VWVortex.com - C Notch
    Results 1 to 19 of 19
    Thread: C Notch
    1. Junior Member SPLLANCER's Avatar
      Apr 20th, 2011
      Rock Hill, SC
      06 Passat 2.0T, 04 Ford F150 Heritage
      01-02-2012 06:40 PM #1
      What kind of welder you guys using for notching? MIG, TIG, ARC? If you could use mig can you use flux wire?
      White 2006 Volkswagen Passat 2.0T Auto. Current Mods- 19x8.5 32et Tenzo Concept 9 wheels. JOM Black Badgeless Grille. Nite Shades Tail Lights. Debadged. 30% Tint. Black Painted Roof. Smoked Front Turn Signals. DDM 6K Hids. ECS Billet Oil Filter Housing. Future Mods- Bags (Accuair eLevel). New Wheels (Bored). Color Matched Trim (Hate Chrome).
    2. Member Rat4Life's Avatar
      Oct 13th, 2004
      Fair Lawn, NJ
      lada 2101,rx7,bmw 318i,87 golf gt,93 1.8t two tone,01 flat blue mk4,02 gti 1.8t. 1JZ e21 in works
      01-02-2012 10:58 PM #2
      Quote Originally Posted by SPLLANCER View Post
      i personally use mig,i'm sure you could get away with using gas-less flux wire,just make sure to protect anything that could get melted from all the sparks flying created by flux,like rubber brake lines,bags,boost hoses/pipes.
      http://<a href="http://www.flickr.co.../a>, on Flickr
      Complete air ride installs,frame notching,welding, in north jersey.
      http://www.flickr.com/photos/rat4life/
      roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
      follow me on instagram RAT4LIFE
    3. Junior Member SPLLANCER's Avatar
      Apr 20th, 2011
      Rock Hill, SC
      01-03-2012 12:52 AM #3
      Cool, thanks a lot for the reply. Do you use a plasma cutter or a grinding wheel?
    4. Member Rat4Life's Avatar
      Oct 13th, 2004
      Fair Lawn, NJ
      01-03-2012 01:10 AM #4
      i use hole saw, 2&1/2"diameter. plasma cutter could be too hot for fuel lines that located very close inside that frame rail
    5. Junior Member SPLLANCER's Avatar
      Apr 20th, 2011
      Rock Hill, SC
      01-03-2012 05:31 PM #5
      Awesome, thanks so much for the replies!
    6. Member prospal's Avatar
      Mar 8th, 2011
      Morris County, NJ
      2011 GTI
      01-11-2012 07:01 PM #6
      So - question about my notch. I keep seeing videos and pics of rolling shots where the car is practically aired out but still drivable. As I begin to near 40psi in the front, you start to hear chattering, metal on metal. If I try to get any lower than that, it begins to like make like a grind noise and I'm afraid to push it any farther without doing damage, so I just air back up. Is my notch too small or is being able to ride that low not possible without further modification?
    7. Senior Member reynolds9000's Avatar
      Oct 16th, 2003
      Huntsville, Alabama
      '95 GLX, '97 GL (VR6)
      01-11-2012 07:45 PM #7
      Your notch might not be big enough to allow for the change in the position of the axle. If that's happening, chances are you are sitting on one of the edges of the notch instead of being centered in it when you air out.
    8. Member prospal's Avatar
      Mar 8th, 2011
      Morris County, NJ
      2011 GTI
      01-11-2012 08:29 PM #8
      You think? I mean, it lays out even and no scraping noises airing up/down at a standstill
    9. Member President Lincoln's Avatar
      Jun 27th, 2005
      Magna
      75 Swallowtail Rabbit, 80 Westmoreland Rabbit - 83, 85 & 91 Jetta - 87 & 03 GTi - 13 Golf R, IE450T
      01-11-2012 09:20 PM #9
      Axle bind. If it sounds like a clicking. I guess fast clicking might sound like grinding. I have no notch but driving even low enough that the axle is rubbing frame, I can feel the cv or axle bind. Might need to mod the cv.
      1966 Beetle - 83 Jetta Deluxe - 87 VR GTi - No. 0242 - 2017 Tiguan (hers)
      Instagram: @lordcaskin
    10. Member Rat4Life's Avatar
      Oct 13th, 2004
      Fair Lawn, NJ
      01-11-2012 10:13 PM #10
      Quote Originally Posted by prospal View Post
      possible that your sway bar links interfere with the axle too,if i remember correctly you have sway bar and bar links right?
    11. Member prospal's Avatar
      Mar 8th, 2011
      Morris County, NJ
      2011 GTI
      01-11-2012 10:40 PM #11
      Quote Originally Posted by Rat4Life View Post
      i was considering this as a possibility, but then wouldn't they interfere when airing out also? something isn't lining up while the car is in motion
    12. Member Rat4Life's Avatar
      Oct 13th, 2004
      Fair Lawn, NJ
      01-11-2012 10:44 PM #12
      yes they probably would still interfere,but it would not make noise because axle is not turning when you just airing out and not rolling,so maybe thats why noise is there only when rolling .
    13. 01-12-2012 07:17 PM #13
      Mig
    14. Senior Member reynolds9000's Avatar
      Oct 16th, 2003
      Huntsville, Alabama
      01-12-2012 08:32 PM #14
      I used a flux core machine, fwiw.
    15. Senior Member reynolds9000's Avatar
      Oct 16th, 2003
      Huntsville, Alabama
      01-12-2012 08:37 PM #15
    16. Member martin13's Avatar
      Apr 20th, 2010
      Calgary Alberta
      MK5 GTI, 73' 280SE
      01-12-2012 09:06 PM #16
      for the extra 1 bolt i probably would have dropped the strut out ^^^
    17. Member President Lincoln's Avatar
      Jun 27th, 2005
      Magna
      01-12-2012 09:23 PM #17
      Quote Originally Posted by martin13 View Post
      Actually three nuts
    18. Member Slamtastic's Avatar
      Jul 24th, 2010
      Calgary, Alberta
      01-12-2012 10:54 PM #18
      Quote Originally Posted by reynolds9000 View Post
      Same here. It's not the prettiest weld, but it's plenty strong.
    19. Senior Member reynolds9000's Avatar
      Oct 16th, 2003
      Huntsville, Alabama
      01-13-2012 08:59 AM #19
      We were really careful to shield the bag and strut from the sparks. It looks like they're flying everywhere in the picture, but the sparks weren't coming anywhere close to the bag.
