I was gonna pull the gear off the end of the aba intermediate shaft, and press on the one from the 1.7. That way I'd keep all the gearing correct, but this csnt happen because the end of the shafts are a different diameter.... So, I began to take a closer look at where the 1.7 shaft hits the crank. It hits on that lobe that must have been for something that was scraped, cause it does nothing. I assume this is a balanced unit, so grinding off the spot that hits is gonna be sketchy. But, it looks like minimal wieght has to be taken off so I'm gonna grind it just enough to clear the crank as it passes by. I was thinking that I might be able to time it so the lobe and the crank would be out of time, but they're not one to one, eventually they meet up.
As for the distributor, it mates up with the aba oil pump fine. Lines up with the intermediate shaft gear fine, the only problem is the housing is too small. It fits into the bore in the block instead of on top. I'm having a fitted ring made to fit over the housing. It'll be a few days, I'll take pics when it's done and set up. Ordered the 9a rod bushings today so I can run the 9a pistons on the aba rods. $100 for the set, wtf.
