#141
Also what's the thought behind using multiple wires to run from the abs to the switch? Why not use one wire?
#142
#143
#145
#146
#148
2012 GLI 6MT APR'd Cat Pajamas
Vroom Vroom
#149
just ordered all parts needed for this mod. i am gonna try the part numbers listed on awes site even tho i have the autobahn package. hopefully all will go right. no cel and hopefully it will function properly....wish me luck
#150
Might want to cross reference it with this info. http://forums.vwvortex.com/showthrea...1#post75758920
I know it says NON GLI, but thats because he did it in a "S". I think its still the same of VERY simular. And we did run into AWEs list having the wrong connector for the ABS module.
Fuelly info:
http://mefi.us/images/fuelly/sig-us/84732.png
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
#152
thanks for the info...ive done a good bit of research but i cant seem to find anything that says if awes switch and switch connector for the gli non autobahn works on the actual autobahn...oh well... parts are ordered...guess ill just havta wait n c![]()
#153
Matt / 2012 Candy GLI / AWE / APR
official mk6 Jetta/GLI DIY guide
Hit me up if you need a VAGCOM in Phoenix.
#154
sweet...looks like ill be set then. now all i need is my dp, awe track silver tip exhaust, and stage 2![]()
#155
Anyone in the North New Jersey area who knows what they are doing want to install this for me, I will gladly pay you, feed you and give you alcohol.![]()
#156
Fuelly info:
#158
Fuelly info:
#159
I too would like to know to anyone who has tried this on a 2012 GLI - If you either install the button to disable, or even if you VCDS the ESP to only kick in after 30kph (http://forums.thecarlounge.com/showt...1#post75791103) would you then be able to use Launch Control?
#160
hmmm...well i just installed the switch here at work....no dice
its hot and im tired...but i havent yet figured out why it isnt showing up on my mfd
i used awes guide...all the parts appear to be correct
oe repair wire seated properly
i have power to and from my switch
and my harness appears to have a good connection in each port
any ideas???![]()
#161
I know that the GLI is different than the rest of the Jettas so dont be upset if Im wrong. But I know that for my TDI no light actually came on in the dash console. I also noticed that a simple press didnt work. It took a long press (say 3 seconds) and it turned off. The only way I know it works is by trying. Getting the tires to spin and the traction control light to not come on when they are spining is the only indication I have.
Fuelly info:
#162
#163
ty guys...do you know if the button itself is supposed to light up?
im not getting it to light up at all at any point
#164
#165
I just checked the AWE's guide. I dont see any part numbers for different switches. Care to elaborate?
I NEED to do this to my GLI autobahn w/ nav.
I was just running a really curvy back road last weekend. On exit of a quick left then right bend my esp light lit up like crazy and wouldnt let me go full throttle. I had the pedal the floor in second gear but the brakes just pulsated like crazy.
Im planning on doing stage 1 soon but not until i get this esp button done.
Anyone with info on part numbers for us Autobahn w/nav guys would be great.
#166
#167
success! got everythin up and runnin...btw my 12 gli autobahn 6spd man cbfa engine shows asr off on the mfd and the light up icon on the dash when disabled
btw it turned out that i didnt have a good bite on my positive wire from my power outlet thanx all
#168
Not sure what to tell you. here is a swtich from bold sport. Corret size and it is momentary. But wrong icon
http://www.bold-sport.com/store/inde...&product_id=51
Fuelly info:
#169
Check out http://carstyle4you.com/index.php?cPath=16_24_48
They have quite a few more options, even some custom engraved ones. I also have a Autobahn with Nav, and was looking for other switches - and found some great ones in both "end" and "middle" shapes in Verebs1's post on relocating the TPMS and adding ESP button in the DIY area http://forums.vwvortex.com/showthrea...on-DIY-add-ESP - I havent yet ordered them, but he uses them in his post.
#170
I'm about to do this mod and i think I located the grommet mentioned in the AWE instructions. Is it the rubber sheath? How the heck can you see where you are making the cut in the grommet? I can barely see it as it is.
#171
I installed mine with my buddies over at Wolfcars Motorsports here in Miami. It was quick and easy and it works perfectly! YAY! The only thing is that the button is lit up all the time
LowKulture
Instagram ---> flamenginho <---
#172
I have 3 kits available which are wired correctly meaning light is not always on also providing you full dimmability with other interior lights. I should also have those middle buttons in next week.
Sent from my Galaxy S II Epic 4G Touch using Tapatalk 2 on Android 4.04![]()
#173
Installed my switch/button this morning. Pain the butt getting the wire from the engine bay, through the grommet, and into the passenger side footwell. Works well though, with the ESP Off light illuminated in the gauge cluster when I push the button.
Sent from my ADR6425LVW using Xparent SkyBlue Tapatalk 2
#174
#175
