Look at you with all the fancy pix
Sent from my EVO
#1
Got my podi setup finally. I have a mixture of the mk6 white gauge and the mk5 pod. It looks damn nice
The install was cake and the gauge flashes red when you reach higher boost is sweet too. Peak boost recall is what sold me Podi
If anyone is looking to purchase Podi and wants free shipping use this coupon code: NINOSHIP
and yes my name is nino haha
Enjoy the pics
Unitronic > APR Switched from APR to UNI and never looking back
CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
#2
Sent from my EVO
Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
#4
#5
#6
Link????
ps; it looks Fing sweet
WWTD![]()
Just think, What Would T Do?
Who is T? ME .
PM me if want to know wwTd.
#7
I have the other gauge but I dont like the piece of plastic that came with it that holds it to the SW. Does this one bolt on?
Do you have a link for the website with free shipping?
JT
Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
#8
#9
#10
2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
2008 Touareg VR6
#11
#12
#13
How much would come out of pocket to make the switch?
2008 Touareg VR6
#14
Add another podi believer....love this gauge.
2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
#15
#16
Exactly which parts did you order to get this setup? I don't see a B6 setup listed and I love the look you got. Any mods needed to make it fit or is it pretty simple to set up?
#17
what you need to do to MOD the GTI column pod:
pop the old one off, youll need to make a slight mod to the PODI pod its very easy all u need is an exacto knife takes a hole 2 min to do.
this is what the underside of the gauge pod looks like b/f u mod it
what u do:
you need to make a new slot (left of the pic) this hole needs to be directly above the old slot (same size roughly doesn't need to be exact) and directly across horizontally from the right slot
this is what it looks like after
Since you have a indigo set up in your car you'll get the Podi kit for the MKV GTI it comes with everything you need except a boost tap, i recommend the BSH one bc it gives you more options if you were to ass say a vac controlled DV or W/M injection ect..
http://www.bshspeedshop.com/bshstore...Boost-Tap.html
#18
To make it fit better, here are what I sent podi so they can redesign their pods to fit Passat/cc
it literally took 15mins to mod
oh, and that last comment on the last pic was for Podi, just disregard that
#19
Forgot you added the "gutter" i didnt do that to mine yet
Sent from my EVO
#20
I didn't do the gutter on mine either, but I did have to cut the tab off at the end on the angle.
I doubt podi will ever make these changes. It would more than likely require a complete new mold, and depending on how many cavities it is it could be a $10-20K investment.
#21
#22
#23
#24
I'm about to order a podi gauge as well. This looks to be the electronic rather than mechanical.
Is it worth the extra money?
Unitronic Stage 2 -- 42DD 3" catless downpipe -- votex front lip -- HiDef side skirts -- painted rear valence -- mkvi wheel w/DSG paddles -- DDM HID headlights -- Euro side markers -- Interior & licence plate LEDs -- Skyline style Euro Tail Lights -- Podi gauge and pod kit -- revision D diverter valve -- Eibach DG springs (waiting to be installed)
#25
#26
#27
#28
#29
#30
Hmm I may tough out the new south pod for a bit and then upgrade later. I have lots of parts to buy and limited $...
As soon as I get my lemon law money im ordering a votex front and hi def sides. Then Getting the downpipe and springs put on. Then I'm probably gonna redo the tint. Then I go into uni tune & tranny flash saving mode...hopefully after buying all the parts I'll still have $500 off the bat saved up for UNI.
#31
#32
#33
#34
How far does the podi bezel stick out? I need a measurement guys.
I'm concerned that the wheel may not be able to turn fully using the new south pod and podi gauge.
Also congrats on sending ur ecu in.![]()
#35
Bump for bezel
