started phase one of the ebrake project. i need to get some styro tomorrow and some abs pieces and some fusor hopefully this works as planned. iff not i just ruined a perfectly good ebrake surround. if not ill just mill out a chunk of abs plastic
#36
>>>PM ME FOR CUSTOM STICKERS AND TSHIRTS
CUSTOM BATTERY RELOCATIONS!! ANY CAR ANY MOTOR!!!
>>>POWDER COATING AND CERAMIC COATING NEEDS<<<<
formally "a sneaky panda" 7,022 posts...now starting over
#37
#38
in for progress, nicely done roger!![]()
going back to stock salehttp://forums.vwvortex.com/showthrea...0#post75141950
#39
#41
#42
1/3 new alternator tensioner bracket came today from my buddy shane. this one is from a mk1, works much better than a mk2 bracket
i need to clearance out a little more of the alternator then im going to space out the bracket and toss it in
also bought, new antenna/base/wire, an early diesel console, golfball shift knob, and need door card speaker grills
here is how it sits in the bay normally (with a/c, please ignore the black bar its obv not there in an OEM system
this is how it sits after grinding and rotating it down into the bracket with the mk1 adjuster.
#43
Hey lookin good man.![]()
Time for anyone and everyone to bomb b6lovin's threads with kittens and Sh!t talk. Where is he located?
Ricky
WTB: .:R32 brakes. ~PM Me~
My 16v-T build http://forums.vwvortex.com/showthrea...ng-to-be-fast.
#44
#45
Ya seriously, When you sell something it's not a "Take your time to ship" kind of deal. Just because it's a personal sale and not a business sale, people think that honesty and courtesy can just fly out the window. Lame
You build that garage or is "new" to you?
Ricky
#46
#47
Ricky
#48
1/4 - got hardened hardware for the alternator bracket today, started working in the bay to remove the old bracket and swap this one in, i used hardened bolts, hardened flange nuts, and 3 washers as spacers
#49
1/5 got the alternator in the car and the new belt on 25" belt. mk1 tension arm seems to work well. tomorrow im pulling it back out to put on a pulley from a non a/c car. the nut used as a spacer isnt quite long enough and it twists the belt a tiny bit
rotated 180* down from original location
#51
thanks
i have a new tensioner arm for that alternator coming. custom made. i made the mk1 work, and i dont thing he got my PM that i didnt need it anymore. so im just going to swap it out for the one he made after i powder coat it. i plan on pulling tons of parts off the car and coating them black to prevent rust and for easy clean up. perks of having your own equipment
#52
1/6 - new console came today. the window switches will get pulled out until i have time to swap the car to electric windows, or ill put gauges in there instead. not sure what im going to do yet. pulled the cruise control controller already to sell
#53
1/10 - today my single round support, rear door, fender flares, door trim, side skirts, custom alternator bracket, door handles, door latch mechs, under dash trays, brake lines, injection lines, antenna, fender badges, shifter alignment tool, and weighted shift linkage came in
im going to powder these black before i put them on the car
#54
coilovers came today...weeks after buying them (12/14) they showed up blown/seized/missing parts. seller gave me all kinds of crap telling me that its used and i should have expected it, and that i was lucky he sent me even one of the spanner wrenches. not to mention i was missing 6 other pieces and they were broken....
#55
tomorrow im going to start shooting powder on some parts/brackets ill be pulling off the car. mostly as a preventative thing against rust, plus satin black looks pretty
#56
1/11 didnt do a whole bunch today, bought a media blaster for parts cleanup, and powder coated my alternator bracket
#57
1/12 - missing linkz shifter came in today im going to blast it tomorrow and powder coat gloss black. i put in my mk3 weighted rod mostly because i was curious as to how the difference felt. it looks like its a tiny bit shorter than the oem mk2 one, about 1/8" shorter?
i think ill do the relay lever while im in there as well. or i may just wait until i order my bushing kit and then do it all at once?
#58
Nice cheap upgradeI did the same to mine. I just used my existing bushings tho.
#59
#60
1/13 pulled the alternator to put the new powdered black alternator bracket in. also i powdered the short shifter black. i plan to use some lengths of square tubing so i can powder the heads of bolts (like the one on the short shifter bracket) so the will match. all this black is temporary for now. when i do the engine swap this summer ill be doing a completely different color pattern. i just want to protect the parts against rust. damage since i know i will be selling most parts later on. i suppose in the event that my engine swap does not go through til next year my engine bay will still look cleaner all black than rust covered. when my sand blaster gets here ill be blasting and painting all the larger parts (parts i cant fit in my oven)
#61
Nice work,
Hey I'm thinking of getting a powder coating sys. also.
This what you are using ? ( Eastwood )
http://www.ebay.com/itm/NEW-Eastwood...item35b8897b85
#62
#63
Thanks for the tip !
We have a good sized sand blaster but was unsure about the rest,
thanks much for turning us on all on to this, all good !
Here is my man for hard to find diesel parts,
you can email him his name is Dominic :
http://www.dmfdiesel.com/index.php?lang=en
#64
#65
Mine has over 400k on itAnd yes I do live in an igloo I mean Canada.
#66
no more coils for me, bought a new bigger powder oven today! feel free to contact me if you need anything done!
#67
FS - OZ M-191 Center Cap - http://forums.vwvortex.com/showthrea...5#post77384355
Diesel Dub Club #38 || Euro Style || MK2 Militia ||
#68
#69
#70
All of themAnd if anything I hope to get a powdercoating gun to coat smaller things like valve covers, brake calipers, brackets etc.
