Results 1 to 4 of 4
Thread: APR Stage 1 duly cycle logs - CCTA Motor
  1. Semi-n00b
    Jun 24th, 2011
    2008 Audi A3
    12-03-2011 11:54 AM #1
    Hello,
    I just got the APR Stage 1 tune, and my first impressions are great. The car went from "oh thats pretty quick" to "okay, now I have to pay attention to what I'm doing" A HUGE difference in mid range torque.
    However...
    I'm not reaching requested boost levels, and my N75 Duty Cycle is pegged at 96% (minus a short dip at 3k RPM) I'm trying to figure out if I have a boost leak. BTW, I have Revision D DV Valve, everything else is stock
    Does anyone have some stage 1 logs with requested boost, actual boost, and N75 Duty cycle? It would be much appreciated.
    Link to my data logs (download then open with excel)
  2. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    12-04-2011 09:11 AM #2
    Looks like a leak. Request and actual should stay pretty close to being on top of each other. Duty cycle is usually much lower.
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality is remembered long after the sweetness of low price is forgotten.
  3. Semi-n00b
    Jun 24th, 2011
    2008 Audi A3
    12-04-2011 09:10 PM #3
    Thanks for the info Arin. I'll post what I find to be the cause. I'm fairly certain the leak was there before the tune but there was enough headroom in the system to compensate. I was able to reach and maintain stock requested boost with 55-60% n75 duty cycle.
  4. Member John Y's Avatar
    Apr 27th, 1999
    Brooklyn to Hannover, Germany
    10 GTI
    12-05-2011 02:59 PM #4
    So is that spread sheet consistent with a leak? You seem a little slow to build boost, and then actual bleeds off more rapidly requested, but for about 1400 rpm in the mid-range it seems to closely match requested, and you are maxing out at just over 17 psi - which I think is about right for an APR st. 1? Also, what is the deal with the N75 - should it be showing partial values even under full throttle?
