VWVortex.com - NUBWORKS ABA LRI Intermanicooler AWIC build.
    Page 2 of 19 FirstFirst 12345612 ... LastLast
    Results 26 to 50 of 457
    Thread: NUBWORKS ABA LRI Intermanicooler AWIC build.
    1. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      01-17-2012 08:54 AM #26
      Looks like a good application for laminova cores.
      Sent from my toaster
    2. 01-17-2012 10:45 AM #27
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      Too costly, unless you have a hook up somewhere.
    3. 01-17-2012 10:46 AM #28
      Quote Originally Posted by nubVR
      So.... got some pics. IC is big, just like i thought it was gonna be. When i recomended the IC we picked, it was based on the first pics you showed me, from bulldogger.... with the core in front of the runners. So keep that in mind when we figure out what were doing!
      First pic, just for size compare and layout, there is about 1/2" i can go down
      angled a little... notice where still really high! Measurment is from bottom of the head, it is also sitting flat on the table, not at angle like the block
      I'm hoping we can chop the core down a bit, or I may just get him another core to work with.
    4. 01-17-2012 11:52 AM #29
      A B C Price Part#
      3.00 2.00 6.00 $89.00 AW300020060
      3.00 2.50 6.00 $99.00 AW300025060
      3.00 2.90 6.00 $108.00 AW300029060
      3.00 3.30 6.00 $116.00 AW300033060
      3.00 3.70 6.00 $124.00 AW300037060
      3.00 4.10 6.00 $132.00 AW300041060
      3.00 4.50 6.00 $140.00 AW300045060
    5. 01-17-2012 11:53 AM #30
      Which core do you think would be best for this application?
    6. 01-17-2012 02:11 PM #31
      Can you take 3/4 inches off the top and bottom of the core to make it thinner?
      I may just source you a thinner core, and sell that one off, if its too much extra work.
      I saw one on silicone intakes that was 3.5" not 4.5. Hp rating is down though...... No cant make thinner, I can't modify core at all! I might be able to sell this one I have another guy that was interested ill send him a message if u want
      Try and sell it off if you can.
      How about sourcing a bell AWIC core and building off of that.
      A B C Price Part#
      Let me take measurements tonight with pics for you and we will get the perfect one..... I'll have to make the water tanks too, bit of work involved just so u know, but it's gonna look 10 times better then the first way we were going
      Sell off the first AWIC, and the funds are yours to work on the extra fab work.
      Thats exactly what I was gonna
      Say... Nice
    7. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      01-17-2012 02:41 PM #32
      If that's a type 8 or type 4 from frozenboost and uncut, I will take it off your hands. Just have justin throw it on my pile and add it to my tab.
    8. 01-17-2012 04:47 PM #33
      I believe its a type 4.
      I'll have justin hook you up.
    9. 01-18-2012 10:02 AM #34
      NUBVR
      Re: Audi AWIC
      Yesterday 06:07 PM
      Ok...... we want
      A=6"
      B=2.90"
      C= 12"
      $156.00
      A600029120
      Double check that flow diagram, and you'll see why its what i posted
      We can go to the 3.10 thick, and gain 50 more cubic feet of air, but id rather have the hood clearance! Im guessing you would too.
    10. 01-20-2012 02:32 PM #35
      [QUOTE=USRT]US Rally Team Hahaha, credit goes to Justin and other USRT gangstas, too. So, when is this beast going to be finished, Dr. Ivey? The flow dynamics of an IC core just before the plenum have got us scratching our heads. None of the conventional formulas we use here "work" with the IC so close. It's fun to be a "n00b" again and watch with no specific expectations.
      5 hours ago · Like/QUOTE]
    11. Member Zorba2.0's Avatar
      Jan 27th, 2005
      Kzoo, MI
      97' Jetta GT, 90' Fox Wagon, Harlequin #125
      01-21-2012 11:42 PM #36
      Why dont you weld 90º elbows onto the turbo? then you wont have to use the couplers.
      I always like the BBM intercooler manifold. Pretty slick design, too bad they only ever made 1 or 2.
    12. 01-23-2012 11:27 AM #37
      With the exhaust manifold flipped, I wont need an elbow.
      If i end up needing a 90 bend, Ill have a elbow with vband outlet on.
      Silicone is for mockup, and initial install only.
    13. 01-23-2012 11:38 AM #38
      Joshua,
      we have (2) Options to offer in the Range you and your Fabricator have indicated:
      - P/N AW600029120, A= 6.0”, B= 2.9”, C= 12.0”
      or
      - P/N AW600029085, A= 6.0”, B= 2.9”, C= 8.5”
      BTW, the Core’s B-Dim. on the Photos looks larger than 2.9” !?!
      If you provide the max. Engine-HP and the Boost-Pressure, at that HP, we can recommend which of the (2) Cores is the preferred Option.
      Gerhard M Schruf
      Bell Intercoolers, Inc.
      Tel: 830-438-6150
      Fax: 830-438-6170
    14. 01-24-2012 03:50 PM #39
      bump it up.
      did work today.
      INDUCTION TEASER 7"Velocity Stack will be mounted in DS Headlight spot.
      This will connect to the BBM airbox, pictured earlier in thread.
      Mounted in headlight bracket, ready to go.
      For Day use and Dyno/ shows only.
    15. Member 02vwgolf's Avatar
      Oct 6th, 2009
      SE-PA
      02 vw golf, 88 Toyota Hilux, 93 4runner(sold), 97 VR jetta(sold)
      01-26-2012 09:29 AM #40
      I like where this is going
    16. 02-02-2012 01:02 PM #41
      Gerhard Schruf gms@bellintercoolers.com
      8:05 PM (16 hours ago)
      to me
      The Bell-Mouth Velocity Stacks after the Intercooler work very well; we have produced several Intercoolers with this Design.
      An “Air-Guide” (Baffle) on the Inlet-Side to the Intercooler, attempting to equal the Flow-Distribution, will help, as well.
      Gerhard M Schruf
      Tel: 830-438-6150
      Fax: 830-438-6170
      Sent: Wednesday, February 01, 2012 9:44 AM
      To: Gerhard Schruf
      Subject: Re: AWIC Intake Manifold Project: Core sizing help needed.
    17. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      S1 Storm 20vSC-AWD, 93 Corrado VR6
      02-05-2012 01:08 PM #42
      Nice build. Just want to mention not to forget to clock your CHRA (turbo center section) so the drain is pointing down. Looking forward to seeing this completed.
    18. 02-06-2012 10:28 AM #43
      Quote Originally Posted by d-bot View Post
      I thought I had it clocked, oh well, i'll definitely take another look and fix that.
    19. 02-10-2012 11:06 AM #44
      alright..... Im gonna highly recomend a billet fuel rail, and a FPR that is moved out a bit, or remote mounted check out how the core sits, off set because of the FPR
      thats the first problem, shouldnt be a big deal, next decision, do you want the core, close to the plenum, or with a couple inches back? Sorry for crappy pics, tranny and oil are all over my work bench, i didnt wanna get the manifold stuff all dirty!
      core is very nice BTW as it should be for the price!
      Making some nice progress.
    20. Banned
      Apr 20th, 2011
      not in the 1.8T Engine forum anymore
      quick, quicker, and quickest.
      02-10-2012 08:08 PM #45
      in this picture, you will not be able to run the vac ports and IAT where you have them, they would be in the core itself and not the plenum. need to roll them on down to the plenum proper.
      Quote Originally Posted by jettred3 View Post
      Just a rough sketch, but thats the idea I'm hoping for.
    21. 02-13-2012 09:59 AM #46
      Quote Originally Posted by Harry Sax View Post
      yeah I figured there would be some details to sort out, where would you suggest placing them, there were added as an afterthought to the initial drawing, just so I had them on there and we would make provisions for use.
      Will revise, and do research before final placement.
    22. Banned
      Apr 20th, 2011
      02-13-2012 02:04 PM #47
      i would put them all on the plenum proper. that way the IAT is getting the proper reading. most IAT are right after the TB, but that is in a system designed with the A2W BEFORE the TB.
      but that is me.....
    23. Member nubVR's Avatar
      Apr 24th, 2004
      Vancouver Wa
      '00 Tropic Orange VR6BT
      02-13-2012 09:38 PM #48
      Nutsack is right....... i thought of it already
    24. 02-14-2012 10:32 AM #49
      Quote Originally Posted by nubVR View Post
      You are the man Justin, I will leave it in your capable hands.
      As for your last question, lets put about an inch between the core and the plenum.
    25. 02-15-2012 10:34 AM #50
      ok this last pic is rough shape of plenum, the front of it is 12" from the head..... Im a little worried about overal height and the hood, sinse the hood slopes torward the front...... Half of me wants to make a card board template that we would be able to attatch and let you shut your hood and see if it smashes.... id hate to do all the work and be cuttin stuff apart, this is the problem with doin this type of stuff and not having a car here!
      Also, water ports, do you want both on one side? or One on each side? Something is telling me both on the driverside might be best..... but not sure where your htinkin about setting all your stuff up. Let me know... im not doin anything else till we get a plan.
      Oh and valve cover.... i dont think we mess with it, i think the way its gonna be shaped it should keep air speed up for the pressure drop its gonna see when it opens up... and the velocity for it hitting those cooling fins? This is all just dumb guy garage theory though
      Making some more progress, any thoughts on the above?....
