Page 17 of 25 FirstFirst ... 7 13 14 15 16 17 18 19 20 21 ... LastLast
Results 561 to 595 of 858
Thread: INTEGRATED ENGINEERING's 1.8Turbo 20V product and new release thread.
  1. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    09-28-2012 08:25 AM #561
    So if their manifold can hold 8000rpm for a min, I think its good to go...
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  2. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    09-28-2012 03:23 PM #562
    can't wait till i can have the fuelrail,adapter, manifold, valvetrain and cams and cnc head with 2.1l all form IE in my car...hopefully inside of the next 6 years lol
    so much win here
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  3. Banner Advertiser Sales@IE's Avatar
    Oct 23rd, 2011
    SLC, UT
    1.8T High power engine dyno.
    10-03-2012 01:52 PM #563
    Winter is right around the corner, who has some big projects planned?
    Connecting rods . Forged Pistons . Valve train . Billet accessories
    IntegratedEngineering - Performance you can measure
    Questions or comments? Contact us: sales@intengineering.com
    Get your free "Wallpaper Wednesday" Download
  4. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    10-03-2012 02:03 PM #564
    Jun 15th, 2011
    Kitchener, Ontario
    1999 Beetle TDI, 2002 GTI 1.8T, 1999.5 GTI VR6
    10-03-2012 04:04 PM #565
    Quote Originally Posted by Sales@IE View Post
    Winter is right around the corner, who has some big projects planned?]
    Ohhhhh that's me , I should have a very large order with in the next month and a half
  6. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    10-03-2012 10:22 PM #566
    Just wanted to say thanks to ben at ie for helping me with my order 83mm je pistons coated for
    My tt and the valve guides for my aeb
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  7. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    10-03-2012 10:47 PM #567
    To Pete & Cassidy for getting my parts here so fast
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  8. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    10-04-2012 11:36 AM #568
    Does the Vi-Pec plug in ECU able to use the factory Knock Sensors or are we gonna have to buy the Vi-Pec knock amplifier kit as well??? Link to what I'm refering to http://www.vi-pec.com/other-products/knockkit...
    According to this info here we will need it
    Table comparing the features of Vi-PEC's ECUs
    FunctionV44V88PlugIn
    Ignition Outputs484
    Injector Outputs486
    Auxiliary Outputs (PWM or On/Off)8108
    Analog Input Voltage5116
    Analog Input Temperature243
    Digital Inputs4106
    Knock Sensor Input020-2[SIZE=2]4[/SIZE]
    Peak & Hold Injector DrivesYYN[SIZE=2]4[/SIZE]
    Internal MAP Sensor4 BarNo4 Bar
    User Define GP On/OffUp to 8Up to 18Up to 10
    User Define GP PWM TablesUp to 8Up to 12Up to 10
    Variable Cam ControlUp to 4Up to 4Up to 4
    Idle Control for 2 & 3 Wire ValvesYYY
    Idle Control, 4 & 6 Wire StepperYYY
    Boost ControlYYY
    AntilagYYY
    Flat ShiftYYY
    Launch ControlYYY
    Logging Memory (ECU)4MB4MB4MB
    Closed Loop Narrow BandYYY
    Closed Loop Wideband WOTY[SIZE=2]1[/SIZE]Y[SIZE=2]1[/SIZE]Y[SIZE=2]1[/SIZE]
    E-Throttle (DBW)Y[SIZE=2]3[/SIZE]YSome
    Knock ControlY[SIZE=2]2[/SIZE]YY[SIZE=2]2[/SIZE]
    QuickTuneYYY
    PC Memory LoggingYYY
    1. External wideband controller required
    2. External amplifier required
    3. External controller required
    4. Depends on model
    External MAP sensors can also be used with all models
    Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
  9. Member theswoleguy's Avatar
    Jan 24th, 2006
    Atlanta, GA
    A few...
    10-04-2012 01:14 PM #569
    Quote Originally Posted by One-Eight GTI View Post
    Ignition Outputs484
    Injector Outputs486
    Digital Inputs4106
    Boost ControlYYY
    AntilagYYY
    Flat ShiftYYY
    Launch ControlYYY
    QuickTuneYYY
    4. Depends on model
    here's a crazy idea, can you set it up to control a VGT solenoid? like the one on my truck's turbo is a 0-5v, 5v vanes fully closed 0v vanes fully open. 35r vgt WOOOO
    Project GTi-R:. '04 R32 Chassis w/ 1.8t transplant in the werks
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, enormous amount of go fast
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, sold to ejg3855
    '13 F150 Ecoboost: Ordered, Rec'd, Triple Black, Tow Truck for other Vehicles.
  10. Member All_Euro's Avatar
    Jul 19th, 2008
    Calgary, AB
    05' VW GLI
    10-04-2012 02:56 PM #570
    Quote Originally Posted by theswoleguy View Post
    Keep up with the crazy talk - I'd love to run a Holset VGT with proper vane adjustment
    KO3 @ 30psi...
  11. Banner Advertiser Sales@IE's Avatar
    Oct 23rd, 2011
    SLC, UT
    10-04-2012 08:16 PM #571
    New 06A and 058 1.8T cam gears fresh in from anodizing.
    Find yours here
  12. Member schwartzmagic's Avatar
    Apr 29th, 2007
    MIA
    2011 Jetta TDI; 05 VW Jetta GLI 5857BT
    10-05-2012 04:26 PM #572
    Find yours here
    From what I see in the pic there are at least 16 columns of cam gears, 5 cam gears down, so thats at least 90 cam gears in that photo. I'm assuming you guys made a batch of at least 100.
    100 x $179.99
    Pretty good sales revenue if you ask me.
  13. Banner Advertiser Sales@IE's Avatar
    Oct 23rd, 2011
    SLC, UT
    10-09-2012 02:55 PM #573
    New Product
    Integrated Engineering Fuel Pressure Regulator Housing
    Now you can easily install that IE fuel rail while keeping your OE FPR secured in a stylish Integrated Engineering Fuel Pressure Regulator Housing.
    These billet fuel pressure regulator housing for OE style fuel pressure regulators easily adapt your regulator to an aftermarket fuel rail. Once the FPR is installed, you can mount the housing to the end of your fuel rail or remotely. The inlet and outlets are -6 AN o ring boss, for easy adaptation to any fitting needed.
    See more here.
  14. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    10-09-2012 03:36 PM #574
    makes my pants get tight
  15. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    10-09-2012 04:02 PM #575
    That is... Beautiful
    Edit: I demand more pictures. You guys should show stuff like that off
    FrankenTurbo F21, CTS Frount mount, Genesis 550cc, Bosch 044, Wiseco pistons, IE Rods, all held together with ARP, 3" 42DD TBE, 2 quarts of my blood, Southbend Stage II, Peloquin LSD, taken care of with Eurodyne ME7.
    Contact Mike P. @ Stevebilt for anything you need.
    Quote Originally Posted by joemiller1989 View Post
    I was pooping when I read this I laughed so hard I couldn't stop pooping
  16. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    10-09-2012 06:20 PM #576
    I picked one up in person yesterday :-). It's a sexy piece. Now I can sell my BBM fuel rail
  17. Banner Advertiser Sales@IE's Avatar
    Oct 23rd, 2011
    SLC, UT
    10-09-2012 07:52 PM #577
    Quote Originally Posted by MrAkalin View Post
    This one is for you, black on black this time.
  18. 10-09-2012 07:58 PM #578
    Quote Originally Posted by Vegeta Gti View Post
    Me too
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-09-2012 11:05 PM #579
    Will your fpr adaptor fit the atp rail ????
  20. Member woodywoods86's Avatar
    Jul 28th, 2008
    Bay Area
    05 VW JETTA GLI
    10-09-2012 11:42 PM #580
    I really want that now, it is looks smaller than the BBM and would work perfectly with my setup! Dammit!
    Buy My Wheels For Cheaper
    Constant, State of Change!
    "Too close for Guns Switch to Missiles"... but, SIR!
    Does anyone read these... I do.
  21. 10-09-2012 11:59 PM #581
    Quote Originally Posted by 01ttgt28 View Post
    this adapter will fit ANY aftermarket fuel rail.
    if the rail has -8AN (as does the IE rail) then you would use -8AN O-ring x -6AN O-ring fitting.
    if the rail is a -10AN like SEM's, then you would use -10AN O-ring x -6AN O-ring.
    and so on and so forth, Amen.
  22. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    10-10-2012 10:59 AM #582
    i put my balls on them, it's exhilarating, but it's much better installed...obviously
    Sent from my SPH-D710 using Tapatalk 2
  23. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    10-10-2012 11:52 AM #583
    not without an adapter.
    the atp rail uses 3/8npt threads (maybe .5in)
    you will most likley need to cobble two adapters together to make it work.
  24. 10-10-2012 07:08 PM #584
    Quote Originally Posted by speed51133! View Post
    ATP rail stock is sized to tap 1/2" npt.
    1/2" NPT x -6AN O-ring boss fitting. done. male to male adapter. (EDITED because Jeff is a fruitcake!)
  25. 10-10-2012 09:58 PM #585
    Quote Originally Posted by speeding-g6O View Post
    male to male coupler.
  26. 10-10-2012 10:09 PM #586
    Quote Originally Posted by Rod Ratio View Post
    dill-hole!!! LOL
    on the left side is the AN, and on the right is the NPT. what i have done in the past is have the cone or taper turned off in a lathe, and even sometimes, depending on flow direction, have a taper on the internal of the fitting put back in. have used this type of setup without fail nor problems plenty in the past, FWIW.
    http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
  27. 10-11-2012 12:05 AM #587
    Svedka/
  28. Member speed51133!'s Avatar
    Aug 5th, 2002
    10-11-2012 11:31 AM #588
    dill-hole!!! LOL
    you know i searched all over for a 1/2in npt to 6an oring fitting. couldnt find one. i ended up cutting off the cone head on the an fitting, but i figure most people dont want to make parts here...
    btw, that pic is no way 1/2in npt to 6an. the part they sell is, it says, but 6an is WAYY smaller than 1/2in npt. 1/2in npt is about 3/4in in diameter. 6an is 3/8in.
  29. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-11-2012 12:14 PM #589
    Many AN fittings allow you to simply add an o ring.
  30. Member speed51133!'s Avatar
    Aug 5th, 2002
    10-11-2012 01:00 PM #590
    yep, you can just slip an oring onto the 6an dome head, and then presto, it is a 6an o ring fitting....
    BUT if the thing it threads into doesnt have the clearance for the tapered dome, then you are out of luck and need to cut it off.
  31. 10-11-2012 01:50 PM #591
    yeah i know, just offering up info. and i just took the pic off Summits website as i didnt see one on IE's.
  32. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    10-12-2012 04:18 AM #592
    man,i need to re-do my silly lines in an stuff eventually. too many rubber hoses and ****.
  33. Banner Advertiser Sales@IE's Avatar
    Oct 23rd, 2011
    SLC, UT
    10-12-2012 07:26 PM #593
    Here is a quick snap for you:
    This is the Integrated Engineering engine dyno test cell.
    We use this room to test, develop, run numbers, gather data, break in engines, and torture parts before they make it into your engine bay. This level of precision research and development ensures the highest quality performance parts, and is the backbone of our company.
  34. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    10-12-2012 07:55 PM #594
  35. Member Twopnt016v's Avatar
    Jul 5th, 2009
    1983 2.0 16v turbo bunny, 1991 2.0 16v Gti, 1986 Jetta Coupe 2.0 16v, 2002 337 Gti, Giannini R1
    10-12-2012 08:06 PM #595
    Very nice! You guys are the smut peddlers of car porn!
