Page 1 of 2 1 2 LastLast
Results 1 to 35 of 47
Thread: 2.0T TSI Ongoing Issues (Water Pump)
  1. Member veedub64's Avatar
    Jul 29th, 2010
    Hampton, GA (Henry Co.)
    Bagged 2010 VW Tiguan S
    12-04-2011 09:54 AM #1
    Maybe someone can held me shed some light on the issue. Just to give a little back story. I brought my 2010 Tiguan new in July of 2010. Everything worked great, no issues. Then come the end of September 2011 I have a really bad coolant leak, bad enough for the coolant dash light to come on and beep. Got it towed to the dealership and it was my water pump. I was still under he 36,000 mile warranty so it was cover at no charge.
    This past Thanksgiving week I noticed coolant leaking again and smelt it. It wasn't as bad this time to make the dash light come on. I took it to the dealership again and it was the back housing of the water pump and seals, yes the same one they replaced in September. The original only lasted 33K miles, this one lasted 4,500. They also replaced my radiator and throttle module.
    Fast forward to yesterday, two weeks since it was replaced the second time and I think it's about to go bad again. I pulled into my garage yesterday and heard a constant high pitch whistle - http://www.youtube.com/watch?v=7HWS2YmsGjo
    I crank it up this morning and run to the gas station and no sound. On my way back, after the engine has had time to get warm it starts again. I don't have any white smoke from the exhaust, it hasn't started leaking YET, however, the passenger side of the radiator has a burn like smile coming from it, no smoke under the hood though. You have to get close to smell it. There is no smell on the inside of the car, even running the heat. I'm going take it back in the morning on the way to work to see if they can give it a quick check over, but in the meantime I'm wondering if anyone else has experienced this or know of someone how has and what the issue was. If it's the water pump it will be the third one, 38K miles, second one in two and a half months.
  2. Member veedub64's Avatar
    Jul 29th, 2010
    12-04-2011 11:24 AM #2
    Update: If I remove the Coolant reservoir cap to relieve the pressure the high pitch sound temporally goes away.
  3. 12-04-2011 12:52 PM #3
    Sounds like the water pump. Has the dealer ever actually replaced the pump??? Or are they just resealing it each time its been in?
  4. Member veedub64's Avatar
    Jul 29th, 2010
    12-04-2011 03:56 PM #4
    They replaced it at this past September. This past thanksgiving they replaced the back housing and seals again, the radiator, and Throttle Module. After removing the reservoir cap to release the pressure I can't hear the sound anymore and it still hasn't leaked yet. I'm going to take it in anyways just to have the check.
  5. Member DasCC's Avatar
    Feb 23rd, 2009
    Monterey Peninsula
    2012 VW CC R-line
    12-04-2011 05:02 PM #5
    Have the same issue with mine. Noise first occurred with 400 miles on the odo. They replaced the WP, sound went away but came back after 500 miles or so. I'm not gonna bother with it again until I take it in for my oil change at 5k. I have 3k right now.
    I'll have to try removing the reservoir cap and see if that does anything.
    Typos courtesy of iPhone 4 using Tapatalk
  6. Member veedub64's Avatar
    Jul 29th, 2010
    12-05-2011 10:57 AM #6
    Sitting at the dealership now. They said the high pitch ring was from the intake manifold gasket and not the water pump, this time.
  7. Member veedub64's Avatar
    Jul 29th, 2010
    12-05-2011 06:56 PM #7
    9.5 hours later and it is still doing the same high pitch sound. They just charged me $541 to replace the intake manifold because he saw my cold air intake and said it was the manifold, this was on the receipt. This even after I mentioned the only way the sounds goes aways is removing the coolant reservisor cap. I will be trying a new VW dealership.
  8. Member DjSherif's Avatar
    Apr 27th, 2005
    Los Angeles
    2010 Audi A3 2.0TQ
    12-08-2011 12:29 AM #8
    I'm currently having some issues. Under hard acceleration the car is bogging down, and I have a misfire. Scanned the car and a flap in my intake manifold is not opening properly and my throttle body won't do an adaptation so I think the throttle body might be bad is well
  9. Member veedub64's Avatar
    Jul 29th, 2010
    12-17-2011 10:22 AM #9
    The high pitch sound has come back, however, it's not as loud before. The only time I can now hear it is when standing next to the car with the engine running.
    Air pressure is getting in somewhere causing air bubbles to build up around the housing seal causing the sound, however, no one knows how the pressure is building up.
    Removing the coolant expansion cap once again relieves the pressure and the sound goes away until the pressure builds back up.
    I'm going to drive it for a few hundred more miles which is when my next service is. I'm going to ask them to replace the coolant expansion tank, maybe the seal is gone bad there and that is where the air is getting in? It's only $25.00 for the tank and it's about the only thing that hasn't been done.
    To recap, over the last 6,000 miles I have had the following done:
    Water pump, housing, seals - (3 times)
    Radiator
    Throttle Module
    Intake Manifold
    I will keep update the thread until a true solutions is found.
  10. Member veedub64's Avatar
    Jul 29th, 2010
    12-20-2011 07:08 PM #10
    I have an appointment next week to see what has caused the ringing to came back. My service rep said that he will have to submit another ticket to VW Tech Corp to see what the next course of action is. After 3 water pumps, radiator, intake manifold, and throttle module I can't bring myself to believe that it's the water pump as the primary cause anymore. No way I get that many defective water pumps unless I'm the unluckiest car guy in the world.
    Something has to be causing the ringing. Possible issues I will bring up with our service rep.
    1. Small crack in the head gasket that's allowing air into the coolant system causing the extra pressure build up. (I don't have an coolant/oil mixture or any white smoke from my exhaust.)
    2. Pulley and/or Belt
    3. Coolant tank and/or cap allowing air in.
    The system was pressure tested a week ago when I had my 3rd water pump installed and no leaks were found.
    Are there any other possible issues I can bring up, that I haven't already had replaced?
  11. Junior Member
    Feb 14th, 2011
    NJ
    04-28-2012 09:06 PM #11
    Quote Originally Posted by veedub64 View Post
    Any update?
  12. Junior Member
    Feb 14th, 2011
    NJ
    05-01-2012 07:32 AM #12
    Quote Originally Posted by Dirty_Dub View Post
    Any update?
  13. Member
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    05-01-2012 03:05 PM #13
    I don't think the noise is from air getting into the system, I think that the plastic water pump housing distorts when the cooling system pressurizes as it heats up, and that distortion causes the bearing (or the shaft seal) to bind-up a little, causing the noise. When you remove the pressure cap, the housing returns to its original shape, and the binding goes away, and therefore the noise.
  14. Junior Member
    Feb 14th, 2011
    NJ
    05-01-2012 05:08 PM #14
    They are ordering new pump but the service manager told me I could pick up my car as the sound I'm hearing is not from the bearing but from the seal. He said he will call me when the new pump comes and they will install it the same day. He told me that it is the same part number but it could be superseeded to a newer pump before it arrives. I asked him if is the same part number who's to say that the sound won't come back his reply was "it may but I couldn't tell you for sure"
  15. Member veedub64's Avatar
    Jul 29th, 2010
    05-02-2012 09:18 AM #15
    So far so good for me after having my 4th pump put on at the end of December, been approx 8,000 miles. The high pitch sound did appear a couple of days after the 4th pump was put on but after removing the cap and squeezing the pipe running from the radiator several times, and leaving the cap off over night and putting in back on the next morning the sound has left. I listen closely all the time, so I just hope my luck continues.
  16. Member DasCC's Avatar
    Feb 23rd, 2009
    Monterey Peninsula
    2012 VW CC R-line
    05-02-2012 10:07 PM #16
    After 4 pumps wouldn't the lemon law kick in?
    Sent from my iDevice using Tapatalk
  17. Member veedub64's Avatar
    Jul 29th, 2010
    05-03-2012 07:52 AM #17
    The lemon law in GA is also based on Mileage. If I remember correctly you have to be under 25K, and I was at 33K when mine first went bad.
  18. 05-09-2012 12:05 PM #18
    So, how's it going? Any news from VW?
  19. Junior Member
    Feb 14th, 2011
    NJ
    05-09-2012 01:23 PM #19
    Quote Originally Posted by feplazas View Post
    The new pump is in. VWOA said there is no recalls and there really wasn't much for them to do. They did say they could extend my warranty on the water pump. Lets just hope this pump last for awhile but i doubt it will.
  20. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    2000 C/W Jetta VRWookie, 2005 Volvo XC90, 2010 CW GTI, 2008 Yamaha R6
    05-10-2012 10:14 AM #20
    What was the part # that they replaced it with?
    Drive it like you stole it!!!
    XBL GT: MasterNele 03
    Need a crank/cam locking tool for your 2.5T (Volvo), PM me.
  21. Junior Member
    Feb 14th, 2011
    NJ
    05-11-2012 10:32 AM #21
    Quote Originally Posted by MasterNele03 View Post
    06j-121-026-AN
  22. Member siren001's Avatar
    Nov 5th, 2009
    SF
    10 2.0T Jetta Wolfsburg
    05-11-2012 10:45 AM #22
    subscribed
  23. 05-11-2012 11:31 AM #23
    06j-121-026-AN
    I really don't think that will fix the problem. 06J-121-026-AN is not even a part for our cars (BA rev. is the latest). I had my wp replaced for the fifth time a month ago, and they also replaced a seal (06H103085Q) with a new rev. (06H103085J). Truth is the noise has not come back.
  24. 05-16-2012 06:15 PM #24
    Status?
  25. Junior Member
    Feb 14th, 2011
    NJ
    05-18-2012 07:41 PM #25
    Status?
    Second replacement pump is now starting to make noise again
  26. 05-18-2012 08:45 PM #26
  27. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    06-01-2012 12:48 AM #27
    Just fell victim to this tonight
    a puddle under the car, low coolant in the reservior and , from up top, coolant all over the bellypan. off to the dealer in the AM
    2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
    Follow on instagram @glfsprtct1
  28. 06-01-2012 08:46 AM #28
    Quote Originally Posted by GlfSprtCT1 View Post
    Sorry man. This prob really sucks. Do this:
    1. Have your wp replaced with the latest rev. for your car (obviously ).
    2. Have the 06H103085J seal replaced.
    3. Have the "auxiliary" (electric) pump replaced (1K0965561J).
    4. Same for your coolant reservoir and its cap.
    How many miles in your car? Any problems before this? Did you have the high pitch noise?
  29. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    06-01-2012 09:36 AM #29
    my dealer was well aware of the issue the second i said 2011 gti and coolant puddle lol
    i had no noise or warning, just happened. car has 13k on the clock.
  30. Member
    Dec 1st, 2009
    06-01-2012 11:31 AM #30
    Why replace the Aux waterpump?????
  31. 06-01-2012 12:47 PM #31
    Quote Originally Posted by CC'ed View Post
    Because it may be working slower than it should be, thus causing more pressure in the water pump.
  32. Member DjSherif's Avatar
    Apr 27th, 2005
    Los Angeles
    2010 Audi A3 2.0TQ
    06-01-2012 12:49 PM #32
    So I just hit 40,000 miles on my car yesterday, I was doing an oil change this morning and noticed that I have coolant leak. And it is coming from the water pump!
  33. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    06-01-2012 05:08 PM #33
    Here ya go guys, hot off the press.
  34. Member jhignight's Avatar
    Nov 21st, 2000
    Crawfordville, FL
    Diesel Deluxe, CC Luxury, P'UP 4x4
    06-01-2012 09:33 PM #34
    Looks like I'm up for this now, too. Our 2010 CC was low on coolant when I went to lunch today, topped it off and within 30minutes I was getting the low coolant light again. At just over 50k, I'm wondering if it will be covered under the 60k powetrain warranty...
    [edit] According to the warranty paperwork that came with the car, water pump and associated seals are covered under powertrain warranty. Dropped it off this am. Here's to hoping the new seal you guys have been posting is the fix.
    To add more: ours never whined/whistled/growled. Just started leaking coolant from the wp area.
  35. Member jhignight's Avatar
    Nov 21st, 2000
    Crawfordville, FL
    06-05-2012 10:27 PM #35
    Got the cc back today, I'll get a pic of the work order later. They put the "BA" pump in.
