VWVortex.com - GTI + Baseball bat = Big build thread
    Page 5 of 11 FirstFirst 123456789 ... LastLast
    Results 101 to 125 of 271
    Thread: GTI + Baseball bat = Big build thread
    1. Member Cortexiphan's Avatar
      Mar 1st, 2010
      South East, Mi
      Golf R
      02-15-2012 11:21 PM #101
      Wow man. Im super impressed.
      This car definitely got the right owner.
      Definitely going to be watching this build
    2. Member francis2's Avatar
      Oct 29th, 2011
      Montreal, QC
      Golf TDi
      02-15-2012 11:47 PM #102
      cant wait for more and for a canadien
    3. 02-16-2012 12:03 AM #103
      Subscribed
      Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
    4. Member Hecktür's Avatar
      Jul 13th, 2011
      STL
      Turbo
      02-16-2012 12:12 AM #104
    5. Member 18t papa's Avatar
      Dec 28th, 2009
      Orange County, NY
      '91 Passat 16V Variant, MK3 Supra Turbo, 1977 Jawa 350
      02-16-2012 01:13 AM #105
      I thought that thing was beyond beat but you seem to be bringing it back nicely, looks good so far.
      Long live the SCüMWAGON!
      IG: @captain_scum
    6. Member
      Apr 27th, 2010
      Mass
      02-16-2012 09:08 AM #106
      I love that you're restoring this And the 500r looks great! I had a lot of fun with one of those as my first bike. I loved that thing.
    7. Junior Member nicelydone's Avatar
      May 13th, 2011
      Kitchener ON
      Bagged '01 Jetta 1.8T Wolfsburg
      02-16-2012 09:25 AM #107
      awesome work. keep it up.
    8. n00b
      Jan 19th, 2012
      Maine
      03 GTI VR6
      02-16-2012 10:56 AM #108
      Can't wait to see more! Keep up the great work man. After seeing your bodywork, I'm excited to see your skill on the interior as well
    9. Junior Member
      Oct 14th, 2005
      Saskatoon, Sk
      2001 GTI 1.8T
      03-08-2012 10:25 PM #109
      Soooo....Its been a while.....
      Still making progress, just the boring kind that nobody gives a sh*t about. Except me of course. I finished filling in the rub strip holes, and have been blocksanding the doors and hatch in my spare time over the last few weeks. Its such a crappy process because someone has already repaired each of the doors (poorly) so I took them right down and started fresh. They are so damned close to being straight as an arrow, but the last bit of blocking is killing me. It goes like this... Prime with high build primer -> Cure for a day -> Guide coat -> block sand until guide coat is removed -> prime again -> repeat. One more round of blocking then its on to the shell of the car.
      I've also been hunting for a front grille that was nice, wouldn't sag, and wasn't a TON of money. Trying to stay budget conscious here. I ended up "settling" on building my own badgeless grille. There is a how-to floating around here that gave me the idea. I got a second grille from a local guy, and patched the two together. One key thing I did that isn't pictured is when I put the sections in from the donor grille, I kept a locking tab in the middle section of both the plastic grille backer, and the fin. It will keep everything locked in perfectly, and most importantly, straight. When this thing is done it will look like vw made it! Only about 45 mins worth of work into it when the pics were taken. Its put together using a flexible 2 part plastic epoxy, and CA glue to tack everything in place before the epoxy goes down.
      More pics to come when more significant progress is made! Thinking that I will leave the doors and hatch as they are for now and start fixing some metal on the car (i'm so tired of blocking primer).
    10. Member Miller7204's Avatar
      Jul 25th, 2011
      Upstate New York
      2004 Jetta GLS 2.0L R.I.P. - 2002 Jetta GLS 2.0L
      03-08-2012 10:29 PM #110
      Can't wait to see this finished
    11. Junior Member
      Oct 14th, 2005
      Saskatoon, Sk
      2001 GTI 1.8T
      03-08-2012 10:32 PM #111
      Quote Originally Posted by Miller7204 View Post
      You and me both....
    12. Member LanceeH's Avatar
      Oct 1st, 2011
      Calgary
      2003 2.0T Jetta, 2003 24v VR6 GLI
      03-19-2012 10:43 PM #112
      More updates!!
    13. Junior Member dub_tdi's Avatar
      Sep 7th, 2011
      Birmingham, Al
      MK4 TDI Golf, 2015 Subaru WRX
      03-19-2012 10:48 PM #113
      [QUOTE=sejamis;76315619]Soooo....Its been a while.....
      nice work. look like you know your ****. i would just block the doors on the car. it sucks to do but you get a great smooth showroom finish
    14. Member DieselDubber's Avatar
      Feb 11th, 2011
      Irvine, CA
      2003 Jetta TDI
      03-19-2012 10:50 PM #114
      that color is going to look amazing
    15. Member tylerfisher's Avatar
      Apr 11th, 2011
      jersey
      bagged mkiv golf- SOLD bagged mkv jetta
      03-19-2012 10:55 PM #115
      love seeing threads with mass amounts of actual body work
    16. Junior Member
      Oct 14th, 2005
      Saskatoon, Sk
      2001 GTI 1.8T
      03-28-2012 10:56 PM #116
      Started working on the shell of the car. Biggest repair which was the quarter, is done. Just some shaping of the wheel arch and the overall shape of the panel to tweak, and its ready to go. Roof has also been repaired, but I have to find a new sunroof assembly and test fit it before I can call it finished. The sunroof opening is pushed down in one corner and its giving me issues with the way the glass sits. Still have to tweak the drip rail area on the passenger side, but its close. Finding OEM fenders is turning out to be a pain in the ass. Got my hands on a red drivers fender that needs a little love, and still hunting for a passenger. I have aftermarket china replacements, but opted to use OEM instead. Trying to line up an aftermarket hood, fenders and front bumper is not my idea of a good time.
      Other side of the car is pretty much done. Welded shut the trim holes then prepped and primed the drivers side of the car. Having do minimal body work on at least one panel was nice .
      I'm slowly picking away at things, but it's coming. School/Finals are over by the 19th of April and I have 10 days off between that and the start of my summer employment, so the goal is to have everything in its final coat of primer and ready for wetsanding by then. I'll post more as I progress.
    17. Member builtvw's Avatar
      Sep 19th, 2009
      coopersburg
      windsor 2.0, ginster 1.8t
      03-28-2012 11:04 PM #117
      looking good man
      Quote Originally Posted by ZACHER3tuning View Post
      only on vortex, could this turn into a argument.
      http://forums.vwvortex.com/showthrea...Project-molest
    18. Member joedubbs's Avatar
      Nov 1st, 2004
      07 Camfollower
      03-28-2012 11:09 PM #118
      great work, it's so awesome you saved this with skills... wish I had skills
    19. Member bunny_luv'R's Avatar
      Mar 12th, 2009
      Cigar City,FL
      Bagged 24v
      03-28-2012 11:18 PM #119
      Quote Originally Posted by joedubbs View Post
      he doesnt have skills.....he has SK1LLZZZZZZ!!!!!!!!
      great job man.
      you deserve a couple 's and 's.
      cant wait to see the outcome.
      OEM USDM
    20. Junior Member
      Oct 14th, 2005
      Saskatoon, Sk
      2001 GTI 1.8T
      03-29-2012 06:35 PM #120
      Junkyard win today. Went out to a local wrecker to grab some stuff, found a votex spoiler. Corner is cracked and will need to be repaired, but for $50 i'm not complaining.
    21. Member Jake2k's Avatar
      Nov 24th, 2010
      Somewhere in Florida
      Bagged, 2.Slow, 4 Door, 6 Speed Golf and a 2010 TDi JSW w/DSG
      03-29-2012 06:43 PM #121
      Looking great man
    22. Member Marijnz's Avatar
      Apr 9th, 2010
      Belgium
      VW Bora
      03-29-2012 06:44 PM #122
      nice work!!! can't wait to see the outcome.
    23. Member R32R1's Avatar
      Jul 1st, 2008
      South County, RI
      project roided wookie
      03-29-2012 06:46 PM #123
      Didn't read many previous posts but somebody had a crazy ex gf lol
      The Build Thread CTS Turbo SoCalStance Shop
      Window Tinter (RI Area)- #meatheadwindowtinting
      RIP Alexi
    24. 03-29-2012 06:58 PM #124
      looks good !
    25. Member n00bsauce's Avatar
      Feb 12th, 2012
      CT
      '03 Jetta Wolfsburg
      03-29-2012 07:16 PM #125
      Quote Originally Posted by sejamis View Post
      im going to be doing the same thing to my jetta. trying to find a second grille
