VWVortex.com - 1.8t power?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 39
    Thread: 1.8t power?
    1. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-05-2011 10:35 PM #1
      There has to be an easy way to make power on a reasonable budget. Any ideas?
    2. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      '91 Passat 16V Variant, MK3 Supra Turbo, 1977 Jawa 350
      12-05-2011 10:40 PM #2
      Frankenturbo.
      /thread
      Long live the SCüMWAGON!
      IG: @captain_scum
    3. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-05-2011 10:53 PM #3
      Already have ko4 with the ports smoothed up and Swiss cheese airbox. Still have factory tune and stock everything else. Not sure on hp estimate but runs decent just want more power naturally. Kinda new to all this.
    4. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      12-05-2011 11:04 PM #4
      If I were you I would get a tune specific to the k04 with certain sized injectors, I believe Unitronics has a 380cc tune for the k04. Get a FMIC and an exhaust to make the most of it
      IG: @captain_scum
    5. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-05-2011 11:53 PM #5
      I gutted the cats too do you think I'm hurting it running a stock tune.
    6. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      12-06-2011 12:06 AM #6
      It should be fine you just won't see gains unless your tuned for the setup your running
      IG: @captain_scum
    7. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-06-2011 12:19 AM #7
      Hey man im new and using an iPhone how can i post pics from it
    8. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-06-2011 07:06 AM #8
      Is there a package to do a tune myself or is that something that needs to be left to a professional.
    9. Member ElliottG's Avatar
      Sep 22nd, 2008
      Montreal, Canada
      '99 Passat 1.8t
      12-06-2011 07:50 PM #9
      Get it chipped? Lol
    10. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-07-2011 12:18 AM #10
      Quote Originally Posted by B518tko4 View Post
      This, unfortunately, is not a Japanese car with easily tweak-able engine parameters. You have to re-write the ECU software. Buy a commercial tune; look to spend $400-$500. It's well worth it.
    11. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      B5 5MT UNITRONIC TUNED, B7 6MT STAGE 1.5 TDI
      12-07-2011 12:23 AM #11
      Neuspeed chip around $350, exhaust system, cold air intake? Ur looking at around 200 hp more or less
    12. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-07-2011 12:28 AM #12
      BTW, almost all aftermarket "cold air" intakes for the Passat will actually reduce power; the factory installed CAI is very hard to beat.
    13. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-07-2011 01:09 AM #13
      As for intake I'm running stock box with 1 1/2 inch holes drilled throughout. Filter is speed by spectre. Cats are hollow and exhaust is stock cant find one that sounds quite right. Ko4 was good investment I think and probably a good start but indefinitely need a good ecu. I really appreciate all the feed back. I wanna post pics but having all kinds of problems doing it.
    14. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-07-2011 07:34 AM #14
      Might want to fix that. The holes are drawing hot (less dense) air from inside the engine compartment. Kind of pointless anyway. The stock box already has a flapper at the bottom which opens up if the main intake isn't bringing in enough air.
    15. Member
      Sep 24th, 2008
      2014 Prius C
      12-07-2011 12:14 PM #15
      Biggest power difference for the budget is to get a Chip. Running a stock tune is not giving you much power even if you have a ko4, the stock software is still running a stock boost setting. You need a tune specific for that turbo to run at a higher boost.
    16. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-07-2011 04:35 PM #16
      I do understand about the stock tune I hav just been too cheap or lazy to gt a good tune.
    17. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-09-2011 11:05 PM #17
      How about exhaust. What sounds good.
    18. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-11-2011 01:23 AM #18
      What is a goo front mount intake. I want something that I can make more power later with but will still handle the stick configuration im running till then.
    19. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-11-2011 07:49 AM #19
      What is a goo(d) front mount intake. I want something that I can make more power later with but will still handle the stick configuration im running till then.
      (Facepalm) Refer to "The Last Intake Thread" over at PassatWorld. The best of the aftermarket intakes, the Carbonio, only equals the stock airbox. Most are quite a bit worse. IF you're running some monster setup, like the APR Stage III+, you might, MIGHT benefit slightly from a custom intake - nothing off the shelf.
      The air intake is the LAST place you should be looking for performance. This isn't a 70's Dodge - or a Honda.
    20. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-11-2011 11:20 PM #20
      Haha not a Honda. Yeah I get that. So definitely go front mount and injectors. I wanna do as much as possible before the tune since it isn't a Honda and the tune isn't gonna be fifteen bucks a pop.
    21. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-12-2011 07:19 AM #21
      You might want to re-think that. You have to take a "systems approach" with these cars; doing upgrades piecemeal rarely works as you'd want. Installing higher-volume injectors without appropriate software will almost certainly make your car run like crap. It'll be running too rich for the current software to compensate for.
      A bigger intercooler (front-mounted or not) can have some downsides, too. The idea of it is to reduce heat soak and loss of charge air density. This would happen on hot days with sustained high-RPM operation. Rarely happens with the stock turbo, or in street use. What you WILL get in ALL circumstances is a lack of throttle response - it takes longer for the turbo to pressurize all that piping. It's only a reasonable compromise with a larger turbocharger and/or for track use.
    22. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-12-2011 10:46 AM #22
      Well I want to eventually run autocross. I have run the car gutted mostly in the quarter and with a couple different settings. But I still want a street car. So a front mount kinda would be helpful but never really looked at the downsides.
    23. Member E CODE's Avatar
      Feb 1st, 2005
      Toronto, Ontario
      1 Sedan and 1 Wagon - both Wolfsburg's
      12-12-2011 10:49 AM #23
      Why did you buy a passat???? A golf would have been a better option.... or better yet, a Miata..
      VAGKRAFT | Red BBS RS for sale | Mk6 Part Out | Micro Can VagCom in the Toronto Area
    24. Member B518tko4's Avatar
      Dec 5th, 2011
      98 passat sedan
      12-12-2011 10:53 AM #24
      I really like the look of the passat and where I'm from there are none that are done right.
      For a four door the car Does everything I want it to do. And mazdas suck. Plus I'm a vw guy.
      So there is no hope for the 18t is that what your saying?
    25. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-12-2011 07:41 PM #25
      Hell no. You can make bags of power with a 1.8T; but you're going to be looking at a set of interdependent systems upgrades, not simple incremental bolt-ons. For an idea of where you're heading, look at the APR Stage III kit. When you get up around 300 HP, you'll have to have a manual transmission; a bit after that, you'll have to strengthen the engine internals. I've heard of 500 HP 1.8T's. But it ain't gonna be cheap.
      And as noted, this will all be going into a 3300lb. family sedan. If you weren't kidding about autocross, you really, truly have picked the wrong car.
