I'm not willing to put the $1k or so into it that it needs to be a fairly nice car. You can't give a corrado away these days let alone sell one
      I wish you'd have revived this one/put it in storage somewhere, but I guess they all cannot be saved and the parts will help others. GLWPO.
    16. Awaiting Email Confirmation
      Nov 4th, 2008
      He'll lick your balls
      04' R32, 81' Caddy
      12-12-2011 10:28 PM #16
      still have the exhaust?
    17. Member tstmstr's Avatar
      May 7th, 2006
      it rains here
      Allroad/85 GTI
      12-14-2011 10:50 PM #17
      Bump for a good seller and all around nice guy!
    18. 12-17-2011 08:11 PM #18
      pmed
    19. Member krazy4dubz's Avatar
      Dec 13th, 2002
      The (503) is where I be.
      86 GTi 16v, 78 Rabbit 16v, 91 Passat VR6, 86 GTi VR6, 91 Corrado G60 (Current)
      12-18-2011 03:26 PM #19
      Sent PM and Text.
      Quote Originally Posted by RedYellowWhite View Post
      Rule no.1 for Corrado-owners wifes worldwide: "Never touch the Corrado"
      I Love It When A Plan Come's Together...
      SpoonFed Tuning <<<<< If you own a Corrado click here!!
      My Build Thread
      CPNW (Corrado's of Pacific Northwest) GROUP PAGE
    20. Member
      Feb 18th, 2009
      medford, ny
      1993 corrado slc
      12-25-2011 01:08 PM #20
      pm sent again. haha
    21. Member vwlub94's Avatar
      Dec 10th, 2010
      Bham
      88 Gli
      01-12-2012 03:02 PM #21
      haha weird seeing my old car in parts haha
      Quote Originally Posted by Edleman View Post
      How many people on here get confused when a little red scooter throws you a V?
      Quote Originally Posted by diagramOSC View Post
      The dog needs more low.
    22. Junior Member d1esel's Avatar
      May 15th, 2010
      Bellevue
      2000 gti 1984 diesel rabbit
      01-12-2012 05:19 PM #22
      Do u still have the tan leather seats? Need 4 my rabbit
    23. 01-13-2012 03:24 PM #23
      Do you have the front bumper lip? If so, what's the condition?
    24. Member DüüüG's Avatar
      Oct 5th, 2011
      Whidbey Island
      1988 Jetta Coupe
      01-13-2012 09:31 PM #24
      Free Bump. Buy stuff from this guy, you won't be disappointed.
      originally posted by:ejijah17
      LOWERED ON RACE LAND COILS(not crappy ebay coils)
    25. Member DüüüG's Avatar
      Oct 5th, 2011
      Whidbey Island
      1988 Jetta Coupe
      01-20-2012 02:36 AM #25
      Do you have the blower motor? I need one for my a2.
