VWVortex.com - What did you do to your cabby today?
    Page 2 of 113 FirstFirst 1234561252102 ... LastLast
    Results 26 to 50 of 2812
    Thread: What did you do to your cabby today?
    1. Member oneunder's Avatar
      Mar 31st, 2009
      Minneapolis, MN
      89 Cabby, 01 xit
      01-18-2012 04:38 PM #26
      I dreamt about it and am trying to figure out how to best deal with my rubbing issue I have on the rear passenger side.
      "Those two piece splits are as close to fakes splits as real splits get"
    2. Member Run_That's Avatar
      May 15th, 2009
      Sturgis, MI
      01-19-2012 05:44 PM #27
      - Replaced the glove box door (someone took the padding off?)
      - Installed the knee bar again
      Drove it 100+ miles today on ****ty roads and loving it.
      '91 GTDECO
      Feb 20th, 2011
      Midvale Ut
      83 rabbit convertible 05 4runner
      01-19-2012 10:32 PM #28
      we moved into a new place and now it has a garage
    4. Member
      Jul 3rd, 2011
      Joliet, iL
      99 VW Cabrio MK3, '12 Nissan Rogue (Wifey's)
      01-20-2012 09:33 PM #29
      Drove her in the fresh snow with my son (so no hot rodding or e-brake pulls )
    5. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      01-20-2012 09:39 PM #30
      Not a Dam thing...
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    6. Member sehaare's Avatar
      Aug 4th, 2003
      Palatine, IL. But I'll NEVER call Chicagoland home.
      2013 TDI Sportwagen, 81 Rabbit Convertible, 92 Cabby (Daughter's), 98 SUV, 2011 Legacy
      01-20-2012 11:27 PM #31
      dug it out of the snow and squeezed both the 81 and 92 into the garage.
      Enjoy every sandwich - Warren Zevon
      Jun 28th, 2006
      Elizabethtown, PA
      '97 Golf (sold), '82 Rabbit 'vert, '92 Jetta VRT, '01 BMW 325i wagon
      01-21-2012 10:21 AM #32
      Quote Originally Posted by Lunchbox2021 View Post
      everything i do is budget build stuff. i bent the #15 pin for the DRL and just put a switch under the dash for the fogs
      Easier and less destructive way, pull down the fuse panel, locate the single wire yellow connector and unplug it. DRLs disabled on your MK3 without bending/damaging tabs, and can easily be re-enabled should you decide you want them, or to sell the car.
      The cabby only got caught in the background of this pic as I worked on the wheels for the MK2 project, last night.
    8. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      '15 PP GTI; '89 Cabriolet
      01-21-2012 04:59 PM #33
      Washed her........drove her.......took a picture of her....
      Bought sumin' for her....
      Now, I'm gonna tackle changing the color of the boot.
    9. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      91 Burgundy Etienne(2), 06 Jetta 2.5, 08 GTI 2.0T FSI
      01-21-2012 05:33 PM #34
      Turned 125,000 miles on a trip to the grocery store, with the top down in mid 70's weather.......
    10. Member Run_That's Avatar
      May 15th, 2009
      Sturgis, MI
      01-21-2012 06:30 PM #35
      I am jealous..
      '91 GTDECO
    11. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      01-21-2012 06:39 PM #36
      Quote Originally Posted by Run_That View Post
      I am jealous..
      needs a wash...
      Nov 30th, 2010
      Apple Valley, MN
      86 Cabriolet, 73 Super Beetle
      01-21-2012 06:41 PM #37
      mid 70s! it got in the twenties today so i figure it would be a good day to park and tarp mine
      dink and flicka
    13. Member Run_That's Avatar
      May 15th, 2009
      Sturgis, MI
      01-21-2012 07:43 PM #38
      Yeah it's unfortunate. The car sits in a garage most of the time but can't avoid getting dirty on wintry roads.
      I just cleaned the airflow plate area and fixed a intake boot issue. And shortly will be tending to an exhaust rattle at the sway bar. I must be one of the only around here to be driving/fixing things in the winter.
      '91 GTDECO
    14. Member Bama420's Avatar
      Jun 9th, 2011
      Orlando, Fl-ish
      1997 VW Golf GTI VR6
      01-21-2012 09:58 PM #39
      Quote Originally Posted by YJSAABMAN View Post
      GLH pizza cutters?
      1989 Plymouth Horizon
      1997 VW Golf GTI VR6 (OBD1 swapped)
      1988 Honda Prelude Si 4WS (parting out)
      1990 VW Cabriolet Triple White
      1981 Toyota Pickup 4x4 & 1998 Ducati 900SS
    15. Member yellorado's Avatar
      Oct 8th, 2001
      Quebec city, Canada
      92 cabby 16v, 91 yellow corrado, not stock!!!
      01-21-2012 11:02 PM #40
      not very much since she's sleeping for the winter, its -1000 deg here and theres 100 ft of snow everywhere
      well not really, but it sure seems like it to me!!!
      i did go for a drive with the wagon and picked up two full sets of used 195-50-15's (one yokos and one toyo proxes) so i have good rubbers on all three set of mags i rotate on it during the summer months
    16. Member
      Jul 3rd, 2011
      Joliet, iL
      01-22-2012 04:06 AM #41
      Changed the valve cover gasket, and the intake gasket (2.0 aba Mk3) ... Unfortunately, lost one of the hex bolts while taking off the back bracket/bolts.... Dropped it in the undercarriage and couldn't find it on the ground , so hopefully it'll fall out.. Everything else went smoothly, cept I found a bit of water/moisture inside the valve cover (let's hope it's because it's 10 degrees F up here.)
      Sent using my chin on My CyanoPad
    17. Member lil_squeeker's Avatar
      Nov 17th, 2003
      pa
      1998 jetta glx, 63.5 galaxie 500
      01-22-2012 01:19 PM #42
      bought it. threw a battery in it. then drove it home.
      only hiccup was a small coolant leak from the rad.
      "subculture refuses to let this model vw fade away......they are cherished and preserved in spite of logic and economics."
    18. Member
      May 7th, 2005
      Centennial, CO
      84 Cabby, 82 Westy 4 door aba hybrid, 2005.5 Jetta
      01-22-2012 02:17 PM #43
      I picked up this to put in it-
    19. Member 87CabrioSK's Avatar
      May 27th, 2010
      S'toon, Sk, CA
      1987 Cabriolet (5 speed) 2001 Beetle GLX 1.8T manual
      01-22-2012 02:33 PM #44
      Brushed off a foot of snow. Started her up...
      Sat in her for 15mins with a beer, dreaming of spring. What a machine!
    20. Member Spokane Pepe's Avatar
      Nov 18th, 2011
      Spokane WA, USA
      1987 VW Cabriolet
      01-22-2012 04:10 PM #45
      Ordered a Euro plate - should be in next week.
    21. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      01-23-2012 02:24 AM #46
      Got a call from my kid last night who was out in Etienne #2. Seems the passenger side axle came off on the tranny end, spilling its guts all over the road.
      Loaded the tools, jack, and a spare cv joint into the pickup. Found that 4 of the inner cv joint bolts were missing and the two bolts left had snapped leaving the remainder of the bolt in the hole. Was able to get one of the broken bolts out.
      Went to auto store, bought 5 of the 1.25x45mm M8 bolts.
      Pulled off the inner cv joint that fell apart, reinstalled the one I brought with me.
      Put 5 new bolts in place using lock washers, dropped it back to the ground and the kid drove it away.
      Need to find two of the plates that go on the axle bolts as they are missing.
      Ordering new bolts from germanautoparts as well as a shifter rebuild kit which this car needs.
      Another day in the life.......
    22. Member matty kirk's Avatar
      Jul 2nd, 2007
      Eugene, OR, transplanted from Eastern PA
      1990 VW Cabriolet 1.8L JH 5Spd Digi2 - 1981 Ford E-100, straight 6, 4 on the floor
      01-23-2012 06:44 AM #47
      Pulled my tranny ( in the rain ) so it can be sent for a rebuild. Stupid pinion bearing. All in all it went pretty smooth, considering the weather, and the fact that I'm working with an 1/8th of the tools I normally have available.
      Even a blind squirrel finds a nut in the dark, sometimes.
    23. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      01-23-2012 06:50 AM #48
      Quote Originally Posted by CajunSpike View Post
      When I lost the axle plates I just used 2 washers. 2 years no issues.
    24. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      01-23-2012 06:50 AM #49
      Did nothing but Drive it today............
    25. Member
      Jul 3rd, 2011
      Joliet, iL
      01-23-2012 07:45 AM #50
      Quote Originally Posted by briano1234 View Post
      Isn't that half the fun?!?
