Results 1 to 21 of 21
Thread: mk4 Control arm bushings
  1. 12-21-2011 04:44 AM #1
    I got a concern. On urethane control arm bushings front and rear mounts on the lower control arm.
    There are lips on top and bottom of the rear bushing.
    I feel as if when aired out and the angle of the control arm rises up, the upper lip may pop out of the control arm.
    Dose anyone have any input and or running urethane bushings front and back.
    Sep 15th, 2010
    bagged 04.5 BMP GLI/ bagged daily B4 passat vr6
    12-21-2011 08:06 AM #2
    I ran those same bushing all last season and they actually lasted but prevented me from going as low as i would have with oem bushings.
    CORNSTATUS
    KBC Air Suspension Installs
  3. 12-21-2011 01:30 PM #3
    dammit thats what i was afraid of...., I knew i should of gone r32 style. Thanks for the reply
  4. 12-21-2011 01:36 PM #4
    Your still looking pretty low on them.
    http://www.klutchrepublik.com/blog/lady-black-dress
    Car looks great btw
    I might still try and slam on them.
    Sep 15th, 2010
    12-21-2011 02:11 PM #5
    Quote Originally Posted by joebig585 View Post
    Car looks great btw
    haha thanks man! Yeah but i'm like probably a inch from laying frame... and after i notched my subframe and let the car back down i was pissed to find out it wasn't even the subframe holding me up.
    CORNSTATUS
  6. 12-21-2011 04:00 PM #6
    So whats pictures is as low as you can get on the urethane bushings. Even with C notch's and sub frame trimming, pinch welds ect...?
    Sep 15th, 2010
    12-21-2011 04:34 PM #7
    thats as low as she went... everything above done! even tierod notch. those poly bushings are a great thing to stop wheel hop but suck if you want to be low. Maybe someone else will either agree or disagree for both our sakes...
    CORNSTATUS
    Sep 15th, 2010
    12-21-2011 04:41 PM #8
    76 views and i'm the only one who adds anything... I really don't want to run OEM bushings again...
    CORNSTATUS
  9. 12-21-2011 04:56 PM #9
    Only thing i can think of are the urethane r32 mounts
  10. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    12-21-2011 06:00 PM #10
    R32. Only way to go.
  11. Member
    Sep 15th, 2010
    12-21-2011 09:25 PM #11
    Quote Originally Posted by arethirdytwo View Post
    is my assumption correct that the poly bushings will keep you from laying frame?
    CORNSTATUS
  12. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    12-21-2011 11:58 PM #12
    Correct.
  13. Member
    Sep 15th, 2010
    12-22-2011 05:59 AM #13
    Correct.
    Thanks man
    CORNSTATUS
  14. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    12-22-2011 06:10 AM #14
    Do you think the same issue would be ran into with a TT spindle/LCA swap?
    Quote Originally Posted by pentaxshooter View Post
    Ant's car doesn't actually move. He just drives a rollback as a daily. A GTI happens to reside on it.
    Maintenance is paramount.
    Corn Status l Podi l Gonzo GTT l ORT
  15. Member toby lawrence's Avatar
    Dec 11th, 2011
    Boston
    mk4 sled
    12-22-2011 09:06 AM #15
    Anyone laying frame with spherical bushings like H2Sport's offering or the tubular LCA w/ heim joints from IDF? IDF seems like it'd be a go but if you want the proven LCA design but upgraded bushings, H2Sport seems like the way to go. I've been contemplating a set myself, but don't want to bone myself out of laying frame before I even get my air ride installed.
    science: it's for real.
  16. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    12-22-2011 04:19 PM #16
    Depends on wheels. With my 19's I max everything out on the R
  17. Member
    Sep 15th, 2010
    12-22-2011 07:03 PM #17
    from what i have heard the h2sport control arms are very similar to the MK1 TT control arms. The IDF control arms require no trimming of the subframe. Both will allow you to lay frame no problem... But they all cost a crap load of money...
    CORNSTATUS
  18. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    12-22-2011 07:50 PM #18
    TT swap isn't that costly. It's gonna cost me around $500 with new ball joints, bearings, and an alignment.
  19. Member 01Jetta20VT's Avatar
    Jul 4th, 2007
    91 Coupe VR6
    01-11-2012 09:49 PM #19
    The IDF control arms get a ton of travel!
  20. Banned SoIAteAPancakeToday's Avatar
    Apr 21st, 2009
    mexico
    cheby
    01-12-2012 10:59 AM #20
    holy ****, with those innovative control arms if you bottom out you will bend that whole part of the subframe
  21. Member
    Sep 15th, 2010
    01-12-2012 11:09 AM #21
    Quote Originally Posted by SoIAteAPancakeToday View Post
    i just cant justify 500 bucks. maybe if i was racing it and really cared about camber and caster.
    CORNSTATUS
