Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 141 to 175 of 183
Thread: ESP Button
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    02-13-2012 10:30 PM #141
    Also what's the thought behind using multiple wires to run from the abs to the switch? Why not use one wire?
    Nov 3rd, 2011
    RVA
    2011 Jetta SE
    02-13-2012 10:33 PM #142
    Quote Originally Posted by Verebs1 View Post
    there is only one wire going to the module. I just connected two from the switch to that one wire.
    Oct 25th, 2011
    2011 Jetta S
    02-13-2012 11:08 PM #143
    Quote Originally Posted by Fendermender View Post
    I know that I was just referring to the other instructions on AWEs site
  4. Junior Member
    Mar 9th, 2005
    CT
    2012 GLI Autobahn/Nav
    02-16-2012 12:56 PM #144
    So is the ESP button a MOMENTARY switch?
  5. 02-20-2012 11:27 PM #145
    Quote Originally Posted by bmain0407 View Post
    i was on the hill on pearl by boston road lol. do you got a gli too?
    You guys live right by me, I drove down to Arizona though or I'd be right there with you haha
  6. 02-20-2012 11:35 PM #146
    SUCCESS!! It works on the SE's. without the mfd it doesnt give you any idication that its off inside the car but i tried spinning the tires over with it on and it chirped once the light in the dash started flashing and it killed the power, then i hit the button and tried again and it spun like crazy. I took a ton of pictures and ill try to post them up soon and do a write-up when i get more time but here is one for now.
    [IMG]IMG_0327[1][/IMG]
    YESSSS and nice charger, got the same one
    Sep 19th, 2010
    bama
    03 jetta IV gli vr6 24v(sold) 2012 Gli autobahn man.
    04-30-2012 07:54 PM #147
    is your gli autobahn or base?
  8. Member stumpjump's Avatar
    Dec 27th, 2011
    MoCo MD
    05-01-2012 08:04 AM #148
    Quote Originally Posted by alscrx View Post
    Yes.
    2012 GLI 6MT APR'd Cat Pajamas
    Vroom Vroom
    Sep 19th, 2010
    bama
    05-01-2012 01:18 PM #149
    just ordered all parts needed for this mod. i am gonna try the part numbers listed on awes site even tho i have the autobahn package. hopefully all will go right. no cel and hopefully it will function properly....wish me luck
  10. Member pdt165's Avatar
    Jul 29th, 2011
    Fl
    2011 Jetta TDI
    05-01-2012 01:24 PM #150
    Quote Originally Posted by lovinmyjetta View Post
    Might want to cross reference it with this info. http://forums.vwvortex.com/showthrea...1#post75758920
    I know it says NON GLI, but thats because he did it in a "S". I think its still the same of VERY simular. And we did run into AWEs list having the wrong connector for the ABS module.
    Fuelly info:
    http://mefi.us/images/fuelly/sig-us/84732.png
    LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
    Micro-Can, Jupiter FL, PM me.
  11. Member
    Oct 25th, 2011
    2011 Jetta S
    05-01-2012 02:10 PM #151
    Quote Originally Posted by pdt165 View Post
    He has an SE, I have an S ans this is another option for you.
    Sep 19th, 2010
    bama
    05-01-2012 03:50 PM #152
    thanks for the info...ive done a good bit of research but i cant seem to find anything that says if awes switch and switch connector for the gli non autobahn works on the actual autobahn...oh well... parts are ordered...guess ill just havta wait n c
  13. Member asusc's Avatar
    Oct 22nd, 2004
    Scottsdale, AZ
    2012 GLI
    05-01-2012 03:54 PM #153
    Autobahn and non-Autobahn will only matter if you've got KESSY.
    Matt / 2012 Candy GLI / AWE / APR
    official mk6 Jetta/GLI DIY guide
    Hit me up if you need a VAGCOM in Phoenix.
  14. Member
    Sep 19th, 2010
    bama
    05-01-2012 04:03 PM #154
    sweet...looks like ill be set then. now all i need is my dp, awe track silver tip exhaust, and stage 2
  15. Member flypaper89's Avatar
    Nov 10th, 2009
    2010 CC Sport, 2012 GLI Autobahn
    05-01-2012 08:19 PM #155
    Anyone in the North New Jersey area who knows what they are doing want to install this for me, I will gladly pay you, feed you and give you alcohol.
  16. Member pdt165's Avatar
    Jul 29th, 2011
    Fl
    2011 Jetta TDI
    05-02-2012 09:09 AM #156
    And it worked in my TDI too. The only issues are if you have kessy or not. Otherwise everything should work just fine.
    Fuelly info:
  17. 05-02-2012 10:20 AM #157
    I have kessy in my tdi will this mod work?
  18. Member pdt165's Avatar
    Jul 29th, 2011
    Fl
    2011 Jetta TDI
    05-02-2012 10:22 AM #158
    Quote Originally Posted by opticalmike View Post
    Yes, you just need to purchase a different switch. Those without kessy are using the left most switch. Youll need to buy one of the center switches. The different part numbers are on AWE's guide. Other than that there shouldnt be any issues.
    Fuelly info:
  19. Junior Member TransientMole's Avatar
    May 7th, 2012
    Littleton, CO
    2012 Jetta GLI Autobahn/DSG, 2006 Jetta 2.0T
    05-07-2012 02:15 AM #159
    Quote Originally Posted by apmarsh44 View Post
    On another note, does anyone know if launch control would work after installing the ESP button in a 2012 GLI w/ DSG?
    I too would like to know to anyone who has tried this on a 2012 GLI - If you either install the button to disable, or even if you VCDS the ESP to only kick in after 30kph (http://forums.thecarlounge.com/showt...1#post75791103) would you then be able to use Launch Control?
  20. Member
    Sep 19th, 2010
    bama
    05-08-2012 02:38 PM #160
    hmmm...well i just installed the switch here at work....no dice
    its hot and im tired...but i havent yet figured out why it isnt showing up on my mfd
    i used awes guide...all the parts appear to be correct
    oe repair wire seated properly
    i have power to and from my switch
    and my harness appears to have a good connection in each port
    any ideas???
  21. Member pdt165's Avatar
    Jul 29th, 2011
    Fl
    2011 Jetta TDI
    05-08-2012 03:04 PM #161
    any ideas???
    I know that the GLI is different than the rest of the Jettas so dont be upset if Im wrong. But I know that for my TDI no light actually came on in the dash console. I also noticed that a simple press didnt work. It took a long press (say 3 seconds) and it turned off. The only way I know it works is by trying. Getting the tires to spin and the traction control light to not come on when they are spining is the only indication I have.
    Fuelly info:
  22. Member
    Oct 25th, 2011
    2011 Jetta S
    05-08-2012 05:54 PM #162
    The GLI displays a message in the MFD for like 5 seconds.
  23. Member
    Sep 19th, 2010
    bama
    05-08-2012 06:22 PM #163
    ty guys...do you know if the button itself is supposed to light up?
    im not getting it to light up at all at any point
  24. Member
    Nov 3rd, 2011
    RVA
    2011 Jetta SE
    05-08-2012 06:32 PM #164
    If you wire it up per Awe's guide it should always be lit up
  25. Member DangerZone's Avatar
    Feb 5th, 2012
    585, NY
    2012 RB Golf R 4D
    05-08-2012 08:15 PM #165
    I just checked the AWE's guide. I dont see any part numbers for different switches. Care to elaborate?
    I NEED to do this to my GLI autobahn w/ nav.
    I was just running a really curvy back road last weekend. On exit of a quick left then right bend my esp light lit up like crazy and wouldnt let me go full throttle. I had the pedal the floor in second gear but the brakes just pulsated like crazy.
    Im planning on doing stage 1 soon but not until i get this esp button done.
    Anyone with info on part numbers for us Autobahn w/nav guys would be great.
  26. Member
    Oct 25th, 2011
    2011 Jetta S
    05-09-2012 07:02 AM #166
    Quote Originally Posted by DasAUTObahnGLI View Post
    I still think that you may be able to turn the circle in the engine start/stop button around. But without having one to play with I can not try.
  27. Member
    Sep 19th, 2010
    bama
    05-09-2012 12:37 PM #167
    success! got everythin up and runnin...btw my 12 gli autobahn 6spd man cbfa engine shows asr off on the mfd and the light up icon on the dash when disabled
    btw it turned out that i didnt have a good bite on my positive wire from my power outlet thanx all
  28. Member pdt165's Avatar
    Jul 29th, 2011
    Fl
    2011 Jetta TDI
    05-09-2012 12:57 PM #168
    Not sure what to tell you. here is a swtich from bold sport. Corret size and it is momentary. But wrong icon
    http://www.bold-sport.com/store/inde...&product_id=51
    Fuelly info:
  29. Junior Member TransientMole's Avatar
    May 7th, 2012
    Littleton, CO
    05-09-2012 02:08 PM #169
    Check out http://carstyle4you.com/index.php?cPath=16_24_48
    They have quite a few more options, even some custom engraved ones. I also have a Autobahn with Nav, and was looking for other switches - and found some great ones in both "end" and "middle" shapes in Verebs1's post on relocating the TPMS and adding ESP button in the DIY area http://forums.vwvortex.com/showthrea...on-DIY-add-ESP - I havent yet ordered them, but he uses them in his post.
  30. Semi-n00b
    Jan 2nd, 2012
    2012 GLI
    08-24-2012 10:09 PM #170
    I'm about to do this mod and i think I located the grommet mentioned in the AWE instructions. Is it the rubber sheath? How the heck can you see where you are making the cut in the grommet? I can barely see it as it is.
  31. Member W220s's Avatar
    Jul 8th, 2011
    Miami,FL
    2011 Jetta SE, 2005 Mercedes S430
    08-24-2012 10:15 PM #171
    I installed mine with my buddies over at Wolfcars Motorsports here in Miami. It was quick and easy and it works perfectly! YAY! The only thing is that the button is lit up all the time
    LowKulture
    Instagram ---> flamenginho <---
  32. Member
    Oct 25th, 2011
    2011 Jetta S
    08-25-2012 06:40 AM #172
    I have 3 kits available which are wired correctly meaning light is not always on also providing you full dimmability with other interior lights. I should also have those middle buttons in next week.
    Sent from my Galaxy S II Epic 4G Touch using Tapatalk 2 on Android 4.04
  33. Member 16VSerenity's Avatar
    Jul 26th, 2006
    2012 VW Jetta GLI
    08-25-2012 03:58 PM #173
    Installed my switch/button this morning. Pain the butt getting the wire from the engine bay, through the grommet, and into the passenger side footwell. Works well though, with the ESP Off light illuminated in the gauge cluster when I push the button.
    Sent from my ADR6425LVW using Xparent SkyBlue Tapatalk 2
  34. Member HD9280's Avatar
    Jul 26th, 2012
    Los Angeles, CA.
    2013 Jetta TDi Prem
    08-25-2012 04:20 PM #174
    Quote Originally Posted by Jaykaufman101 View Post
    What kind of charger is that? where did you get this?
  35. Member Corradoman8's Avatar
    Sep 14th, 2000
    Hanover, PA
    '90 G60 Corrado(Sold); 2007 Jetta(RIP); 2012 Jetta TDi; 81 Caddy LX
    08-27-2012 02:06 PM #175
    Quote Originally Posted by HD9280 View Post
    That's the iPhone charger from Walmart. I got mine from the "Automotive" section. It's one of the few chargers that will work with the Lifeproof case.
