contact me at 336-847-6084
or email me at yb1990@live.com
The Bad: nothing at all mechanically, has a rust spot in rear right quarter panel
The Good: engine is solid, new statsis coilovers(unbelievable ride, so smooth), fresh tires and alignment all maintenance up to date,NO CHECK ENGINE LIGHT
2000 Audi S4 Black on black(yep another audi)
- 170k miles
- 6 Speed
Maintenance:
- Second Timing Belt and water pump done at 150k
- Valve cover gaskets and cam seals. Done a second time
- New 02 sensors
- Upper Oil pan gasket
- Oil Sending Unit
- Aux Water pump
- Oil changed religiously at 3k miles
- New Windshield & Mouldings last year
- Fuel Filter
- Windshield Wiper motor
- Parking Brake Cable
- Tierod Ends front and rear
- Power Steering pump
- Power Steering rack
- Semi new Pads and Rotors all around
- Spark Plugs
- After Run Switch
- Green temp sensor
- ECS Light weight pulleys ( minus alternator one)
- Reman Alternator
- So many alignments...
- A lot more i cant remember currently.
--Exterior is about 7/10 but looks amazing for black as many people know. Mods:
- Replaced hood, front fenders, rear bumper and driver door
- Rolled Fenders
- Front door has no keyhole
- RS4 Front Grille and new s4 emblems on front and rear.
- Stasis Streetsport Coilovers
-VMR 708s 18X8.5 | Tires Handkook Ventus V12 evo K110 225/40/18 only a few months old. ( one wheel has a slight bend. Doesn't loose air)
- 35% Tint side windows. Back is 30%
- Depo E Code headlights with 35w 6k HID Kit | LED city lights | parking lights removed, only blink for signal
- Yellow fogs, independent fog mod
- Silver Mirrors
- LED Rear license plate bulbs
- Front license plate holder
- Front Bumper has hole in the Pass Side
- Rust Spot on Pass side Quarter Panel.
--Interior 7/10 Pretty good for 170k miles. Still very nice.
- Custom wrapped carbon fiber trim
- A Pillar boost gauge setup ( Completely safe)
- Wiring for radar detector.
--Performance Mods:
- VAST Custom Tune (spike 20psi holds 15-17psi)
- VAST 3 inch Downpipes
AWE Twin One Exhaust
borg warner k04s with modified inlets
-Forge Diverter Valves
- Stern Firm Motor Mounts
- 034 Snub with Bracket
- Apikol Upgraded Rear Diff mount
--Transmission
- Fully rebuild trans. JHM Short Shifter
- Stage 4 8 Puck Ceramic clutch
- New Linkage 1k miles ago
I.got b6. 3.0l w.b7 front end koni coil.. hammer amg w new tires
Txt me for pics 203 5208049
#13
Hey,
I have a B6 A4 Quattro 3.0 6 speed. Lightly modded, new paint and body work.
BRIEF Descrip-Koni Coils, 19 inch wheels, Flashed ECU, Intake, Just got timing and head gasket done.
PM for Pictures if you are interested.
Go fast or don't go at all
