Neat. I like it!![]()
Take a good look at the LRI, I am having fabricated. *Long runners similar to the USRT unit I could not afford. *This should really wake up my Built ABA w/ 270 cam, and sealed airbox with cold air feed and velocity inlet in the lower grille.
original thread.
http://forums.vwvortex.com/showthrea...7#post74435917
I cannot wait till this is finished.
Also going on this motor, is a polished G60 Valve cover, t3/t4 .50 cold side. .63 hot side. and LRI dual plenum manifold w/ integrated AWIC with icebox and Bosch cobra Pump.
Will be using C2's 42lb. fueling kit.
I cannot take credit for the fabrication.
UpdatesOriginally Posted by nubVR
The pics below are from someone elses build but we will design something similar, mostly Justin not me...
Thinking of doing something similar
Any thoughts
*Originally Posted by nubVR
Thanks guys, my built aba with scat rods and ross pistons is making either rod knock or piston slap noises so I'm gonna have to rebuild or swap in a new bottom end before I boost it.
I have a spare motor on a stand and am gabbing the down pipe for my mk1 as well.
If anyone wants to do some good reading check out Bentley publishers maximum boost by corky bell of bell inter coolers.
Looks goood
Message me for tuning solutions.
https://www.facebook.com/inteng?v=ap...data=cid_12851
Please vote for me, i'm having rod knock.
It will fit, we are building it from scratch.
PLEASE TAKE the time to vote for me.
Just a rough sketch, but thats the idea I'm hoping for.
I'm hoping we can chop the core down a bit, or I may just get him another core to workOriginally Posted by nubVR
We will end up running a bell core, and selling off the core pictured up.
#11
This is just the type of manifold I wanted to build, but I wanted ITB's as well.
ROUGH draft.
8VALVETURBO - Sorting the kinks out.
#13
#14
Enough Ice in the 2.6 gallon resevoir, a good pump, and maybe a little CO2, and the core will be sufficiently cool.
The CO2 spray would only be for making "a one shot cooler?, where The intake charge*is cooled so much it is actually below ambient temperature before entering the plenum.
It might be liquid nitrogen, the drag guys use i'm not sure but basically you can in theory make an AWIC more than 100 percent efecient and actually lower temps below Ambient IAT...
#16
#19
INDUCTION TEASER 7"Velocity Stack will be mounted in DS Headlight spot.
This will connect to the BBM airbox, pictured earlier in thread.
Mounted in headlight bracket, ready to go.
For Day use and Dyno/ shows only.
#20
I mocked up my Kinetic manifold like that and the turbo compressor hit the firewall.
That was on a MK3.
#21
#22
Making some nice progress.Originally Posted by nubVR
Making some more progress, any thoughts on the above?....Originally Posted by nubVR
#23
#24
#25
Pics? I'm not that good at interweb yet. Here is a link to my build: http://www.dubsnorth.org/forum/viewt...11068&start=30
Only one OK pic of the turbo manifold setup on page 3.
I like that manifold your building.![]()
#27
[QUOTE=jettred3;75484752]Originally Posted by USRT
Manifold is up for sale, taking serious offers.Originally Posted by nubVR
#28
Looks great!! I remember back in 2007 bum had an awic intake mani for the aba but stop making it. It looked insane, infect I believe a couple people brought it. Gl keep up the good wrk
d.i dubinvasion.co
#32
Plenum build begins, I may have to source a smaller rad, any suggestions?
#33
Stripping the motor down for a rebuild tonight, pretty sure its just rod bearings.
#34
crazy...looks good
like the air filter shield you are using![]()
Boost... the displacement replacement!
BBM, LLC 541.388.1202
www.BahnBrenner.com
we share the passion!
