Welded Water End Tanks!
#40
Thats some really nice work and I cant wait to see it in the bay but how are you gonna change the spark plugs when it comes time?
#41
#42
On second thought, it should not be that bad, just need a small ratchet and a swivel.
#43
please more pictures. manifold going to slip between the valve cover correct?![]()
#44
Yes manifold should appear "nestled" or sunken into the valve cover...
http://smg.photobucket.com/albums/v7...view=slideshow
#47
Looks great! Cant wait to see what it will put down when its all said and done
Keep up the good work guys![]()
#48
that looks great, im sure its gonna lay down some good numbers!![]()
phillyscca.com
J&J autosport
#51
this is absolutly ausome man great job. cant wait to see how it all works out, good luck!
#52
Things are starting to come together, too bad, it all needs to come apart to drop in the built motor...
#53
#54
Holy crap that's amazingly well fabbed.
If you want to make your 2.0 8v faster, read the thread below!
http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
#55
Holy whoa!!!! Amazing work!!
For the PCV you're running a line from the valve cover to the catch can to the block and bypassing the line back into the intake with the filter...amirite?![]()
aka rbi*04
#56
#57
