Results 1 to 27 of 27
Thread: Fs: Alot of mk1 diesel parts engines transmissions anything you need
  1. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    12-12-2011 05:35 PM #1
    I DO NOT HAVE ANY TURBO DIESEL PARTS, I DO NOT HAVE ANY TURBO DIESEL PARTS, I DO NOT HAVE ANY TURBO DIESEL PARTS, I DO NOT HAVE ANY TURBO DIESEL PARTS, I DO NOT HAVE ANY TURBO DIESEL PARTS
    just picked up this Lot of MK1 diesel engines transmissions, and various mk1 parts. Check out the pictures below and let me know what you need. and questions feel free to message me.
  2. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    12-13-2011 11:10 PM #2
    bump
    Dec 3rd, 2009
    Ashland, OR
    1978 Rabbit Diesel 4 door
    12-15-2011 12:53 PM #3
    I am looking for a handful of timing cover grommets & the metal pieces that go into them for the bolts to pass through.
    AC delete brackets
    Sheetmetal pieces to cover the belts on both AC and non AC setups.
    And I`d be interested in one super cheap planetary starter, and cheap 107A pump cores.
  4. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    12-19-2011 11:45 PM #4
    bump
    Dec 24th, 2011
    indiana
    81 rabbit diesel, 99.5 jetta TDI
    12-27-2011 03:37 PM #5
    Looking for crank and water pump pulleys for 1.6 diesel.
  6. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    12-28-2011 12:57 AM #6
    i have a couple of pullies, tell me which one you need?
  7. Junior Member cabron1991's Avatar
    Apr 26th, 2006
    Port Saint Lucie FL.
    1991 Cabriolet
    01-02-2012 08:55 PM #7
    looking for a .71 5th gear sets for a 5 speed tranny ...Thanks Alex
  8. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    01-03-2012 12:59 PM #8
    i do not have any 5th gears
  9. Member 73vw's Avatar
    Aug 7th, 2007
    INDIANA
    90' BMW E30 325i, 82' VW Caddy 1.6D, 90' Corrado 2.0T ABA, 81' Rabbit Vr6
    01-03-2012 08:15 PM #9
    1.6 non turbo block ?
  10. Semi-n00b
    Jan 3rd, 2012
    Utah
    '78 rabbit 1.5D sold, '80 caddy with '82 motor, '97 Dodge Cummins
    01-03-2012 11:03 PM #10
    Looking for a 1.5L head, or a 1.6L turbo block or complete, shipped to 84663. thanks
  11. Member DaVisionz's Avatar
    Jun 25th, 2007
    Round Rock, TX
    1985 Golf Diesel, 2010 Routan, 2003 Passat VR6 4MO(sold), 2007 Rabbit(sold), 1982 Rabbit Cabby(sold)
    01-05-2012 06:03 PM #11
    I'm looking for a 1.6L mech head
  12. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    01-06-2012 10:16 PM #12
    i have a mechanical head and block i am rebuilding now, i will sell them separately, however i will be away for the weekend an will not be home till tuesday
  13. Junior Member
    Nov 5th, 2011
    Festus, MO
    01-10-2012 03:06 PM #13
    How about a 1.6 hydraulic block?
    Steve M.
  14. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    01-10-2012 11:01 PM #14
    the only difference ive come across with and diesel 1.6l blocks are the head bolt sizes, some later mk1 diesl came with the 12mm head bolts like the 1.6l hydraulic head/block, all i have right now are all mechanical lifter blocks
  15. Member DaVisionz's Avatar
    Jun 25th, 2007
    Round Rock, TX
    01-17-2012 09:33 PM #15
    any of those heads 12mm mechanical?
  16. Member 81rabbit's Avatar
    Jan 28th, 2005
    everywhere in NY
    1975 bagged 240d, 1980 corolla, 1980 rabbit, 1982 caddy, 85 golf tdi, 2004 cbr1000rr, 2002 gsxr750,
    09-10-2012 11:55 PM #16
    Sent pm I need one of these engines
  17. n00b 81caddyTDI's Avatar
    Mar 12th, 2010
    West Chester, PA
    1981 VW Caddy
    09-11-2012 09:27 AM #17
    Curious if you have a turbo ( not the ecodiesel turbo). Need it cheap because I plan on rebuilding it anyway. Thanks.
  18. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    81 cutom Caddy-Longhare, 89 Jetta - Cooljet, 84 Rabbit diesel - Rommel
    09-19-2012 07:29 PM #18
    Looking for 2 x 1.6L NA diesel pistons cylinder 1 and 3 if it makes any diference. Also looking for a later model crankshaft sprocket the one with the notch not a keyway. Thanks
    Capt
  19. Member vw315mk4's Avatar
    May 10th, 2010
    Syracuse
    08 328xi wagon 81 caddy
    10-12-2012 06:52 AM #19
    Looking for a running diesel engine
    VrSociety #238
  20. Member
    Jan 21st, 2011
    Utah
    82 Euro caddy TD, 96 passat wagon TDI WVO, 99.5 Golf TDI WVO
    10-12-2012 02:37 PM #20
    Anyone looking for a 1.5 working head that has a 1.6 working head (trade + cash)? Just curious? Also I have a 1.6 block, crankshaft, oil pan, ect. UTAH
  21. Member njslastchance's Avatar
    Apr 6th, 2007
    pennsauken, nj
    84 turbo diesel jetta, 83 turbo diesel rabbit (wrecked), 07 rabbit, 49 dodge d100 pickup
    11-20-2012 03:59 PM #21
    looking for a good 1.6 head
  22. 11-21-2012 09:29 AM #22
    HI! any chance you have a CR mechanical cylinder head with 11mm head bolt holes? trying to rebuild the motor found a hair line crack on the cylinder head i have now. thank you!
  23. Member ShaboyNick72's Avatar
    Nov 17th, 2010
    Clifton Park, NY
    Mk1 Diesel Rabbit
    11-22-2012 10:40 AM #23
    Any turbo diesels? Want the turbo setup. Also, is that an upper timing cover for a 1.5 diesel? I need one
  24. Junior Member
    Jun 30th, 2011
    NJ
    Soon-to-come MK1 Rabbit/Cabby
    11-28-2012 10:47 AM #24
    Hey man, im in NJ too... I'm wanting to swap a turbo diesel and trans into my Daihatsu Charade... wutchu got?!!
  25. Junior Member bushwacker308's Avatar
    Feb 26th, 2009
    broomall, pa
    82 caddy
    12-09-2012 08:52 PM #25
    looking for a 1.6l n/a diesel crankshaft pulley.
  26. 12-13-2012 04:53 PM #26
    Do you have a turbo oil supply line and drain line for a 1.6?
  27. Member Biggmike92gti's Avatar
    Jul 6th, 2004
    bergen county, NJ
    12-18-2012 01:01 AM #27
    NO turbo diesel stuff
    I really dont care about your opinion
