Results 1 to 16 of 16
Thread: 04 1.8t gli / boosting issues please feel free to help
  1. 12-28-2011 09:08 AM #1
    I buddy of mine has a 04 GLI 1.8T and has been having some issues for a month or so, I scanned his car and came up with the following codes. I have replaced the N75 valve, boost sensor, installed a samco turbo inlet boot, new front O2 sensor. I don't want him to keep throwing money into this but is there any test that can be done to determine if the MAF is causing his car not to boost past 0 It's getting annoying, it's either the MAF or Wastegate. I am open to all suggestions.
    Thanks
    10 Faults Found:
    16622 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 35-10 - Signal too High - Intermittent
    16804 - Catalyst System; Bank 1
    P0420 - 35-10 - Efficiency Below Threshold - Intermittent
    17544 - Fuel Trim: Bank 1 (Add)
    P1136 - 35-10 - System too Lean - Intermittent
    16555 - Fuel Trim; Bank 1
    P0171 - 35-10 - System Too Lean - Intermittent
    16517 - Oxygen (Lambda) Sensor B1 S1
    P0133 - 35-00 - Response too Slow
    16795 - Secondary Air Injection System
    P0411 - 35-00 - Incorrect Flow Detected
    18613 - Performance Malfunction in Cooling System
    P2181 - 35-10 - - Intermittent
    17956 - Boost Pressure Regulation Valve (N75)
    P1548 - 35-10 - Open Circuit - Intermittent
    16485 - Mass Air Flow Sensor (G70)
    P0101 - 35-10 - Implausible Signal - Intermittent
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-10 - Performance too Low - Intermittent
    Readiness: 0000 0001
  2. Semi-n00b
    Apr 17th, 2011
    Tunkhannock, PA
    2002 VW Jetta 1.8T
    12-31-2011 10:11 AM #2
    From what I can tell it seems like you might have a vacuum leak. Have you tried doing a leak test? I think the reason you're getting all the inefficiency codes is because the engine is sensing extra air that it hasn't found when going through the MAF. Check out this link http://www.audizine.com/forum/showth...st-Leak-Tester Also if you have access to a smoke machine it will also help in visually showing you where the leaks are. When I first bought my car I had a HUGE leak in the PCV lines under the intake manifold, 3 mins of letting the smoke machine run and saw it pouring out from under the intake.
  3. 01-01-2012 07:23 PM #3
    Complete Auto-scan please.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  4. 01-01-2012 11:16 PM #4
    I will post the entire scan tomorrow. But so far I've replaced the MAF / N75 / boost sensor @ turbo Inlet pipe. I've performed many leak test and everything isn't air tight. My thought either ECU / Throttle Body or wastegate. Car has decent power but won't budge past 0 psi .
    Please help
    Thanks
  5. Member Josein06GLI's Avatar
    Jun 28th, 2008
    San Diego, Ca
    2012 Audi A4, 2006 VW Jetta GLI, 1989 MK2 GTI 16v
    01-01-2012 11:23 PM #5
    Are u getting vacuum? Check boost gauge and taps for gauge. EVO and intercooler piping.
    2006 BMP VW JETTA GLI DSG some coils, some bolt ons and some wheels.
    1989 VW GTI 2.0 16v some coils, some bolt ons, and some wheels.
    2012 Audi all stock, its hers. she dont want me messing with it...yet.
  6. 01-02-2012 10:01 PM #6
    Tuesday,20,December,2011,16:24:01:09916
    VCDS Version: Release 11.11.0 (x64)
    Data version: 20111111
    Chassis Type: 9M - VW Jetta IV
    Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
    75 76
    VIN: 3VWSE69M54M145053 Mileage: 132560km/82368miles
    Address 01: Engine Labels: 06A-906-032-AWP.lbl
    Part No: 06A 906 032 SM
    Component: 1.8L R4/5VT G 0030
    Coding: 07510
    Shop #: WSC 12338
    VCID: 7BFB396369FE7F6
    3VWSE69M54M145053 VWZ7Z0D9544986
    10 Faults Found:
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 00066 000 00000
    VCID: 3469D25F542070E
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: 04 AIRBAG VW61 0202 0001
    Coding: 12340
    Shop #: WSC 00066
    VCID: 27533513C5F60B6
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J5 920 926 H
    Component: KOMBI+WEGFAHRSP VDO V56
    Coding: 05230
    Shop #: WSC 00000
    VCID: 3469D25F042070E
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00066
    VCID: F0E19E4FB0B88CE
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 1H Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 00066
    VCID: 3773E55315569B6
    Subsystem 1 - Part No: 1C1959801A
    Component: 1H Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C1959802A
    Component: 1H Tõrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811A
    Component: 1H Tõrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812A
    Component: 1H Tõrsteuer.HR KLO 0202
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180 G
    Component: RADIO 3CP 0007
    Coding: 00031
    Shop #: WSC 00066
    VCID: 2449221FB4C0E0E
    End ---------------------------------------------------------------------
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 46: DTCs cleared
    Address 56: DTCs cleared
  7. 01-03-2012 08:35 PM #7
    Seems to me an over boost condition probably due to incorrect hose hookup.
    Verify as per the repair manual and verify with logs in VCDS after codes cleared.
    0x01-02-05
    0x01-08-115
  8. 01-03-2012 10:03 PM #8
    I will check all connections tomorrow thanks for the feedback, I even tried capping of the N75 valve port leading to the waste gate to see if the waste gate was bad. Could it be the B1 S1 O2 sensor, how well do the aged test predict bad sensors?
    Thanks
  9. 01-03-2012 11:12 PM #9
    Keep this in mind.
    Boost is used to open the waste gate not vacuum. Your current thought process is ass back-wards.
    It is switched via the N75 to hold the waste gate shut to gain boost.
    If unplugged, it will go to full on boost, then limp mode, due to a 200 MBAR deviation seen by the ecu at the map sensor as a protection mechanism.
    Hence, the over boost DTC.
    The limitation of the DTC, is every terminal 15 key cycle, or cleared DTC memory until deviation seen again.
  10. 01-08-2012 12:39 PM #10
    Im having a similar problem, no boost what so ever, and ive replaced maf,n75,n249,turbo, dv, spark plugs,coil packs,
    Have you figured out what the problem was?
    Im still getting 21hg vaccuum so im pretty sure i dont have a vac leak
  11. Banned bodya2004's Avatar
    Feb 21st, 2009
    Philadelphia Pa
    1998 Gti (sold) 2001 Gsr (sold) 1998 Jetta Gt (sold) 1990 Audi 80 2004.5 GLI (Sold) 2001 225ttg
    01-10-2012 11:29 PM #11
    does the car jurk or hesitate when about to go into boost?
  12. 01-11-2012 11:20 AM #12
    NO SOLUTIONS YET
    I just got back from vacation today and I will run a few VAG checks. I want to run a O2 sensor aging test to see if my B1 S1 is shot. But it doesn't run rough, it does hesitate to budge past "0" psi
  13. Forum Sponsor Santos@Ross-Tech.com's Avatar
    Feb 16th, 2007
    Willow Grove,PA
    2004 Passat Wagon 1.8t, 4motion, manual
    01-11-2012 11:41 AM #13
    Is your car chipped? Some of the tuners will delete o2 sensors and prevent some of the tests from running.
    VCDS Diagnostic System For VW/AUDI/SEAT/Skoda/Bentley
    www.Ross-Tech.com
  14. 01-16-2012 06:37 PM #14
    OK, I FOUND MY SOLUTION
    Check your exhaust, your CAT might be clogged like mines was..
    CHECK THIS OUT
    No wonder car made 0psi.
    SORRY for the large a$$ pictures.. dont know how to resize
  15. 01-16-2012 08:16 PM #15
    This is a result of an underlined condition.
    False air.
    Bad MAF
    Lean condition.
    Over boost condition!
    You better sort that out or its gonna get expensive.
    Always remember Cause + Effect or Effect again!
  16. Banned bodya2004's Avatar
    Feb 21st, 2009
    Philadelphia Pa
    01-17-2012 11:36 AM #16
    what to look into changed maf no leaks boost/vacum
