VWVortex.com - Front Brake Pads Not Sitting Flat
    Results 1 to 19 of 19
    Thread: Front Brake Pads Not Sitting Flat
      Apr 21st, 2008
      Dayton, OH
      2009 GLI 6sp; 2009 Jetta 2.5 5sp
      12-10-2011 02:12 PM #1
      I thought I saw a thread on this once, but can't find it.
      Why do the front brake pads not sit flat against the rotors? There's quite an angle, with the outer edge of the pad apparently worn about twice as much as the inner edge:
      This is with about 42.000 miles on the original pads.
      It's the same both sides on my GLI, and on my wife's Jetta.
      I had my daughter stomp on the brakes with the engine running, so I could see what happens. I expected to see at least some tightening or flattening of the brake pads against the rotor, but didn't notice any movement at all. Brakes seem to work fine while driving.
      Rear brake pads sit perfectly flat against the rotors.
    2. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      Salisbury township/Allentown, PA
      2009 Volkswagen Jetta SE 2.5L, 1995 Ford F-150 Eddie Bauer edition 5.8L
      12-10-2011 03:00 PM #2
      Good pads will have that. It cuts down on brake noise. Cheaper pads usually are completely flat but will end up making noise cause dirt and dust gets stuck between the pads and rotor. That is completely normal
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 03:39 PM #3
      Quote Originally Posted by anteramk5jetta View Post
      Oh, OK... never saw that with our previous VWs or other makes. None of them cheap.
      Does the pad flatten against the rotor when working? I'd expect the inner edge to cause more wear/scoring on the rotor than the outer edge.
    4. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      12-10-2011 03:44 PM #4
      Some higher end pads do come as a flat pad. I've never seen any difference in the way the pad performs. as the pad wears it becomes flatter but during braking it doesn't. whenever I perform a brake service, if the pads that I'm putting on don't have the chaffer at the ends, I do it to the pads. I've rarely have ever had any brake noise problems with pads like that as opposed to flat surface pads
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 04:02 PM #5
      I've been looking at the images of brake pads on the ECS web site. I can see they're chamfered on each end of each brake pad (which I can't see on the pads on my GLI). But that's not what I'm talking about... I'm talking about the angle of the pad from the inner edge to the outer edge, causing the wedge-shaped gap you can see in my image above. Which I think I can also see on at least some of the ECS brake pads.
      So you're saying the pad doesn't flatten out against the rotor when the brakes are applied? (I'm not talking wear, I'm talking the actual angle of the entire brake pad when the piston presses it down.) That would mean only the inside edge presses against the rotor. Seems like that would cause serious wear to that inside edge, as well as to the inside edge of the rotor where the pad hits. But I'm not seeing any such wear to the pad or rotor after 42,000 miles. In fact, I'm seeing even wear on the rotors across their width, which means that the pads must flatten out when pressed down.
    6. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      12-10-2011 04:26 PM #6
      sorry, my mistake. Misunderstood what you meant. The pads DO make full contact when the brake is applied. Google wagner thermoquiet brake pads, they actually explain the chamfer on the edges, they are designed to help reduce brake pads temps, noise, and excess wear. Not all brake pads come like that, and I have seen some pads without problems that are completely flat, but I prefer when they have the chamfer since they seem to perform better overall
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 04:41 PM #7
      I did that, thanks. That applies of course to the chamfering on the ends of the brake pads, not the beveling of the entire pads.
      I see the end-chamfering on images of all replacement brake pads for the Mk5, but I don't see it on my pads. I assume the pad wear has gone past the chamfering by now?
    8. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      12-10-2011 04:44 PM #8
      You still have some towards the top of the pad, when new at the end of the pad (near the rotor hat) is very minimal and usually is great going towards the top of the pad. From a mechanic point of view, your rotors look a little glazed, nothing major, and the pads looks to have 7-8/B meaning about 3/4 life
    9. Member Dronks's Avatar
      Jun 7th, 2011
      Green Bay, WI
      MKV Jetta 2.5l M5
      12-10-2011 04:49 PM #9
      You don't know what he's talking about do you?
      Pads can wear unevenly because of the condition of the slide pins, how their installed and the type of rotor your using. Looks like those pads were not installed correctly or the guide pins aren't moving freely. They are not supposed to look like that.
      If it sounds like sarcasm, it probably is.
    10. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      12-10-2011 04:54 PM #10
      Normally when a caliper slide sticks, or when a pad begins to wear uneven you will see it when looking at the pad from one side to the other. With the picture that is provided I see nothing out of the ordinary regarding the brake pad itself. all in all it is hard to actually give a full CORRECT answer in regards to it since I can't see everything first hand or see the pad comepletly. In the picture you see an area that has far less material then the rest of the pad. That part is designed into the pad and is completely normal. Only other thing I would recommend is the area on the caliper bracket where the spring contact, apply grease there in an effort to help everything moving freely
      Wagener Thermoquiet edge brake pads are shown
    11. Member
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 05:04 PM #11
      Sounds good. Thanks.
      I just had an independent mechanic I trust (as opposed to the local VW dealer) do a check of the car a few weeks ago. He said the front pads have about 7/32" left (I'm not sure at what point on the pads), and the rear pads have 4/32".
      Quote Originally Posted by Dronks View Post
      I'm not a brake expert, but I disagree. First, they're the stock pads that came with the car new. Second, both sides (left and right sides of the car) look like that. Third, the wear across the rotors is even. Fourth, it's the same on the brake pads on my wife's Jetta.
      It's just that I've never seen pads with that beveling.
      Anyone else see the same thing on their Mk5?
      May 21st, 2010
      Dutchess Cnty, NY
      2012 SEL 2.5L Jetta
      12-10-2011 05:14 PM #12
      Pads always wear at a slight angle with the outside pad being more angled than the inside. The high clamping force of front calipers causes that due to the caliper itself flexing. You do have a bit more angle to those pads than normal though. Id check the slides on both calipers and clean/grease them to ensure they are moving freely.
    13. Member
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 05:50 PM #13
      Well, here's what my wife's front pads look like on her Jetta after 22,500 mi. Original pads that came with the car new:
      Looks like exactly the same beveling of the pad, thicker toward the inner edge (toward the hub), touching the rotor surface; and much thinner toward the outer edge.
    14. Member Dronks's Avatar
      Jun 7th, 2011
      Green Bay, WI
      MKV Jetta 2.5l M5
      12-10-2011 07:26 PM #14
    15. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      12-10-2011 07:40 PM #15
      don't have to believe me or trust what i'm saying, not saying you do either. Just giving my experience on the situation since I've been a cert. and licensed mechanic for 12 years now
    16. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      12-10-2011 07:45 PM #16
      I understand what you think you are seeing. The pads are chamfered on the ends, but I guess it's what you would call a compound angle. If you were to take the pad off the car you would see that the center of the pads are flat in the center. I noticed the same thing in the first pic on my car with my stock pads. If you pop the wheel off and shine a flashlight in there you will see what I mean
    17. Member
      Apr 21st, 2008
      Dayton, OH
      12-10-2011 08:18 PM #17
      Quote Originally Posted by blackvento36 View Post
      I see the stock pads are chamfered on the ends. Courtesy of ECS Tuning:
      You know...maybe what I'm seeing is an optical illusion, like you're saying...because of the diagonal edge of the pad, narrowing toward the hub; and the angle I'm looking at it through the wheel opening. Makes it look like the hub edge of the pad is touching the rotor face, while the outside edge isn't.
    18. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      16 Jetta S, 08 Rabbit, 06 Touareg
      11-03-2016 11:03 PM #18
      Glad I found this thread, I freaked when I saw my pads this afternoon. I checked both sides and they look the same. I guess its normal. *whew*
      Sent from my LG V10 using Tapatalk
      Quote Originally Posted by bryangb View Post
      I'm usually too busy reaching for another beer to pay attention to other cars on the road
    19. Member
      Sep 20th, 2013
      Cle Ohio
      2007 VW Golf GTI
      11-04-2016 09:06 AM #19
      So I have allot more ware on the outside (away from hub center) on one of my rears.... it ended up being a bad wheel bearing that had maybe a MM of play in it. Assume this was letting my hub / rotor deflect and as they were used caused uneven ware. Could also be from your calapers flexing, the forces at play are pretty high when you are really pushing on them.
      Do you have a go pro? Mount it inside the wheel well and go hit the breaks and take a look at it in action.
