Closed Thread
Page 27 of 64 FirstFirst ... 17 23 24 25 26 27 28 29 30 31 37 ... LastLast
Results 911 to 945 of 2220
Thread: The Progress Thread 2012
  1. Member quiksilver6's Avatar
    May 8th, 2007
    Grand Haven, MI
    05-30-2012 10:59 AM #911
    Ok.. Yeah I was never told I had it, only checking to see next week.
    But ur case, if you have an abdominal injury, it's obviously tight in ur whole Ab area I'm sure, which is directly connected to ur hip flexors obviously. Ur hip flexors if very tight, would pull your femoral head harder than normal back into your pelvic gurdle where the impingement would take place. I guess it would be tough to foam roll your Hip Flxrs and avoid stretching your abs tho.
  2. Member kryptonik's Avatar
    Apr 26th, 2003
    Salt Lake City, UT
    05-30-2012 11:19 AM #912
    Quote Originally Posted by Rob Cote View Post
    Found this place which is pretty much in between work and home. It means probably driving to work (rather than taking the train) when I want to lift but it might be legit. I dig the college gym idea, I hadn't thought of that. I guess I just assumed you have to be a student to use the facility.
    Your unis may differ, but most have a fee you can pay to use it. It wouldn't hurt to check out. And, at least pertaining to me, the gym is "run" by students, so they are pretty lax on their rules. Which for chalk use, etc. is pretty solid.
    Quote Originally Posted by quiksilver6 View Post
    Yeah, I just started pulling/squatting recently. Not quite as heavy as I was, but, it's getting back there. I have to agree with the injury being responsible for the tightness. If I lift, the area feels better the next day. Sitting at work, makes it worse. It's a **** road to be on currently, but, I suppose it's part of the game.
  3. Member vwbrvr6's Avatar
    Jul 30th, 2002
    Boca Raton, FL
    '12 VW Passat 2.5 SE, '09 Honda Civic
    05-30-2012 12:16 PM #913
    I took 4 weeks off from dead lifting and just did some last night and I was exactly where I left off. Which is weird, cuz if I were to take 4 weeks off of my bench it would be like starting over from day one.
    VW's from my past.
    1986 Scirocco 16v, 1998 Jetta GLX Vr6, 2002 Passat 1.8t, 2005 Passat 1.8t, 2009 Passat 2.0t.
  4. 05-30-2012 02:15 PM #914
    more "progress"
    today i carried 550 pounds of plates up my stairs and out into the garage... a month ago i couldnt carry a laundry basket up the stairs so this is a massive improvement. unfortunately my knee already feels a little sore but whatever, i ****ing made it -- without a brace this time.
    going to start back on the exercise bike tomorrow and hopefully i can be doing bodyweight squats within a couple weeks.
  5. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    05-30-2012 02:44 PM #915
    Quote Originally Posted by tweezy! View Post
    more "progress"
    Holy **** dude...what?!? Not sure if typo...
    When i'm lookin' to get er to spread 'em I usually just throw copious amounts of alcohol at the situation.
  6. Member ultimate steve's Avatar
    Apr 17th, 2003
    west islip NY
    MKVI GTI, carbon steel gray, manual, sunroof/nav
    05-30-2012 02:47 PM #916
    I don't think he meant all at once
    Sent from my iPhone using Fapatalk
  7. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    05-30-2012 02:50 PM #917
    Quote Originally Posted by ultimate steve View Post
    Hahaha even still, what the christ is he eating off that much plate?!
  8. Member ultimate steve's Avatar
    Apr 17th, 2003
    west islip NY
    05-30-2012 03:52 PM #918
    Maybe he runs a catering company from His house how the f*** should I know haha
  9. 05-31-2012 02:48 AM #919
    what the **** is going on in here?
  10. Member ultimate steve's Avatar
    Apr 17th, 2003
    west islip NY
    05-31-2012 10:28 AM #920
    You tell us
  11. Member .Mad Hatter.'s Avatar
    Oct 18th, 2007
    Toronto
    20Vs
    05-31-2012 10:37 AM #921
    Weight plates...
    #notsureiftrolling
    Quote Originally Posted by futur View Post
    who is fastest? if you guys didn't find out, what were you doing instead? patching floors? #mk3 #lulz # POR15 #umadbro #supercharger #thatsalottospendforjust8psi #justthetip #justkidding #noimnot
    podi.ca
    Scraped.Crusaders. l the.final.offset l flickr
  12. Member scandalous_cynce's Avatar
    Oct 28th, 2007
    Vancouver, WA
    MK4 Jetta - '07 Audi A3 (SOLD)
    06-01-2012 11:58 AM #922
    Trying tonight for a 2x body weight dead lift!
    I'm 5'4" and ~128 lbs right now so that would be a 260 lb lift. I'm excited!
    Last week I weighed in at 126 lbs and pulled 205x5 so fingers crossed!
    EDIT: Failed. Stuck at 225 lbs.
    Follow me on Instagram: cyncetastic
  13. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    06-01-2012 12:04 PM #923
    Quote Originally Posted by scandalous_cynce View Post
    Good god! I think a 2x BW pull is a long way off for me
  14. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    06-01-2012 08:37 PM #924
    I did manage to 3x3 365 today. Even got one extra on the last set it felt very clean. It's amazing what proper sleep and mental focus will do for your lifts.
  15. Member ultimate steve's Avatar
    Apr 17th, 2003
    west islip NY
    06-02-2012 12:15 AM #925
    My dl has been stuck at 315 forever.
  16. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    06-02-2012 06:00 AM #926
    Do something about it. Is that a single rep max or a working set? If you're doing sets with it, try taking out a couple reps and bumping up the weight. I found that by doing that it really helped to overcome a mental barrier that was holding me back. Also I once was deadlifting and I don't know if it was real or not, but I suddenly was convinced I hadn't eaten enough food, that I literally didn't have it in me to complete the set. Try eating a bit more before you lift (but I dunno what your diet looks like, so maybe this isn't an option).
  17. Member ultimate steve's Avatar
    Apr 17th, 2003
    west islip NY
    06-02-2012 10:17 AM #927
    315 is a max and it feels like **** every time haha. I haven't done them in a while since I finished the strong lifts 5x5. But my last working set in that program was 295x5. My pre workout meal is usually half cup of oats in milk w/honey and 2-3 eggs, and some fruit. Not a whole lot of food but enough I think without feeling too full. I might have to put on some weight to get over that hump though I think. But it'll have to wait till after summer. Right now 315 is over double body weight. I'm down to fighting weight 148 @5'7.
  18. 06-04-2012 10:53 AM #928
    I saw a woman piss herself on the platform during a deadlift at a meet yesterday.
    In other news I'm down 13lbs in 8 weeks. Only 33 more to go
    www.TheDaintyBoys.com
    www.youtube.com/RumblerProductions
    Quote Originally Posted by pops View Post
    hey, who do I have to insult around here to get a PM?
  19. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    06-04-2012 11:14 AM #929
    Slight change of pace, I bagged 2 4000 footers yesterday Mt. Hancock and South Hancock. ~10 miles hike, ~ 6 hours and change. I'm beat, but it feels awesome.
  20. Member XiaoNio's Avatar
    Nov 22nd, 2005
    MD
    07 MCS, 09 Street Triple
    06-04-2012 09:29 PM #930
    Well, first progress in a bit. I've been slowly getting the strength/weight back that I lost following getting my teeth pulled out and not being able to work out/eat for a month.
    Finished Sheiko 29 adjusted for push press instead of benching. Back squatted 170 kg (375 lbs) which matches my pre-op PR. Push pressed 105 kg (231 lbs), which is the first time I've tested it in 2 years. Weighed in at 75 kg (165 lbs).
    Not sure if I'll do another Sheiko. It feels like a ton of volume but not a lot of work. Maybe that's the trick, that every weight feels kind of easy. The cycle capped at 80% for 6x3. Before when I was progressive overloading, I was doing 90% for 5x3, so I have a hard time imagining that I wasn't growing more with that.
    Anyway, next up is an 8 week cycle of Westside 4 Skinny Bastards to put on a few pounds while I'm traveling to other bases.
  21. 06-04-2012 10:45 PM #931
    diet is going GREAT!
    been doing 25-30 minutes of walking cardio 3-4 times a week.
    eating lots of salad, LOW carbs.
    started the tren and winny, def looking lean and veiny. Got about 6 weeks left until vegas. I'll post pictures in another week or so, hopefully I'll have this years speedos by then
  22. Member leakypipeDCI's Avatar
    Dec 21st, 2004
    The BL, WA
    06-04-2012 11:11 PM #932
    By diet you mean cycle, right?
    It's all about squats and deads.
  23. Member Chilledman's Avatar
    Jul 14th, 2010
    USA
    06-05-2012 09:51 AM #933
    Quote Originally Posted by ::xander:: View Post
    OMG its the fat chick diet
  24. Member Residentevol's Avatar
    Sep 19th, 2000
    Spangdahlem, Germany
    2009 UG GTI on bagzzz
    06-05-2012 09:52 AM #934
    ****ty excuse time...but I had to take nearly 4 weeks off from the gym to do some travelling with family in Europe. Before they came over to Europe I had to take a PT test (military) so I had taken the week prior to that off as well as to have no injuries or soreness.
    Went back to the gym yesterday and felt super rusty. I ended up cutting a lot of weight back to get my form straight again. I was squatting about 205 for 5x5 and I cut it all the way back to 135 yesterday (same w/ bench) I'll just go back to adding 5lb a workout until I get back there I guess.
  25. Member kryptonik's Avatar
    Apr 26th, 2003
    Salt Lake City, UT
    06-05-2012 10:25 AM #935
    Traveling in Europe with the family is not a ****ty excuse to not be in the gym.
    I'd give up a month of lifting to see the world with my family for sure.
  26. Member Residentevol's Avatar
    Sep 19th, 2000
    06-05-2012 11:07 AM #936
    Truth I was just being a smartass ..I live here and they were coming to visit from Florida hadn't seen them in years and my 2 year old son needs to know his grandmother/aunt even if for short visits. If we had stayed in the local area I would have kept up the routine but we were in Paris/Rome/Germany/Belgium so it was a busy trip
    Sidenote. I am sore as shyt today from yesterdays workout. Even at those low weights it brought the pain funny enough I've found the best way to make the soreness go away is to lift more weights..Is that normal?
  27. 06-05-2012 12:50 PM #937
    today's a big day
    squatting with the bar, deadlifting up to 135
    my knee feels rock solid for the first time since february and its time to man up. i honestly don't even know if i'll have the flexibility and/or lower lumbar strength to maintain a reasonable form even under 0 load... but i don't care. here goes nothing.
  28. 06-05-2012 02:46 PM #938
    Quote Originally Posted by leakypipeDCI View Post
    fact: you are what you eat, regardless of gear.
    my diet is in check, and my cycle is a NASTY combo that should make me look SOLID, veiny, and shredded, providing my diet is in check.
  29. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    2003 Silverstone Grey 2.9L 24v twin turbo VR6, 2002 S6 Avant
    06-05-2012 02:50 PM #939
    Back to the gym finally since my back surgery two years ago... I took a little bit too much time off.
    Driversport|| Valley Dubs PM me for all your Fragola Fittings and Billy Boat Exhaust Needs!!!
    The Elite 24v VR6 Club: Member #4
    My Build Thread
  30. Member kryptonik's Avatar
    Apr 26th, 2003
    Salt Lake City, UT
    06-05-2012 04:21 PM #940
    Doing deads today. Not totally sure what I'll pull. My abs are feeling much much better. Not 100% yet, but much better. Going to do 315 3x5 at minimum. Hopefully a bit more, but I don't want to push it quite yet.
    Cleaned up my diet quite a bit, and lowered my calories down a decent notch. Never really tried to cut weight before, but, I have a goal of having some kind of abs by august. I am going on a vacation with friends and family, and want to look as good as possible by then. So far I've dropped ~3 pounds. First time in a long time I've seen the scale dip down, and stay below 192.
    edit: pulled 325 3x5. not too difficult. killed my upper back with rows and pull ups. feeling them today big time. for my diet, I lowered my carbs quite a bit, and definitely feel like I run out of steam faster in the gym. my strength isn't going away, I just get tired faster. Hoping this stops once I get used to the deficit.
  31. 06-06-2012 11:39 AM #941
    really fuzzy pic. Looking solid in person. Loving it
  32. Member leakypipeDCI's Avatar
    Dec 21st, 2004
    The BL, WA
    06-06-2012 11:46 AM #942
    Quote Originally Posted by Mr. Rictus View Post
    Welcome back!
  33. Member kryptonik's Avatar
    Apr 26th, 2003
    Salt Lake City, UT
    06-06-2012 12:28 PM #943
    looking good.
    why not take a photo with the regular iphone camera versus instagram or whatever? the regular camera on that thing should take crystal clear photos I'd believe.
  34. 06-06-2012 01:09 PM #944
    failure is not an option, it is mandatory
    Keep trying!
    and for those of you who use the foam roller before you get under the bar, what do you do? and how long do you do it? I did about ten minutes on the bike because i've been told it helps loosen up your synovial fluid, and then rolled out my IT bands, hammys, calves, and did some squat to stands
    I've been trying to actually warm up and honestly I need to educate myself I feel like the more prepared I am the better my workout is. Really my major goal would be to workout the issue with my knees cracking, I'm wondering how major of a roll mobility plays in this
  35. 06-06-2012 01:44 PM #945
    Quote Originally Posted by kryptonik View Post
    looking good.
Closed Thread
