Page 5 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 1218
Thread: The Ultimate MKV Wheel Fitment Guide
  1. Member KIDVersion 1's Avatar
    Jul 4th, 2011
    Pennsylvania
    '89 Coupe, '12 Passat
    12-26-2011 02:49 PM #141
    I would like to add this:
    You're a cool dood.
    2012 Passat Timeline | 2008 R32 Timeline | 1989 Jetta Coupe Timeline | Flick
    For all of your automotive LED needs, visit PerformanceLEDs.
    For all of your air suspension needs, visit Bag Riders.
    May 30th, 2011
    New Jersey
    2010 Jetta TDI Cup Edition (Laser Blue)/ 1989 Toyota Pickup
    12-26-2011 02:51 PM #142
    840 miles on 1 tank of fuel...Get On My Level
  3. Member TeamZleep's Avatar
    Aug 27th, 2007
    MD
    FR-S/MK6 TDI
    12-26-2011 03:22 PM #143
    Quote Originally Posted by PSU View Post
    Apparently I start informative threads and don't know what I'm talking about. #csb
    Up.
    If anyone has anything else to add, chime in.
    EG
    Quote Originally Posted by ColinW. View Post
    ohh ftg's.....static problems.
  4. Member s t a y g o l d's Avatar
    Mar 27th, 2011
    Castle Rock, CO
    '08|Wolfsburg|Static|2.0T|MT
    12-28-2011 03:46 AM #144
    I love this thread. my go-to post for all wheel related curiosity.
    you might consider adding this link, similar to willtheyfit but its a little more dumbed down
    (the distance from strut and wheel well in mm made it easy for a genious like me to understand)
    http://www.1010tires.com/wheeloffsetcalculator.asp
    Quote Originally Posted by cbs_24 View Post
    We don't want to see pictures of your poverty Jetta in this thread. Why is it so hard to understand?
  5. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    12-28-2011 11:20 AM #145
    http://www.willtheyfit.com is a lot better
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  6. Member s t a y g o l d's Avatar
    Mar 27th, 2011
    Castle Rock, CO
    12-28-2011 11:57 AM #146
    Quote Originally Posted by bryangb View Post
    the all knowing bryangb, thank you sir. As I stated in the post, it is similar but a little more simplified for those of us who don't understand all the information given on willtheyfit. thanks though
  7. Member TeamZleep's Avatar
    Aug 27th, 2007
    MD
    FR-S/MK6 TDI
    12-28-2011 12:16 PM #147
    Quote Originally Posted by s t a y g o l d View Post
    I don't wanna sound like too much of a dick, but willtheyfit.com is pretty simple, and easy to read.
    EG
  8. 12-28-2011 02:30 PM #148
    lol is starting to evoke some attitude.
    It's almost like when people argue, and instead of just ending their sentence when their point is through, they say "JUST SAYING."
    jk guys, lets keep the info coming
  9. Member s t a y g o l d's Avatar
    Mar 27th, 2011
    Castle Rock, CO
    12-28-2011 02:55 PM #149
    Quote Originally Posted by TeamZleep View Post
    Agreed. I don't know what I was thinking making a suggestion about a similar resource that is 100% relevant to this thread.
    I'll re-suggest when my post count is +3k & then the k00l k!dz will think it might be of some use to people who visit this thread for information.
    Just to clarify my original point, bro;
    suggested link:
    Use this calculator to determine the effect of changing your wheel width and offset. First enter your current wheel width and offset. Then enter your new wheel width and offset. Next click the calculate button. It will show the clearance between the inside of the wheel and the strut housing. It will also show how far the outside of the wheel edge will extend or retract. If you reduce the inner clearance too much or push the wheel out too far, the tire might rub or not fit at all. This calculator is for information purposes only and we do not guarantee fitment based on this calculator alone.
    (after calculation)
    Inner Clearance: 10mm less (the inside of the wheel to the strut housing)
    Outer Position: extend an extra 28mm (position of the outside edge of the wheel)
    willtheyfit:
    Insert your existing wheel and tyre specs, and the desired size, and the outcome is shown on the diagram. Bear in mind most tyre manufacturers vary slighty from the specs, and that it could be dangerous to run tyres on wheels they aren't designed to fit. The strut shown in the diagram is for show only - Don't worry if the wheel looks like it fouls!
    (after calculation)
    Old New
    Diameter 634.3mm 647.1mm
    Circumference 1992.7mm 2032.9mm
    Poke 34.9mm 63mm
    Inset 142.9mm 153mm
    Speedo error 0% -1.98%
    Reading at 30mph 30mph 29.41mph
    Reading at 60mph 60mph 58.81mph
    Ride height gain 0mm 6.4mm
    Arch gap loss 0mm 6.4mm
    willtheyfit is MUCH MORE in depth and informative, I agree. My point is (as i stated before, twice.) the "n00bz" who want to know if it will fit, are going to have a much easier time looking at the first, because it just tells you, it'll ****ing fit, congrats. whereas the second just tells you a bunch of specs that you may or may not understand.
    all I was saying, bro
  10. Member TeamZleep's Avatar
    Aug 27th, 2007
    MD
    FR-S/MK6 TDI
    12-28-2011 05:18 PM #150
    Just wait until you get over 60k posts, I think your ego consumes the internet.
    What the hell does post count have to do with any of this? EXPERIENCE has everything to do with this... Bro. If you can't read that calculator and have a generalization on what it's saying, maybe you shouldn't be working on your car...
    I didn't bash you for posting something relevant, I said that the other calculator is just as easy to read and it clearly provides MORE useable information that would benefit you in wheel selection.
    Try thinking next time before you run your mouth, Bro.
    EG
    Jan 13th, 2005
    Webster, NY
    2007 Black VW Jetta GLI DSG
    12-28-2011 05:36 PM #151
    Well, here's an update from me. Ordered Schmidt TH-lines in 17x8.5 et33 front, and 17x9.5 et20 rear. Will get back to you guys on how they fit etc., wish me luck!
  12. Member TeamZleep's Avatar
    Aug 27th, 2007
    MD
    FR-S/MK6 TDI
    12-28-2011 06:03 PM #152
    Quote Originally Posted by RomanML320 View Post
    Do werk!!
    EG
  13. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    12-28-2011 06:11 PM #153
    They'll never understand the information until they start seeing it and reading it.
    Post count!!!
    // Open Road Tuning
    Instagram: @bryangb
  14. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    12-28-2011 07:56 PM #154
    Front fitment will be dead on.
    Rear will be poke a bit.
    If only the rear was 17x9.5 +30. You'd be able to tuck them.
    AWhiteRabbit | GrkTurbo SEND ME MY STUFF!
  15. Member
    Jan 13th, 2005
    Webster, NY
    12-28-2011 08:02 PM #155
    Well, we'll see what happens
    Special thanks to you bud!
  16. Member
    Oct 25th, 2011
    Gainesville, Florida
    07 TR GTi
    12-28-2011 08:28 PM #156
    Good thread
    Just for clarification, the strut in the image on willtheyfit.com is not an accurate representation of your strut. It's just there for looks. Best bet is to figure out what the minimum offset of some width wheel is, and base your inset off of that.
  17. Junior Member
    Nov 16th, 2011
    Shawinigan
    GLI 07, Passat Glx 04
    12-29-2011 09:13 AM #157
    ok i've reid the ENTIRE post but... information are fighting each other.... i went to whilltheyfit
    Old New
    Diameter 634.3mm 653.2mm
    Circumference 1992.7mm 2052.1mm
    Poke 37.9mm 73mm
    Inset 139.9mm 143mm
    Speedo error 0% -2.89%
    Reading at 30mph 30mph 29.13mph
    Reading at 60mph 60mph 58.26mph
    Ride height gain 0mm 9.45mm
    Arch gap loss 0mm 9.45mm
    I'm currently on Classix, 225/45/17...want to go on 18/8,5 with 245/40/18 and lowering about 1.3 inch... The table a the second page says i'm in between and need ET45, whill the fit say i need ET 35 ....
    How am i supose to do to fit that under my GLI ?? I will proabaly got rubbing... But...does a fender rolling job will eliminate it???
    HElp !!!!
  18. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    12-29-2011 09:15 AM #158
    ^ ET47 or so should sit you right where you need to be to run 245/40s.
    You'd be fine at stock height, but rubbing is imminent if you go lower.
    Even at stock height though, you'd rub a little from suspension travel.
  19. Junior Member
    Nov 16th, 2011
    Shawinigan
    12-29-2011 09:59 AM #159
    Know that...but does a fender rolling job will help or for the litte difference i'll be screwed anyway ??
  20. Member ninohale's Avatar
    Jun 9th, 2010
    CinnCity
    '06 MKV on pillows & '07 Fahrenheit GTI
    12-29-2011 10:27 AM #160
    Quote Originally Posted by salmonize View Post
    Why such a "meaty" tire.. 245/45 on either an 8 or 8.5 will be relatively thick. I would suggest 235 or even 225 for your tire width. In either situation you should be just fine. The stock tire size on Charlestons (18x8) is 225/40/18.
    The lower the offset the further out your wheel is going to stick. If you roll the fenders it will give you a little extra room but I stress the word little. The wheels your looking to run should be just fine, I would just suggest a smaller, less thick tire.
    l Air Lift l APR l BBSRS l
    @ninohale IG
    ConduKt.Co
  21. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    12-29-2011 10:36 AM #161
    If you knew that, then why did you mention ET35?
    No way in hell a 245/40 is going to work on an 18x8.5 ET35.
    A 215/40 barely works in terms of clearance.
  22. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    12-29-2011 12:57 PM #162
    Why the need for such a ballon tire?
    Get something a little smaller.
    // Open Road Tuning
    Instagram: @bryangb
  23. Junior Member
    Nov 16th, 2011
    Shawinigan
    12-30-2011 09:06 AM #163
    that's what i ask!
    i doing lapping on week end and whant to keep more power on the ground ...does 235/35/18 will be better ??
    i'm not doing it for the look, i want to be stick on the ground....
  24. 12-30-2011 02:49 PM #164
    This isn't exactly a thread emphasizing function.
    Performance-wise, you'd probably be alright with an 18x8 ET45 using a 235/40 tire as long as you're not low. If you lower the car at all, get a stiff-ish setup and you'll be fine.
    I'm not sure if Dan_GSR is on here, but if you're on GolfMKV, send him a PM if you want to find out about a good track setup.
  25. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    12-30-2011 02:52 PM #165
    Quote Originally Posted by HereticByDefault View Post
    What is function?
  26. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    12-30-2011 02:52 PM #166
    that's what i ask!
    not with that offset its just too aggressive with an 8.5 width wheel and a 245 tire you would need 45 or above
  27. Member
    Jan 13th, 2005
    Webster, NY
    12-30-2011 04:02 PM #167
    What is function?
    Poor choice of words, that's all, lol
  28. Member cdj06's Avatar
    Dec 25th, 2011
    06 UG
    12-30-2011 06:38 PM #168
    great info to have
    i might have a great deal on 18s but with the widths and needing adapters im not sure that they would even fit, any input? specs are 18x8.5 et 35 and 18x9 or 9.5 [not sure] also et 35. bolt pattern is 5x100 so would need adapters.
    .:formerly 'HxC_vdubb':.
  29. Member firstorbit84's Avatar
    Feb 25th, 2006
    FL
    '12 Sonic 1.4T; '10 CX-9 (wife's)
    12-30-2011 11:26 PM #169
    HElp !!!!
    Definitely go with 245/35/18 and et45
  30. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    12-31-2011 02:18 AM #170
    Quote Originally Posted by cdj06 View Post
    great info to have
    After adapters, that setup would be too aggressive.
    The smallest adapter is 15mm.
  31. Member WaWaMKVDub's Avatar
    Feb 5th, 2007
    Abingdon, MD
    E32 735i
    12-31-2011 02:48 AM #171
    great info to have
    IIRC they don't make 112-100 adapters.
    Quote Originally Posted by offfthaheeezay View Post
    Rims are for bicycles and Pontiacs.
    06 Gti (gone) 95 Golf City (gone) 00 Cabby (gone) Mk2 Gti (gone) Mk4 Gti (gone) Mk2 Jetta (gone) Mk2 Golf (gone) E32 735I (current)
    I do installs in the MD/PA area. (Air ride, coilovers, etc.) Hit me up!
  32. Junior Member
    Nov 16th, 2011
    Shawinigan
    12-31-2011 11:15 AM #172
    Quote Originally Posted by firstorbit84 View Post
    won't rub with a 1.3 inch drop ??
  33. Member !LL3ST's Avatar
    Oct 12th, 2010
    Central NJ (732)
    E36 & MKV
    01-01-2012 06:20 PM #173
    So I picked up a set of BMW m3 wheels for an absolute steal.
    I know BMW's usually have wacky offsets but is there any
    chance I'll be ale to make these work? (with 15mm adapters)
    Front: 18" x 8", 47mm Offset
    Rear: 18" x 9", 26mm Offset
  34. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    01-01-2012 06:22 PM #174
    Fronts would work. Rears... Not so much.
  35. Member !LL3ST's Avatar
    Oct 12th, 2010
    Central NJ (732)
    E36 & MKV
    01-01-2012 06:27 PM #175
    Thanks for such a quick response PSU
