VWVortex.com - Air Suspension Lifespan?
    Results 1 to 25 of 25
    Thread: Air Suspension Lifespan?
      May 24th, 2011
      Alberta, Canada
      2004 Phaeton 4.2 V8, 2015 Touareg 3.6 FSI VR6, Pre: 2011 Golf 2.5 L5, 2011 Mercedes-Benz C250 V6 RWD
      12-09-2011 12:53 PM #1
      Anyone has any ideas on how long the lifespan is on Phaeton's air suspension? And anything we can do to maintain them? As the fleet ages, I am starting to think of these kinds of questions.
      Thanks!
      Oct 31st, 2008
      SF, CA
      Phaeton '04 4.2L
      12-09-2011 04:46 PM #2
      Tomasty,
      There's no routine maintenance that I can think of. If it goes bad,it will most likely be due to damaged plumbing, damaged sensors, or aged air bladders.
      Damon
    3. 12-09-2011 04:52 PM #3
      It's the same as the ATF in the 6 speed transmission.
    4. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      12-10-2011 04:19 AM #4
      Quote Originally Posted by invisiblewave View Post
      I'm perplexed, I don't understand that comment in the context of the question above.
      Michael
    5. Member FootSore's Avatar
      Aug 22nd, 2006
      Yorkshire, UK
      VW Phaeton 3,0 TDi
      12-10-2011 09:14 AM #5
      Michael,
      I guess invisiblewave means that there is nothing we are supposed to do it. It is supposed to last the lifetime of the car, and we just have to trust them on that. The fuid never needs changing and the air suspension nevers need maintaining. Until the day it does require some assistance in the form of replacement.
      Dave
      Who this week has a Passet CC - Phaeton in for warranty work on doors, all four coming off.
    6. Member
      May 24th, 2011
      Alberta, Canada
      12-10-2011 11:44 AM #6
      Thanks for the input guys, but the problem is, the ATF is not a "life time" item, please check out this post: http://forums.vwvortex.com/showthrea...fluid-(baloney
      And I just changed ATF and fuel filter in my Phaeton, which are both claimed by VW "life time" item, so I am starting to think what is the next "life time" item
      You can see my posts of ATF and fuel filter here:
      http://forums.vwvortex.com/showthrea...Y-(18-Pictures)
      http://forums.vwvortex.com/showthrea...)-(ATF-Coolant)
      Tomas
    7. 12-10-2011 02:31 PM #7
      That baloney thread refers to a completely different transmission, on a Beetle by the looks of it. Who manufactures the Beetle transmission? Compare the colour of the fluid coming out to the fluid that came out of your car, from the photo you posted yours looks like new. What happened to your transmission when you changed the fluid? Anybody can post anything on the internet, just because someone says VW are talking baloney doesn't make it so.
      Oct 31st, 2008
      SF, CA
      Phaeton '04 4.2L
      12-10-2011 02:59 PM #8
      Tomas,
      As far as the air suspension goes, and barring any physical damage, the worst enemy is the age of the rubber components. Just like any seal on a vehicle, it will be subject to failure with age. The bladders inside your air struts are like bicycle inner tubes. They will eventually develop tears due to constant friction an flexing.
      Damon
      May 24th, 2011
      Alberta, Canada
      12-10-2011 05:54 PM #9
      Quote Originally Posted by dlouie View Post
      Tomas,
      Damon
      Hi Damon,
      Thanks, so basically, there is nothing we can do then besides keep all fingers and toes crossed and hope for the best.
      Tomas
    10. Member
      May 24th, 2011
      Alberta, Canada
      12-10-2011 06:01 PM #10
      HI invisiblewave,
      According to the transmission manufacturer ZF, the ATF should be changed every 8 years on 80,000 KMs depends on the driving condition, please refer to this ZF document: http://www01apps.zf.com/kst464/ZF_In...011_en0700.pdf
      I wasn't having problems before the ATF change, just change it as a preventative maintenance, as my car has 169,000 KMs on it. The tech worked on my car also told me the reason VW say ATF is a lifetime item simply because they want to sell more cars that way.
      Phaeton is a luxery car, doesn't mean it's transmission is bullet proof, all fluids degrade over time, there is no such called life time fluid.
      And changing ATF on Phaeton is not new, Michael changed the ATF on his car, there is post under TOC: http://forums.vwvortex.com/showthread.php?2967745
      Tomas
    11. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      12-10-2011 06:36 PM #11
      Quote Originally Posted by tomasty View Post
      ...changing ATF on Phaeton is not new, Michael changed the ATF on his car, there is post under TOC: http://forums.vwvortex.com/showthread.php?2967745
      There is a specific service instruction to change the ATF on the 5 speed Phaeton transmission (used in vehicles with the W12 engine). I am not aware of any specific service instruction from Volkswagen, published in either the NAR or ROW markets, to change the fluid in the 6 speed transmissions.
      Michael
      Sep 17th, 2010
      Newfoundland Canada
      2004 VW V8 Phaeton Luna Blue Sonnen Beige Interior 5 Seater, 2001 Sebring Convertible, 2011 Ram 1500
      12-11-2011 12:11 PM #12
      Ok I'm planning to change my ATF . I'm seeing different numbers all over, flash controller or not. My local Canadian Tire shop has a "new" transmission flush machine, it uses the cooler lines to drain and add new fluid at the same time. I will follow the proper "top up" at 35*C. So what is the proper OEM ATF I should use, G055005A or the G052162A2? The shop listed the G052162A2 at 9.2l for my 6 speed V8, I thought this fluid was for the 5 speed W12.
      Mike
    13. Member
      Oct 31st, 2008
      SF, CA
      Phaeton '04 4.2L
      12-11-2011 02:03 PM #13
      I think this thread got hijacked.
      Damon
    14. 12-11-2011 03:49 PM #14
      HI invisiblewave,
      Tomas
      Yes, it says the fluid is a lifetime fill EXCEPT in those exceptional circumstances, such as a lot of towing. Thanks for posting it, I now know I don't need to change my ATF!
    15. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      2005 Phaeton V10 swb 4-seat, Jeep XK Commander Hemi, SY Stavic 4x4, SY KJ Korando, Mercedes W168
      12-11-2011 04:12 PM #15
      tomasty
      I guess a view on the suspension life would be from the repair experiences of owners of high-mileage Phaetons (say 150k - 200k+ miles). Although that wouldn't really reflect materials ageing as such, only mechanical wear.
      Does anyone know if similar struts were used before 2003 on (say) Quattros?
      seawind3000
      I've seen quoted G052162A2 for 5-speed ATF and G055005A2 for 6-speed ATF (in ETKA).
      invisiblewave
      I'm still going to change mine, the odd unexpected slightly harsh shift means it could be worth it, if it's got to be 'serviced ' anyway at some time in the future...
      Chris
    16. Member
      Aug 5th, 2008
      Maitland, FL USA
      2004 V8 Phaeton, 2005 V8 Touareg
      12-11-2011 05:44 PM #16
      I believe the Audi Quattros & Allroads have a distinctly different air shock. However, I believe the A8s come with air shocks pretty similar in design to those on the Phaeton. A casual view of one Audi A8 forum indicates a much higher failure rate for the compressor in this system rather than the air shocks themselves. Obviously the air shocks can fail, as we've had some evidence of this on our Phaetons. However, I believe VW designs them to last the life of the car, whatever that might mean - maybe 10 years or 100-150k miles. Nevertheless, if the mean failure rate is say, 10 years or 120k miles, many air struts will fail before that as we've seen.
      Since I have a 2004 model, most likely with the obsolete air shocks, my biggest concern is that mine will last so long that VW will cease helping owners with the policy of "owner pays for failed shock and VW pays for the other 3 plus the new controller."
      I'm hoping VW will never totally eliminate this policy, but may require owners to pay an increased share of the expenses as time passes.
      Jim X
    17. Member
      Sep 17th, 2010
      Newfoundland Canada
      12-11-2011 05:57 PM #17
      Sorrry ........ but ATF was mentioned...... somewhere.
      Mike
    18. Member tynee's Avatar
      Dec 18th, 2007
      Pittsburgh
      04/VW/Phaeton V8 Black on Sonnen Beige
      12-14-2011 08:45 AM #18
      Quote Originally Posted by Jxander View Post
      Jim X
      That's funny, that's exactly my biggest concern with the car right now. I wish I could do some preventative maintenance on these shocks, and I baby the car all the time, but it's hard to keep rubber from aging.
      Ditto on the "help" from VW too. Half of me wants to drive hard, fail a shock, and get "help" on the total cost before it expires, and half of me keeps my fingers crossed that nothing will go wrong with the system for years to come.
    19. 12-14-2011 08:56 AM #19
      I think all of us with 04 cars are in that same boat. Every time I approach mine directly from behind or in front when it's on a level surface, my paranoia takes over and convinces me it's leaning one way or the other.
    20. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      12-14-2011 09:40 AM #20
      How about applying some comfort therapy?
      Put 18 month's depreciation into a bank deposit account, put the web address of the cheap Polish strut repair service on a fridge magnet, and forget about it.
      You could have a lovely worry-free time until, say, the year 2021...
    21. 12-14-2011 10:10 AM #21
      If you can supply the address of said Polish strut service (we are talking suspension repair here??), I can forgo the fridge magnet and use a bookmark instead.
    22. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      12-14-2011 10:36 AM #22
      That's typical, I can't find the repair reference now!
      But used struts are about $150 each, the 3D0 907 553 B controller about $60, all plus shipping and import taxes, so no cause for huge panic if you are OK with used parts for a used car.
      But maybe that isn't quite as re-assuring as I had hoped!
      Chris
    23. Member
      Oct 31st, 2008
      SF, CA
      Phaeton '04 4.2L
      12-14-2011 11:08 AM #23
      There is a company in the US that is supposedly working or rebuilt units, Arnott Industries (I'm not affiliated). I've had some correspondence with them in the past asking if they were developing something for the Phaeton. They said they were and have recently introduced products for the Touareg family of cars.
      http://forums.vwvortex.com/showthrea...ilt-Air-Struts
      The following is a link to a long lost post from a forum member who has done some extensive modifications to his suspension and has images showing the internals of the air strut (second image). I think it is the air spring gaiter typically fails.
      http://forums.vwvortex.com/showthrea...1#post60387510
      Failure of air suspension components are enevitable no matter what make. Just check out the Mercedes, Land Rover, and Audi forums.
      Damon
    24. Member
      Nov 23rd, 2009
      Espoo, FIN
      Phaeton V6 TDI Lang 4-seater 2011, BMW i3
      12-14-2011 01:01 PM #24
      It was these guys. Their web site is in Polish but you can make sense of it with Google Translate.
      Jouko
    25. 12-14-2011 01:40 PM #25
      It's times like this when I find it difficult to recall how life was carried on before the Internet!
      Thanks!!
