Im finally working on my 16vabaT project again, ordered all the lugtronic goodies from Kevin this week. Fabbed this up the other day, my first real fab/weld job..
#71
^^^ that's a badass turbo..
Aba 16vt jetta coupe 11.2 @132
Run your car not your mouth.
C . T . R
#72
#73
went motor shopping today. my stuff should be dropped off early next week. now the painful part...finding a good working T56 LS1 trans for a reasonable price. ugh lol
K&H fabrication...find us on Facebook! www.facebook.com/khfabrication!
back in the game...but RWD and skidracin
13.24@102 all motor stock motor 12v VR6...bolt on's only
#74
#75
#76
#77
#78
#79
This winter.. My plans were to do nothing much, send in my turbo to be checked, clean and flow injectors, maybe make a headlight air induction for my turbo, nothing major.. So far... I upgraded my turbo to the new 66mm CEA Turbine wheel, new air cooled bb center (old water-cooled ones don't work with new wheels), new turbine housing.. An old friend is making me a quality exhaust manifold, switching over to Ethanol (too poor for VP), skyline GTR rear end on it's way, spoke to Frank about a new driveshaft and axle shafts for the rear, testing the first prototype, and running a very nice CNC fuel rail for 24v BDF head made by 034.. New injectors to flow the extra needed, new fuel pump a little bigger, etc.. Biggest change is letting Kevin take another shot at this pain in the ass car, now running E85 or E98.
Joke picture for views.. Would be nice to mount those suckers right there though.. The new dial gates are very pretty..
Justin - NYCVR6
034 Motorsport
Driveshaft Shop : ST Consulting
FFE Racing : Wired By G
#81
Yea that's the plan! It will be a while till the cars on its feet but it's def gonna be in Kevin's hands at some point![]()
#82
Finish VR Rabbit, hopefully be ready to hit the track when it opens March 3rd.
Complete TH400 swap, fuel system, fit a bigger tire, and turn up boost in the LS car.
#83
I bought a new clutch pac. 6 puc sprung disc, 2600lbs PP and 9lbs Billit steel flywheel.
Yesterday I bought a Roll Bar, 5pt so i don't get kicked for a 11.50 or under pass.
I pick up a set of 1000cc inj's from Aaron today so going up from 860cc to 1000cc.
I am looking into a surge tank to keep from burning down the motor again when the OEM intank
pump siezed and caught fire.
This year i am running only c16 race gas and retuning for 35psi.. I figure crank the boost controller closed and see what the GT3076 will produce. looking for 550whp up from 450whp.
differences are 10 more psi, Race gas instead of pump 92oct. alittle more timing and higher rpm's. I want to run it to 8500rpm on the dyno this time and see how and where the power is made and falls off.
what do you think?
500HP 1990 Cowrado
#84
We dissassembled the 010 (3-speed automatic transmission) from our dragcar today and found that we've split a couple of spider gears into several pieces, jambing part of one against the differential housing causing it to crack the diff. Although we've yet to go back to full boost, we can still apply enough power to overwhelm the stock parts (which were designed for about 1/3 of what we're asking of them).
We're going to replace a few seals, adjust some endplay and put the welded unit back into it. That will get us back on the track at the start of the season.
St.Louis Blues hockey fan!
The blackhawks suck.
#85
I lost 20lbs, 10 more till I hit race weight. Maybe I will finish the car this year...
-Paul
1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
Build Thread: The Build Thread "Good Clean Fun"
#86
#87
We're still developing the box so I'm not really sure how to answer the first part of your question. Since we don't have a tranny brake, we're launching off the footbrake like a granny heading to the grocery store. We have terrible 60' times but the power stays on the whole pass so it's kind of a tradeoff.
I think it's gonna be the shizzy.
#89
My motor is at the maching shop and should be done this week.
Bottom is...
2L FSI crank mod'd by Mr. Ed @ FFE
IE Tuscan rods
JE high compression turbo pistons
head is...
AEB
FFE twin cam gear setup
Solid lifter kit spec'd once again by Mr. Ed @ FFE
IE solid lifter cams
I am excited, can't wait to bolt the motor and trans together and get it in the car.![]()
Douglas VW
Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
Innovative Motorsports + UM
#91
I hope to have the car 100% ready to go in April as long as we have no more set backs.
Douglas VW
#93
got ahold of someone finally? i have just yesterday started grinding away.... gotta take off some under the cam caps too apparently (on the middle lobe each cyl, on the inside window top of cap, those two inside edges)i am just about done with the intake cam..... all 12 holes exiting the lifter section needed work, and the 3 holes for #2 going in to the lifter so far.
#94
JC, here is some of this work and interferences... just started this yesterday actually....
exhaust side
intake side
cam caps are close
in the redneck grinding booth making a MESS!
#95
Looks good, yeah pete got me the cams out last week.
I let the machine shop do all the fitment work as he was doing the rest of the motor anyways.
How long until you are up and running?
Douglas VW
#96
i am running now.... going to dyno on Thursday to get some numbers on this new manifold. then back apart to change the turbo..... this head is just being put together for later, its a back-burner type thing.... i hope to have it together soon, so when the dogbox is done type thing. if not no big deal, i still have one running now.
#97
keep me updated.![]()
Douglas VW
#98
#100
Lately. I've been scraping up as much sidework as i can so i can hopefully not have to change the setup at all during the year.
My long term substitute gig got extended through june, so i've got some financial consistancy now, which is a step up. First whole year to really train some kids to Ninja like ability.![]()
#101
Machine shop gave me a call last night. Everything is looking good just needs to do lash on the 8 exhaust valves and everything is ready to go.![]()
Douglas VW
#102
Ninjas play music? I thought they were simply assassins.![]()
Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
#103
Ninja-like:
-Fast
-Can fly
-Thoroughly meditated and practiced
-Stealthily efficient
That's what we go by.
#104
#105
spent a lil time today assembling some spikey round thingys on some long round rods with little teeth and stuff.
