Page 11 of 13 FirstFirst ... 7 8 9 10 11 12 13 LastLast
Results 351 to 385 of 438
Thread: NUBWORKS ABA LRI Intermanicooler AWIC build.
  1. 09-14-2012 10:10 AM #351
    Looks great! You've got me motivated the start the turbo setup on my wife's cabriolet
  2. 09-14-2012 10:39 AM #352
    Quote Originally Posted by leebro61 View Post
    What are the plans, what motor?
  3. 09-14-2012 11:13 AM #353
    Quote Originally Posted by jettred3 View Post
    Probably just an aba swap with megaquirt Something cheap and fun for her to tear around in.
  4. Member Eganx's Avatar
    Apr 30th, 2004
    Poulsbo WA
    built 90 jetta coupe
    09-16-2012 10:42 PM #355
    Is your hood going to clear that beast? Looks nice in the bay though.....good work
  5. 09-17-2012 01:40 AM #356
    Not a chance without cutting some supports tons of figment issues to work through
  6. Member Bazmcc's Avatar
    Jan 10th, 2005
    Northern Ireland
    2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
    09-17-2012 06:29 AM #357
    How much ground clearance have you got at the bell housing? and sump and the power steering bracket?
    We dropped the mounts down slightly on a MK2 to give us about an extra inch clearance.
  7. 09-17-2012 11:33 AM #358
    Quote Originally Posted by Bazmcc View Post
    Pics? I will measure tonight, no PS.
  8. Member Bazmcc's Avatar
    Jan 10th, 2005
    Northern Ireland
    09-17-2012 11:49 AM #359
    Sorry typo. It was a MK1 (with a MK2 engine). (same mounts as you have). It's been a while since I done it.
    MK2 is much easier. We cut the engine and gearbox mounts down to get more clearance on a mk2 VR conversion but that's a fairly well known adjustment to get the manifold and cover under the hood.
    The gearbox bracket is easy enough. You can bolt on a couple of plates into it with extra holes drilled to lower. Not advised if you have very little ground clearance already though.
    Engine side mount needs cut and rewelded because of where it mounts beside the belt.
  9. 09-17-2012 01:48 PM #360
    Cowl induction hood
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  10. 09-17-2012 02:14 PM #361
    Quote Originally Posted by Rod Ratio View Post
    Cowl induction hood
    Talked it over with Scotty, and the easiest solution is gonna be to chop out the area where it contacts, and then learn to fiberglass.
    Make up a nice elegant bulge and try and blend it in.
    Not messing around with the suspension geometry.
  11. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    08' Rabbit, 97 zx6r (Fighter Project)
    09-17-2012 03:34 PM #362
    Not much to learn. Fiberglassing is very easy.
    Motor looks great in the car
  12. Member Bazmcc's Avatar
    Jan 10th, 2005
    Northern Ireland
    09-17-2012 03:55 PM #363
    I just remembered a subaru hood scoop moulded to a MK4. It was actually quite tastefully done. Something like that might give you a nice bit of clearance. Another option is to buy a BMW M3 hood and use the bulge.
  13. 09-17-2012 04:33 PM #364
    I think thats a legacy scoop, that exactly the one i've toyed with using in my mind.
    Another option... but more work, since they are scarce.....
  14. 09-17-2012 05:21 PM #365
    I can almost guarantee that erebuni, or strictly foreign can source you that or similar.
    Looks like an og reiger or kamei?
  15. 09-17-2012 05:39 PM #366
    Schneider motorsport
  16. 09-17-2012 06:37 PM #367
    Irrespective; that look is the way to go IMO. Everything else would look a bit garish, and out of place; again just my opinion
  17. 09-17-2012 10:03 PM #368
  18. 09-17-2012 10:13 PM #369
    Agreed... Made progress feel like an idiot dv pipe needs some chopping and repositioning but much closer to a finished project.
  19. 09-17-2012 10:27 PM #370
    Fukc it. Drive it with the Hood off
  20. 09-21-2012 11:25 AM #371
    One of the first sets of nozzles ready for testing.
  21. 09-24-2012 09:54 AM #372
    Decided since the hood will not be able to close for awhile, I'm gonna run the exhaust like this just to get her running and to break in the motor....
    Then hitup either RAI Motorsport or NLS for downpipe.
  22. 09-24-2012 10:27 AM #373
    Figuring out the radiator and heat exchanger setup, may be able to run stock rad, with chopped shroud and a slim fan.
    Heat Exchanger is small for now, as i just want to get this running and fall and winter in the northeast should be cold enough for this little guy.
    Down the road having Forge building a custom radiator / AWIC heat exchanger drop in combo...
  23. Member Brian.G's Avatar
    May 7th, 2010
    West of Ireland
    02 25i Msport
    10-01-2012 10:35 PM #375
    Ingenious
    And, page 1, router FTW
    Keep it up, I know you will!
    Brian,
  24. 10-01-2012 10:52 PM #376
    Quote Originally Posted by Brian.G View Post
    Ingenious
    Brian,
    Your formula precision work is stellar as well, top notch!
  25. 10-02-2012 10:01 AM #377
    Alot of little updates, mocking everything up but the wiring, then ordering some proper lines to replace all the couplings....
  26. 10-03-2012 12:14 PM #378
    Things are starting to come together, too bad, it all needs to come apart to drop in the built motor...
  27. Member gbisus13's Avatar
    Aug 16th, 2005
    Roc, NY
    86 Scirocco 16V, 04 Jetta 1.8BT, 89 944 S2
    10-03-2012 12:58 PM #379
    So, is the entire weight of the intake manifold/AWIC supported by the runners/ intake flange? Or are you counting on the turbo to throttle pipe doing some support as well? The welds are beautiful and I'm sure very strong at the moment but aluminum does fatigue out with vibration. Especially with the added weight of the AWIC, it seems like there needs to be some more support for that part of it.
  28. 10-03-2012 01:07 PM #380
    [QUOTE=gbisus13;79210205]So, is the entire weight of the intake manifold/AWIC supported by the runners/ intake flange? Mostly. valve cover might brace it a bit,>>>> Or are you counting on the turbo to throttle pipe doing some support as well?
  29. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    10-05-2012 08:23 PM #382
    Silicone a 1/2 an inch from the turbo hot side = bad idea.. heat sheild might not be enough.
  30. 10-05-2012 10:26 PM #383
    I can address that issue, won't be hard.
  31. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    10-11-2012 03:05 PM #385
    Coming along nicely.
    Is your motor solid mounted? If not are you worried abou the motor rocking to much and hitting the fan shroud?
