Results 1 to 11 of 11
Thread: STOP>Brake Fault>Service Manual!!
  1. Member Das Auto1.8T's Avatar
    May 5th, 2011
    Minneapolis
    Past-2000 Jeep Grand Cherokee Laredo. Current-2004 Passat 1.8T
    01-02-2012 02:24 AM #1
    My ecu keeps telling me that I need to stop driving because I have a brake fault. However my brakes work perfectly fine. It happens every so often, but lately I've noticed it happening ALL THE TIME, and its really annoying, it happens most when I am taking a turn, so Im not sure if its some short circuit or if something near my brakes is touching something it shouldn't and setting it off, really I have no idea. I haven't been able to scan it because the cable I have access to works on PC not a MAC. But if all goes to plan I'll be able to do that tomorrow, but I was trying to get any insight if I could now.
    Thanks,
    Das Auto1.8T
  2. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    01-02-2012 07:10 AM #2
    If it comes on while turning, you most likely have low brake fluid. These cars are very sensitive to that; turning causes the sensor float to dip a little. If so, top it up and very carefully watch it for a while to see if it drops again. You don't normally "use" brake fluid, and if it's leaking that can be a dangerous problem.
    Beyond that, get it scanned...
  3. Member ColoradoBob's Avatar
    May 5th, 2000
    2005 A4 quattro, 1999 A4 quattro, 2001 A4 quattro, 2001 VW Passat
    01-02-2012 10:35 AM #3
    Sounds like a failing ABS module. Mine did the same thing and eventually the warning was on most the time. Get the module repaired (and the common failure point fixed). I had mine repaired by cheapabs.com. Works great now.
  4. Member Das Auto1.8T's Avatar
    May 5th, 2011
    Minneapolis
    01-02-2012 09:41 PM #4
    Quote Originally Posted by scotts13 View Post
    Wasn't able to get it scanned today, but the brake fluid was low, so i filled it to the appropriate level and the brake fault doesn't come on anymore.
  5. Member Mk1Racer's Avatar
    Apr 16th, 1999
    NJ
    '99 B5 wagon (RIP), '01 B5.5 wagon, '81 Scirocco, '04 FXDWG
    01-03-2012 04:39 AM #5
    Quote Originally Posted by Das Auto1.8T View Post
    Brake fluid is not a consumable fluid, there is no reason to top it it. If it's low, that's probably a good indication that your brakes are pretty worn and the pistons in the calipers are extended. If not, it means that you've got a leak someplace that needs to be fixed.
    And now, when you actually do get around to doing the brakes, and you push the pistons back into the calipers, the brake fluid reservoir will most likely overflow, dumping brake fluid into your engine bay. Have you ever seen what happens when you get brake fluid on painted items?
  6. Member Das Auto1.8T's Avatar
    May 5th, 2011
    Minneapolis
    01-03-2012 07:01 PM #6
    Quote Originally Posted by Mk1Racer View Post
    I know its not a consumable fluid and that you should really never have to top it off if everything is working. But I recently did my brakes and a caliper not to long ago, maybe have driving 8-10k on them. I put in really so little amount of brake fluid and my fault stopped, and every time I park somewhere for awhile, when I leave I check for any spills. But you're right I shouldn't take chances, so definitely going to take it to the shop. But thanks for the info, it helped!
  7. Member nolesfan's Avatar
    Mar 9th, 2011
    Raleigh, NC
    2004 Passat
    01-04-2012 12:11 PM #7
    If you have some basic hand tools, you shouldn't have to take it to a shop. Brakes are one of the generally simple things to work on with these cars. Monitor the potential leak for a few days to a week. If no fault warning, then you should be good as far as leaks. Check the inside of your wheels to make sure. You also may want to bleed your lines to make sure there's no air. I'd also take it to Auto Zone or some place similar and have it scanned for codes. Could be ABS module going bad, but won't know yet.....
    Several things could be at play here.
  8. Member Das Auto1.8T's Avatar
    May 5th, 2011
    Minneapolis
    01-04-2012 01:34 PM #8
    Quote Originally Posted by nolesfan View Post
    Thats what i meant by take it to the shop, to get it scanned. I have a metal belly pan and it puts whatever leaks off to the side so sometimes its difficult to tell where its coming from, but thanks for the advice, will post what it is when I find out.
  9. Member Das Auto1.8T's Avatar
    May 5th, 2011
    Minneapolis
    05-18-2012 01:54 AM #9
    Excuse the late post. But believe it or not, I put in the tiniest amount of brake fluid, and the fault has never come back on!
    Watch for dogs.
  10. 05-29-2012 01:33 AM #10
    I have had this problem for months and yet I have full fluid.
  11. Junior Member
    Aug 28th, 2001
    Austin, TX
    '04 B5.5 Variant, '07 B6 Sport
    09-11-2012 11:13 PM #11
    So I had this same problem start yesterday. I grabbed some DOT 4 and filled up the reservoir, but it only took a very small amount of fluid.
    So I fired up the car and pumped the brakes for about 10 seconds, turned it back off then checked it again and the fluid level was under the screen again. Anyway, repeated this process about 6 times and figured I'd put enough in by now. I didn't see any fluid leaking anywhere but I'll have the shop look for next time I take it in.
    -jake
