isnt this a car forum?
#176
all put back together...lol
and loaded up so i could take it to my uncles to have the suspension built
K&H fabrication...find us on Facebook! www.facebook.com/khfabrication!
back in the game...but RWD and skidracin
13.24@102 all motor stock motor 12v VR6...bolt on's only
#177
IFWD 9.14@163 SFWD Junior Varsity GTI
Lugtronic Force Fed Engineering Boost Factory Clutchmasters Caste Systems Performance Madsen Restorations
#178
#179
Sorry guys it used to be a winter chat thread. Guess things have gotten stricter around here.... We'll let everyone go back to being awesome![]()
#180
timmys the only awesome one in here
#184
I am already worried Tim.![]()
Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
#185
#187
#188
#189
#190
#191
#193
After much debate, I've decided on a VRT build. Just need to decide on MK1 or MK2 for the host. I'm leaning toward MK2 however, since weight difference is negligible, and the install would be simpler. I'll start on that in the summer probably, and then work on it over the winter. Hoping to have it running some baselines by next Jan. No solid goal yet, but I wanted to start with 12.5 and whittle my way down...it's a low budget project, no extreme engine builds. Mostly junk yard parts and such. If I can hit 11.5 before it blows up, I'll be satisfied.![]()
#194
Got some work done this weekend. Just waiting on the turbo to come in before i can take it out on the road and try out the dog box.
Also got a new helmet, harnesses and window net.(Anyone who has one should check theres cause there only good for 2 years now)
#195
what turbo you running this year?
||-Audi 90Q-||-2L-||-6765-||-LugTronic-||-10.7@136-||-33psi-||-255 street tires-||-2800lbs-|
http://forums.vwvortex.com/showthrea...llet-LugTronic Instagram -:- JON_ZERB
-:-All powdercoat was done by me! PM me for powdercoating pricing to make it happen!-:-
#197
#199
As a matter of fact I did, in 1999. Ended up finding one. Should have bought a Honda.
-Paul
1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
Build Thread: The Build Thread "Good Clean Fun"
#201
I hate when I have to hit dictionary.com to understand posts.![]()
-Paul
#202
Got my car running considerably better. 19xx lbs @ 12 lbs of boost on street tires is! Can't wait to crank it up to 20. Who's getting excited? Weather is getting nicer and nicer soon time to terrorize the 1/4 mile.
#203
just going to start with the 1.25 housing....
but i needed to clean it up a lil, for some reason these BW turbos are kinda rough in the hotside inlet. lay on gasket, scribe some marks, and get to grinding.
Left to Right 1.25 --> 1.10 --> 1.00
Billet is cool and shiny and stuff
i already ported this housing long ago.
fair bit of material to get out of there
almost done
VIOLA!!!!! should flow much better now....
#204
am i the only one still doin stuffs?
found a lil 1" long slice in one of the slicks. had to get 4 more. talked with John @ M&H Monday, these were here today. 8.5x24.5 / 15's. a true 24.5" tire has 77inch circumference, these are 78.5", which is right at 25".... WOOHOO!!!!! (old ones were 78.625 for reference. pretty close to the new ones)
#205
bad ass. i got mine up and running. still need to tune the car and square some things away before i hit the track.
heres a few quick pics, need to put a real intake on the turbo yet:
Mike
supercharged glx - 12.0 @ 113mph (12psi)
turbocharged glx - 12.7 @ 108mph (7psi), 11's coming soon
S362 .88 a/r
#206
#207
spent most of the time tonight re-routing the dump tubes and redoing the SS hardlines for the wastegates. also re-plumbed the WG solenoid as per the tuners direction.
the list gets shorter and shorter. plan is to do the charge piping on Saturday. making a new VC, catch can, and oil retention pan as well as i dont want to try and put on the engine diaper i got.
#208
i guess i am all alone here..... anyhow.
redid the entire A2W piping today, with nubvr on the welder and me on the fitting/grinding.
Justin @ Linder Power Systems flowed me some couplers, so we redid the piping to incorporate these fittings.
and it looks good i think. spent the whole day doing it all, and it turned out good.
so, Justin (nubvr) came down to Speeding-G60 Race Team HQ today and we spent the whole day redoing the entire boost piping, utilizing Linder Power Systems custom couplers.
we welded onto the turbo compressor outlet, the A2W intercooler inlet and outlet, even cut off and welded on to the throttle body.
it was a longish day of fabrication and welding, and it looks kick ass. i had a MESS of little horseshoe shaped niblets of aluminum pipe laying around when i was done from the constant nibbles and cuts, etc.
THANKS JUSTIN!!!!!
had a fat 3 lb Rib-Eye lunch and beers along the way. when welder comes to you, then feed him you must!
#209
dont worry aaron you are not alone!
narrower front suspension
manual brakes
ccc racing wing
catchpan
oh and set of brute rods and wiseco pistons were dontated by some friends!
#210
Finally got rid of my ebay coilovers and got some decent ones.
Just front D2's i still have the Strange ones in the back that i did right before WCF.
