Results 1 to 18 of 18
Thread: DIY: R&R Door Handle and Lock Cylinder
  1. Member psst97's Avatar
    Jun 21st, 2006
    Louisville, KY
    2004 Passat TDI, 1997 Passat TDI, 95 Jetta VR, 91 Corrado VR,
    01-03-2012 06:50 PM #1
    Have seen this pop a few times recently so i figured I could post something up. Needed to pull one of mine anyway. If you have anything to add or correct, let me know. A few initial pics.
    Fount out why the alarm system didn't work:
    Also found out why the handle would lock but not un-lock:
    Be sure to check this pin to make sure it's still there and not fallen out. Common problem why these handles stop working.
    Tools Needed
    Flat Head Screwdriver
    Phillips Screwdriver
    Handle Removal
    1. Remove Door Card
    2. Unplug Harness
    3. Unscrew Phillips Screw (Driver Side Silver Screw - Counter-Clockwise, Passenger Side Black Screw- Clock-Wise)
    4. Slide Handle Forward
    5. Pull handle out swinging forward
    6. Removal Success!
    Lock Cylinder Replacement
    1. Remove C-clip
    2. Remove Upper Cam Plate and Spring
    3. Remove Lower Cam Plate
    4. Insert Key
    *If no key for cylinder, support back side of handle and lightly tap out with hammer*
    5. Remove Cylinder
    6. Insert New Cylinder
    7. Replace Lower Cam Plate - Align tab with tab on handle
    8. Turn upper Cam Plate upside down
    9. Hook Spring in one side
    10. Bring other hook over tab and hook on the opposite side
    11. Add Cam Plate to assembly aligning its tab with others
    12. Make sure spring is on either side of all 3 tabs
    13. Hold lock cylinder in place and align c-clip
    14. Secure c-clip rest of the way
    15. Done! Make sure you have tension in both directions with the key inserted. If not, you most likely installed the spring on the upper cam place incorrectly.
    Handle Install
    1. Fish Wire Through Hole
    2. Slide front part of handle in
    3. Swing handle into door
    4. Slide Back into place
    5. Tighten Screw (Drivers Side - Clock-wise, Passenger Side - Counter clock-wise)
    6. Attatch Plug and Clip
    7. Re-install Door Card
    Quote Originally Posted by upoo2
    its ok, wheels come and go. But RIMZ are FOREVER
    Quote Originally Posted by dano17
    So they moved the small passat section to fit the abundance of MKIV's that all look the same...
  2. Member perickomx's Avatar
    Nov 13th, 2007
    Tijuana, Mexico
    97 Jetta GLX, 80 Caddy Vr6, 98 Gti VR6 x2
    01-03-2012 08:17 PM #2
    nice write up!!
    was doing this few days ago, not replacing the cylinder but yes, i have not the pin on position anad needs to improve.
    thanks man.
    Westside Mexico: www.westsidemexico.com
    Facebook: https://www.facebook.com/WSMexico
    We all have a secret, at least under the hood!!
  3. Banned ellocolindo's Avatar
    Jan 14th, 2010
    01-03-2012 09:45 PM #3
    The only suggestio to this thread; will be to find a link to the b3 handle repair for the white color plastic thing that wears over time; it contacts the door rod inside the door and works the latch itself.
    It is seen in a few pictures here.
  4. Member
    Oct 23rd, 2006
    San Francisco, CA
    '96 B4V formerly VR6 AT now TDI 5-SPD
    01-03-2012 10:02 PM #4
    Nice write up. Word of warning on aftermarket handles. They worked fine for me but the lock cylinder is not compatible with the original handle. If you don't mind having multiple keys, it's no biggie. If are as anal as me with keys, you may need the services of a locksmith to key alike.
    Besides having different ends, the aftermarket cylinders have single wafers vs. double in the factory handles.
  5. Member x9t's Avatar
    Sep 19th, 2005
    Bay Area-CA
    07 Passat 2.0T 6MT/96 Passat GLX VR6/ 87 Scirocco 16V
    01-05-2012 06:11 AM #5
    I replaced my front door handles and I swapped my Old cylinder lock into them.. I was hard at first because my cylinder lock was so old and the lube was dried.. I had to clean it off with a pick.. relube it and then it went into the aftermarket handle..
    Nice write up.. when I searched.. not one person said anything about unclipping the connector.. or that you had to cut into the insulation to get at it.
    JT
    Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
    Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
  6. Banned
    May 26th, 2005
    o HI o
    84 coupe, 90 b3 td wagon, 81 coupe, BURNT TOAST
    01-05-2012 09:05 AM #6
    well no key and hammer breaks switch.... you MUST HAVE KEY... else do not plan on plugging switch in else it will roll windows down or up for you and screw with the alarm too...
    Oct 23rd, 2006
    San Francisco, CA
    01-05-2012 09:25 AM #7
    Quote Originally Posted by x9t View Post
    JT,
    There is probably more than one brand of aftermarket handle. Bought mine from a fellow in Latvia via eBay. The cylinders have totally different ends. I'm fairly familiar w/ VW locks of that vintage.
    I wanted to add that the U-shaped white plastic bushing/escutcheon (not sure what to call it) visible on the large hole for the handles in pic#9 & #27 must be present for the handle to properly operate. It keeps the large end of the handle from wobbling. I've repaired a few Passat B4 and Jetta Mk3 non-working handle problems by simply replacing that clip. Care should be taken on installing as they are a PITA to fish out of the door once the door cards are in. Don't ask how I know. The ends of the 'U' have a channel intended to hold them to the sheet metal of the door. I find slipping it over the bottom first works best.
  8. Semi-n00b
    Dec 13th, 2011
    Central Wisconsin
    1997 Passat VR6
    01-05-2012 09:20 PM #8
    Quote Originally Posted by psst97 View Post
    Anywhere to get these individually? Or some sort of janky fix? I finally tore apart my driver side door handle and found out why I've had to unlock it from the passenger side.
    Owned the car a month now and if its not one thing it's another so far.
    Oh, and thanks for the write-up.
  9. Member x9t's Avatar
    Sep 19th, 2005
    Bay Area-CA
    01-11-2012 05:15 AM #9
    .. I have my old ones.. you can have them. Just pay shipping?
    JT
  10. Member psst97's Avatar
    Jun 21st, 2006
    Louisville, KY
    01-12-2012 01:01 AM #10
    JT
    There ya go! I dont have any extra peices as all the handles I have are actually good.
  11. Semi-n00b urban tribes's Avatar
    Apr 6th, 2010
    Snoqualmie, WA
    1992 G60 Syncro Passat Wagon
    01-12-2012 03:49 AM #11
    All I have left is to figure out how to get into my locked, shut driver's side door
  12. Semi-n00b
    Dec 13th, 2011
    Central Wisconsin
    1997 Passat VR6
    01-12-2012 01:42 PM #12
    .. I have my old ones.. you can have them. Just pay shipping? JT
    PM inbound
  13. Member B4 Slapshot's Avatar
    Mar 27th, 2008
    '97 Passat GLX
    01-15-2012 12:18 AM #13
    Really Good write up. I replaced mine today with one I bought on GAP. I had to adjust my latch to get it to work and right now I am running a two key set up because being in college I can't afford to keep my car unlocked and unattended for more than a few minutes.
    Favorited for the Future.
    '97 VW Passat GLX
    Mechanical Engineer
  14. Member psst97's Avatar
    Jun 21st, 2006
    Louisville, KY
    01-16-2012 12:14 PM #14
    I ran into a weird issue this weekend. All handles and locks had been working flawlessly. We got our first snow and it got super cold and both front doors locks froze up. Door pin acted like it wanted to pull up but it wasnt happing. I had to jimmy the lock to get into it and once the temp came up above freezing it was fine.
    I have had the latch freeze after being opened so the door wont close but never this. Makes it really difficult to get into the car....
  15. 04-09-2012 06:39 AM #15
    great write up
    I am having problems with the new lock central locking system working
    I changed a whole new handle and swapped the lock cylinder
    my next plan is to just swap the pin over to the old handle
    but now i and can't get the handle out
    has anyone else run into this
    Thanks
    Henrik
    I
  16. Junior Member
    May 27th, 2008
    winchester va
    1983 2.0 GTI 1992 Carat 1997 GLX Wagon
    04-09-2012 08:06 AM #16
    I had the same issue with th central locking trigger breaking off. I bought an entire handle and ran into the issue of my old locl cyl not matching up with the new handle internals. Newer cyl has 7 pins whereas the old cyl had 10. I had to swap my old pins into the new cyl. Starting from the keyhole side of the old cylinder if you ignore the 3rd 6th and 9th pins and then place the rest into the new cyl in order everything comes together pwrfectly. You have to clean the old pins with a toothbrush and some alcohol or they stick from all the crud and lube.
    I am kinda glad I ran into the non fitting issue, now the only thing in my handle that isn't new are the pins.
    I have to do my pass handle this week maybe I'll take some pics of the diff cyl and swapping the pins
    stock 97 GLX wagen........
  17. 04-17-2012 05:22 PM #17
    Excellent How-to
    Just be carefully because your window will break de wires again
    You have to attach the wire inside too ... hard to explain, just look inside. sorry for my bad english
  18. 09-25-2012 07:37 PM #18
    This is awesome. Today the driver's side lock on my '97 stopped unlocking with one turn of the key, but I can still unlock it via vacuum with two turns. Probably the same problem as in the 2nd pic?
    My passenger handle has been fcuk'd for a while, I guess it's time to open up both doors. Anyone have any hints on the best way to source new handles? Thanks!
