    Page 4 of 13 FirstFirst 12345678 ... LastLast
    Results 106 to 140 of 455
    Thread: NUBWORKS ABA LRI Intermanicooler AWIC build.
    1. 05-19-2012 11:54 PM #107
      The black line is where I'm cutting, TB will be tilted slightly torward turbo.... Should be about perfect, sorry for late pic and lack of, had to jam out of work to get to the track yesterday
    2. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      S1 Storm 20vSC-AWD, 93 Corrado VR6
      05-23-2012 01:13 PM #111
      NUBs fat beads, nom nom nom.
    3. 05-23-2012 01:53 PM #112
      Quote Originally Posted by d-bot View Post
      Hahaha.
    4. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      05-23-2012 03:25 PM #113
      I'm glad this is back on track
    5. 05-23-2012 05:01 PM #114
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      Me too, thanks Pat.
    6. 05-24-2012 12:20 PM #115
      Plenum build begins, I may have to source a smaller rad, any suggestions?
    7. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      05-24-2012 01:44 PM #116
      Slimline push fans or aluminum crx rad like the carb/itb guys
    8. 05-24-2012 01:55 PM #117
      CRX rad for the win, that or an early mk1 1.6 or 1.4 liter euro topfill rad.
      I have seen them half the size, but identical to the scirocco topfill rads.
    9. 06-06-2012 04:31 PM #118
      Finishing up pulling the motor tonight.
    10. 06-09-2012 03:34 PM #121
      Picked up a PTE 5557E
      [/QUOTE]
    11. Member dub nutz's Avatar
      Dec 30th, 2010
      vernon, CT
      golf lll vrT, b6 a4 avant
      06-12-2012 08:56 PM #123
      It would be neat to see a vr plenum this way. i like the way this is turning out, cant wait to see it finished
    12. 06-13-2012 11:26 AM #124
      Quote Originally Posted by dub nutz View Post
      VR has been done search sleepers performance.
    13. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      06-13-2012 11:39 AM #126
      rod caps on backwards?
    14. 06-13-2012 11:51 AM #130
      If you are talking about the pic of the rod#1 and the bearing surface being scarred, i forgot to mark that one, and have it reoriented properly, the bearing tangs are on the same not oposing sides right?
    15. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      06-13-2012 12:10 PM #131
      Correct, same sides. I was just making sure. If it wasn't, it would cause some problems though.
    16. Banner Advertiser nothing-leaves-stock's Avatar
      May 16th, 2006
      5780 Main street center valley PA 18034
      a few.
      06-13-2012 12:14 PM #132
      your not reusing that crank and rod correct?
      www.nothingleavesstock.com
      NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
      Email us at sales@nothingleavesstock.com 5780 Main St. Center Valley PA 18034 610 282 5487
    17. 06-13-2012 12:45 PM #133
      Crank no, rod has major dark discoloration, almost like it got so hot when there was literally no rod bearing on either side of rod#1.
      Rod may have ran like that for roughly 70 miles.
      I really cannot afford new rods, but it looks like I may have to hit up I.E.
      those were Scat H-beam rods from BBM.
      Can't I have the crank journal cleaned up, or whole crank reground?
      Have a spare OBD1 Block in the basement, may steal the crank from that.
      Wish I could send the rods to Scat and hope they can take care of me, maybe just sell me one rod.
      Pistons are mint...
      New pump, pan, gaskets, and oil pressure gauge, and oil temp gauge going in, kicking myself for not sorting that after my inital ABA Swap, but never grabbed the sending units of the JH, to work with the cabby triple gauge setup...
      Any thoughts on the Dark Coloration on Rod#1???
    18. Banner Advertiser nothing-leaves-stock's Avatar
      May 16th, 2006
      a few.
      06-13-2012 12:59 PM #134
      do not use the crank or rod. get another crank thats good and get a new rod that matches the others.
      if you reuse that rod. it will NOT last.
    19. 06-13-2012 01:57 PM #135
      Quote Originally Posted by nothing-leaves-stock View Post
      Understood, Yes sir!
      Calling Scat now.
    20. 06-13-2012 02:13 PM #136
      Got this covered, BBM can source me one rod from SCAT just need the big end and small end weights, so they can match the rods I bought OG.
    21. Banner Advertiser nothing-leaves-stock's Avatar
      May 16th, 2006
      a few.
      06-13-2012 02:39 PM #137
      perfect
    22. 06-13-2012 03:38 PM #138
      Got the rod on order 125.00. its 2 grams off oh well.
    23. Member dub nutz's Avatar
      Dec 30th, 2010
      vernon, CT
      06-13-2012 10:11 PM #139
      i found the vr plenum after i posted wish i could afford to have one made
    24. 06-18-2012 05:14 PM #140
      Got my water hardlines mounted. Ended up running both on the passenger side....
