Results 1 to 7 of 7
Thread: h2o2 what do you think?
  1. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    German, American, Jap'erican
    12-20-2011 03:17 PM #1
    it's an oxidizer
    its by product is h2o
    mixed with meth, the cooling properties plus extra fuel from meth could balance the extra o2
    bad part is it's corrosive to iron... don't think that's an issue in the VW AWp though. Especially in low concentration.
    Possibly a better alternative to nitromethane?
    I'm thinking:
    60% methanol
    30% h2o
    10% h2o2
    or
    40% methanol
    50% h2o
    10% h2o2
    what do you think?
    @Scott, I believe you may have been thinking about something similar
    PROTECTED BY SMITH & WESSON
    CORNFED CAR-MAESTRO-E85 - 3"MAF - IE Rifle Drilled Rods - STATIC- Gonzo Tuning GTT K04 Hybrid Turbo - Devils Own Water Meth - Walbro 255 inline - Eurosport FMIC - Peloquin LSD - Madmax wastegate mod - Werk in Progress INTEGRATED ENGINEERING
  2. Forum Sponsor Scott@USRT's Avatar
    Jan 13th, 2005
    Haddon Heights, NJ
    MK4 Jetta 2.0T, Mk1 Scirocco 16v, 323 GTX
    12-21-2011 09:15 PM #2
    Quote Originally Posted by DMVDUB View Post
    it's an oxidizer
    Oooh noooz... You've released my mad idea hounds! The water/meth scene will never be the same. Yes, I have been looking into this for a while but, I've not completed testing. I've consulted with a a chemical engineer, a Texas Mile racer, and looked at Nazi rocket technology, too. (Seriously. It's relevant and easy to find. -not tryin' to be odd. K?)
    I wouldn't worry about that in the slightest. As you figured, the concentration is too low. Secondly, H202 breaks down immediately into H20 + 02 in the presence of heat and intake "schmutz". (Yiddish FTW)
    Well... H202 in the mix would definitely increase overall fuel burn rate. However, it'd also reduce the octane boosting effect. That's because more fuel would be burnt and contribute to increased cylinder pressure. My intuition is that a significant amount of the stuff would be very helpful for a mild supercharging effect on small turbo cars. It'd theoretically add the same amount of hp on a big turbo car, but the proportion would drop as the the power output increases.
    So, after a point, nitromethane would have an absolute advantage. It's important to note that nitro in the brew reduces EGT when run in sensible proportions. It actually has an octane enhancing effect and is quite helpful for increasing power up to 8 - 10% over base output. Running a few % more water is a good idea to keep it smooth and steady under a wider range of conditions.
    I'm thinking:
    60% methanol
    30% h2o
    10% h2o2
    or
    40% methanol
    50% h2o
    10% h2o2
    what do you think?
    I did my tests SO long ago (~2002), that I can't remember the hard specifics. However, I can see the logic in your formulas and recall doing something like this:
    45% methanol
    35% h2o
    20% h2o2
    My test rig was direct port and with nitrous oxide, btw. Those were the high-risk wild days. (Muhahahhaaaaaa )
    Scott F. Williams, Team Director
    US Rally Team
    www.facebook.com/usrallyteam
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    12-22-2011 10:42 AM #3
    I had thought about it about a year ago and put some in my WM tank. I initially started with the off the shelf bottles, but that didnt seem to do too much, other than provide an expensive source of water for my mix. lmao.
    I have found a local lady who said she would sell me 10% concentration they use for hair if I wanted it, but I'm not 100% sure if I want to... my APR tune already runs STUPID rich, and weak, so until I can get logs going on all of it during the process, Im not pulling the trigger.
    It would be a nice combo to run with a richer Meth mix tho, as all that extra burning meth needs O2 to burn up, so you could theoretically vastly increase power if you get it all right, plus the increase in cylinder pressure from the expanding water vapor... Would be great to get a dyno run going, run logs, just play with it all.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  4. Forum Sponsor Scott@USRT's Avatar
    Jan 13th, 2005
    Haddon Heights, NJ
    12-23-2011 09:19 AM #4
    Quote Originally Posted by Krieger View Post
    Yeah, it's only 3%. That's pretty much useless.
    Go find a hydroponics store and purchase a bottle of 30%. THAT stuff is wicked potent. Do NOT get it on your skin. Holy crap it stings.
    That's smart thinking. Of course, the extra oxygen freed as the peroxide breaks down will help rectify the overly rich condition.
    Yep, but ultimately H202 and methanol have a love/hate relationship. They like to explode in contact with each other. This will increase cylinder pressures... but, will it offset the octane boost? This is the sort of thing that I couldn't test almost 10 years ago. Aftermarket data logging was prohibitively expensive.
    You're a sharp guy, Krieger. If you care to do some testing, USRT will be happy to support. We can supply concentrated H202, nitromethane, guidance, etc.
    US Rally Team
  5. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    12-23-2011 10:12 AM #5
    Well, hopefully Ill be buying a VAG-COM here in the next week or two, so after that, ill gladly start trying out different mixes, started at 85% water, 15% h202, then 70% water, 30% h202. After that, Ill start throwing some meth in the mix, and see just where the sweet spot is before we go overboard and cause a potential "runaway" reaction.
    I have been doing some research, thinking it might be a good idea to get a trunk mounted tank, and moving my pump away from it's current spot mounted to my battery... h202 does not respond well to heat...
    Scott, Ive called you before (Michael Young from Fl. Got your spacer about 2-3 months ago) to talk about WM, so im sure ill be calling you again about all of this, and we can bounce ideas around, get a game plan going. Definitely don't want to just go shooting in the dark... especially with something that can potentially pop a motor
  6. 03-01-2012 03:39 AM #6
    Im down to test this. On a dyno with and without on a big turbo setup
    Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
  7. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    03-04-2012 03:26 PM #7
    my set up is ready to test when ever
    Sent from my SPH-D710 using Tapatalk
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
