VWVortex.com - The Ultimate MKV Wheel Fitment Guide
    Page 1 of 75 123451151 ... LastLast
    Results 1 to 25 of 1851
    Thread: The Ultimate MKV Wheel Fitment Guide
    1. Geriatric Member PSU's Avatar
      May 15th, 2004
      Pennsylvania
      '08 R32 | '15 GTI
      12-07-2011 10:23 AM #1
      First and foremost: suspension before wheels.
      Secondly: build your wheels around your car, not your car around your wheels.
      Lug Pattern
      All MKVs are 5x112.
      Hub Bore
      VW center bore is 57.1mm.
      Mercedes center bore is 66.6mm.
      Tire Sizes
      Factory tire sizes: 225/40/18, 225/45/17, 205/55/16.
      Tire Size Conversion
      195mm = 7.67"
      205mm = 8.07"
      215mm = 8.46"
      225mm = 8.85"
      Tire Size Breakdown
      215/40/18
      215 is the width of the tire.
      40 is the height of the side wall.
      18 is the size of the wheel.
      45 series tires on 17" wheels.
      40 series tires on 18" wheels.
      35 series tires on 19" wheels.
      OE Wheel Listing
      Charlestons: 18x7.5 ET51
      Classix: 17x7 ET54
      Detroits: 18x7.5 ET51
      Huffs: 18x7.5 ET51
      Interlagos: 18x8 ET41
      Karthoums: 18x8 ET51
      Omanyts: 18x7.5 ET51
      What will fit?
      18x8.5 ET45 with 215/40/18s is the ideal fitment for a MKV is without camber or fender work.
      18x8.5 ET35 with 215/40/18s is the most flush fitment without much effort. Front fenders will need rolled and pulled.
      Offset
      Offset is a measure of how far the hub mounting surface is from the center of the barrel. A positive offset indicates that it is further toward the face of the wheel, and a negative offset indicates that it's behind the center of the barrel.
      Offsets on MKVs can vary from ET30 to ET50 without much alteration to the car/suspension.
      Spacers
      Spacers are used to do exactly what the term sounds like... space out the wheels.
      If you run a 20mm spacer on your wheels that are ET51, your new offset will be ET31 as you are pushing the center of the wheel further away from the hub.
      Lug Bolts
      Ball seat lug bolts for OEM wheels.
      Conical seat lug bolts for AFTERMARKET wheels.
      Stock thread pitch is 14x1.5mm
      Stock head size is 17mm
      Stock lug bolt length is 27mm.
      Resources
      http://golfmkv.com/forums/showthread.php?t=59761
      http://www.tyrestretch.com/
      http://www.willtheyfit.com
    2. Member RETAH IH's Avatar
      Jul 21st, 2011
      Center Valley, Pistolvania
      GTI
      12-07-2011 10:24 AM #2
      Hood Rat Status l Skeet Skeet l Pelican Club l Yo' Girl Was Looking At Me l Bangarang
    3. Member 07silverbullet's Avatar
      Mar 10th, 2010
      2015 Autobahn Gti
      12-07-2011 10:25 AM #3
      for great info..
    4. Member AWhiteRabbit's Avatar
      Sep 30th, 2008
      Maryland
      MKV Rabbit
      12-07-2011 10:26 AM #4
      OK.
    5. Member SmithersSP's Avatar
      May 24th, 2006
      Charlotte, NC
      REVO STGIII S3 K04 06' PG GLI, C2 97' GLX
      12-07-2011 10:31 AM #5
      Don't think this is going to stop me from PM'ing you every time I think I find a wheel that might fit my MKV.
      Chapter 11 Dubs
      Revo STGIII Kegerator
      Quote Originally Posted by jhines_06gli View Post
      I fix Pete's car to keep cold, cheap beer flowing for the club at shows.
    6. Member glifahrenheitcameron's Avatar
      Sep 14th, 2011
      Supply NC
      07 gli fahrenheit, 65 bus, 67 bus, 81 caddy
      12-07-2011 10:31 AM #6
    7. Member DoctorDoctor's Avatar
      Oct 18th, 2006
      Bay Area, California
      06 GTI, 04 Jetta (Gone)
      12-07-2011 10:53 AM #7
      Tomas Sport Tuning + Bag Riders = BAGS & BBS RS
    8. Member RobbS's Avatar
      Jul 13th, 2011
      Harrisburg, PA
      Bagged 2006 VW Jetta GLI, 2000 VW Golf (Stage 3, K04)
      12-07-2011 11:06 AM #8
      More info I had gathered when putting my site together...
      Hufeisen (“Huffs”)
      Exact same wheel as Detroit without black inlay
      Manufacturer: BBS
      Bolt Pattern: 5x112
      Width: 7.5”
      Offset: 51
      Detroit (“Monza Shadows”)
      Exact same wheel as Hufeisen with black inlay
      Manufacturer: BBS
      Bolt Pattern: 5x112
      Width: 7.5”
      Offset: 51
      Denver
      Manufacturer: BBS
      Introduced: 2006
      Diameter : 17
      Width: 7
      Weight: 24lbs
      Bolt Pattern: 5x112
      Center bore: 57.1
      Offset: 51mm
      Tire size: 225/45/17
      Wheel part:
      Silver: 1K0601025AH
      Gray-metallic: 1K0601025AH 16Z
      Brilliant chrome: 1K0601025AC 88z
      Center cap part: # 3B7601171
      Bolt Pattern: 5x112
      Classix
      Manufacturer: Ronal
      Diameter : 17
      Width: 7
      Bolt Pattern: 5x112
      Center bore: 57.1mm
      Offset: 54mm
      Wheel part: # 1K0 601 025AN
      Center cap part: # 1K0 601 149J
    9. Member bassmanjosh's Avatar
      Nov 6th, 2004
      Milton, ON
      2006 Golf TDI, 2001 Golf 1.8t
      12-07-2011 11:07 AM #9
      good start. sticky?
    10. Member bryangb's Avatar
      Jun 16th, 2010
      Hanover, PA
      '08 GTI, '15 Golf TDI, '14 Ram Cummins
      12-07-2011 11:08 AM #10
      willtheyfit.com
      Instagram: @bryangb
      bags and wheels = build thread
    11. Member vortexn's Avatar
      May 22nd, 2010
      Canandaigua, NY (585)
      1999 Audi A4 Quattro
      12-07-2011 11:36 AM #11
      I think u should put up examples of what will NOT fit!
      Sent from my iPhone
      Quote Originally Posted by bryangb View Post
      Wheel gap on VW's is much like a girl. If you can fit three fingers than it's not a keeper.
    12. Member Ozzker's Avatar
      Jun 4th, 2010
      Kitchener, ON, Canada
      2008 VW Eos 2.0T 6MT, 2008 VW Touareg 3.6L 6AT
      12-07-2011 11:41 AM #12
      Great idea!
      Should also make an MkV suspension thread which includes price, quality, lowness, adjustability, and pictures.
      Sticky that and this, eliminate 80% of questions asked!
      Instagram: Ozzker / Das Parts
      Das Parts -- https://www.facebook.com/dasvwparts
    13. Member vortexn's Avatar
      May 22nd, 2010
      12-07-2011 11:46 AM #13
      ^ prolly wont but we can jusy link them to the thread n it will save lots of time!
      Sent from my iPhone
    14. Member bryangb's Avatar
      Jun 16th, 2010
      Hanover, PA
      12-07-2011 12:04 PM #14
      Let's not make too many dedicated threads. I don't want my post count suffering too much.
      Instagram: @bryangb
    15. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      01001011010011110 1010010
      12-07-2011 12:13 PM #15
      Quote Originally Posted by PSU View Post
      And thread
      "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
      2008 Mkv-sold; 2003 yellow SRT-4-sold; 2009 G8 GT-sold; 1991 Talon TSI- fully built-sold ; 2011 Mk6
    16. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      12-07-2011 12:16 PM #16
      What you shouldnt do:
      Go backwards in PCD. Example 5x112 to 5x100, just not a safe idea
      Worry about wheel fitment before lowz
    17. 12-07-2011 08:57 PM #17
      Subd
    18. Senior Member christofambrosch's Avatar
      Jul 4th, 2011
      Pennsylvania
      2015 Audi A4
      12-07-2011 09:09 PM #18
      Great resource. Sticky.
      Not that any noobs will read it anyway.
    19. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      2015 Bagged GTI Autobahn l Bagged 2010 GTI (Totaled) l 2007 GLI (Sold)
      12-08-2011 11:03 AM #19
    20. Member dustinwark's Avatar
      Dec 3rd, 2008
      Les Bois
      2.0TFSI
      12-08-2011 12:08 PM #20
    21. Member DoctorDoctor's Avatar
      Oct 18th, 2006
      12-08-2011 12:58 PM #22
    22. 12-08-2011 01:05 PM #23
      215-35-18 is a better idea for on the 8.5 18" when you wanna go low wit et35 (and rolled fenders in the front)
    23. Member giusep4's Avatar
      Jun 4th, 2009
      Des Plaines
      MkV GTI
      12-08-2011 02:15 PM #24
      meh.
      GET LOW
    24. Senior Member christofambrosch's Avatar
      Jul 4th, 2011
      Pennsylvania
      2015 Audi A4
      12-08-2011 03:24 PM #25
      Quote Originally Posted by rutger_edition View Post
      Quote Originally Posted by giusep4 View Post
      meh.
      I agree with meh. That is a tiny tire...for many reasons, I wouldn't recommend it.
