1.8T Billet Accessories
In stock and ready to ship, 1.8T billet engine accessories are the perfect addition to your engine bay. For a improved look or options for big power, we have the billet option for you! All accessories available in raw finish or the popular IE red anodized finish.
SAI Block Off Plate
The IE SAI blockoff plate allows the removal of the entire secondary air injection/combi valve system, including the large injection pump near the oil filter for a clean look and easier accessible engine bay. CNC machined from 6061 aluminum alloy, and feature a machined O-ring groove for a perfect seal. O-ring and stainless steel bolts included.
More info here.
Billet Oil Drain Flange and Catch Can Adapter
IE's 1.8T Oil Drain Line Adapter Flange and 1.8T Catch Can Return Adapters are an easy solution for the oil return line on your 1.8T big turbo project. Oil drain flange bolts in the factory return location on your oil pan, and have a -10an male inlet. These are sold as a kit, which includes the adapter flange, new OE gasket, and two stainless steel bolts. More info here
IE's catch can return adapters install between the oil return line flange and the oil pan, and have a 1/8" NPT hole tapped in them for easy plumbing from your catch can. Don't worry about emptying your catch can ever again! More info here
Billett Fuel Rails
IE's 1.8T 20V Billet Fuel Rail for all 1.8T 20V engines. These are made in house from a solid piece of 6061 aircraft aluminum for a one piece design. These rails feature integrated mounts, -8an O-ring boss ports, and retain the factory injector clips for added safety. Great looks and enough flow for high power setups. More info here
FSI/TSI Coil Pack Adapters
IE's 1.8T Coilpack adapter set for use with FSI/TSI coilpacks allow you to run a larger spark plug gap, while maintaining a strong spark output. Testing has shown a smoother idle with these coil packs. Fully CNC machined from 6061 aircraft aluminum and feature a direct fit for all late 06A 1.8T engines and sold with stainless steel bolts.
With FSI Coil Packs
With TSI Coil Packs
(FSI/TSI coil packs sold separately at check out)
More info here
Block Breather Adapter
IE's Billet block breather adapter replaces the brittle plastic crankcase breather hose and installs into the factory bung for the crankcase breather. It features a -10an O-ring threaded port, so you can easily run a braided line, or simply push-lock lines and fittings. More info here
Valve Cover Breather Adapter
IE's -10an Valve cover breather adapter is the perfect solution for your custom breather/catch can setups. Installs in place of the factory hose barb in your valve cover to provide you with a -10an outlet for plumbing in a catch can, or just to convert over to braided lines. CNC'd from 6061 aircraft grade aluminum. More info here
Manual Timing Belt Kit
IE's 1.8T Manual timing belt tensioner kit's prevent unnecessary wear and tear on the belt which leads to premature belt failure and is a great upgrade from the faulty OEM gas-charged tensioner. The billet idler bracket is CNC machined from 6061 T6 aircraft grader aluminum and features roll formed threads for added strength.
Sold in a variety of options:
06A 1.8T Billet Idler Roller
06A 1.8T Manual Timing Belt Tensioner Kit (no belt)
06A 1.8T Manual Timing Belt Tensioner Kit (with belt)
06A 1.8T Manual Timing Belt Tensioner Full Kit W/Pump
058 1.8T Manual Timing Belt Tensioner Kit (no belt)
058 1.8T Manual Timing Belt Tensioner Kit (with belt)
058 1.8T Manual Timing Belt Tensioner Full Kit W/Pump
Coolant Adapter Fitting
IE coolant adapter fitting will allow you to use a factory coolant temp sensor location to plumb a -6an line for your water cooled turbocharger, or anything else you need coolant for. These are made to clip into the factory coolant temp sensor ports. CNC'd in house from 6061 aluminum and finished in IE red anodized finish. More info here
Coolant Temp Sensor Adapter M12X1.5
When installing a standalone ECU, finding a location for your coolant temperature sensor can be a bit tricky. We have designed these adapter bungs to clip into the factory VW/Audi coolant temperature sensor location, and tapped with M12x1.5 threads, commonly found on Delphi, and Bosch coolant temperature sensors. CNC'd in house from 6061 aluminum and finished in IE red anodized finish. More info here
Cam Degree Tools
These billet aluminum degree tools allow the camshafts to be properly degreed in, on that exact engine, by the end user. The set includes two special cam caps for measurement purposes only, bolts and complete instructions. These can be used in the car, but it is much easier to complete the procedure on an engine stand. More info here
Billet Aluminum Heater Core Fittings
The OEM plastic heater core fittings are a common failure part. This is a set of billet aluminum fittings milled from a solid piece of 6061. These fittings are a slick looking fail-proof solution and feature a -10t threaded O-ring port. Sold in pair of two. More info here
Billet Accessory Pulleys
Integrated Engineering's Billet Light Weight Pulleys for 1.8T engines. These pullies are made in house on our CNC lathe from 6061 aircraft aluminum, and finished with a gloss clear anodize finish. Light weight pulleys reduce rotating mass, resulting in a faster revving engine. All pullies are factory size, so there is no worry of underdriving the accessories.
Alternator Pulley - 126 grams Click Here
Power Steering Pulley - 126 grams Click Here
Product line looks great
ll
