Page 3 of 39 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 1354
Thread: What did you do to your cabby today?
  1. Member BIGDAVE1050's Avatar
    Sep 14th, 2003
    Fort Mill, SC
    2005 Golf TDI, 1999 Carbio
    02-04-2012 09:06 AM #71
    I replaced both side view mirrors glass. The old ones had wierd brown waves along the edges.
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    02-04-2012 11:19 AM #72
    Blue one Nothing but drive it...... my Green one had to have the Alternator replaced last week. took longer to get the warranty Alt and have it tested from the "auto jobber" than to remove and replace the old one.
    On a side note, getting it tested at the autojobber of choice, is a good thing, as they can print out the test or display it, and you can jot down the voltage and amperage of the new unit. So that when you place it on your car and start it after, you can measure the voltage to the battery to determine how bad your cables are.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  3. Member lil_squeeker's Avatar
    Nov 17th, 2003
    Glenside, PA
    03 ranger, 92 cabriolet carat
    02-04-2012 01:21 PM #73
    drove it for the first time since i bought it 2 weeks ago.
    as picked up......
    as of 1pm today
    "subculture refuses to let this model vw fade away......they are cherished and preserved in spite of logic and economics."
  4. Member
    Nov 30th, 2010
    Apple Valley, MN
    86 Cabriolet, 73 Super Beetle
    03-03-2012 09:53 PM #74
    Made my interior quiet
    Fixed my noisy vents... amazing how nice it is not to have those things whistling... thanks for the write up brian
    Took apart dash, found a bunch of missing screws and replaced them.
    Cleaned every switch button and controls while i had the dash apart. Looks 100 times better
    Unpluged 3 of the four speaker po blew them... im rocking just the passenger front for now.
    dink and flicka
  5. Member 08jettas's Avatar
    Jul 2nd, 2008
    08 jetta , 84 rabbit convertable , 1998 golf
    03-03-2012 10:09 PM #75
    Still polishing my wheels . And doing alittle paint work around the "p" s on the rims !!
  6. Junior Member Stashm2's Avatar
    Oct 25th, 2011
    Albany NY
    1963 VW Bus, 1992 VW Cabriolet, 2000 Chevy Express and a 06 Hyundai.
    03-03-2012 11:50 PM #76
    Today I got new tires for my used 97 Jetta Rims and put them all on my car looks much better than the ghetto 17's and Gave it new front shocks and springs :-) Set camber per a thread here seemed to work well. New rears should be here on monday! Drives like a new car with these wheels.
    And I missed Rodrigas My 92 Mexican Jetta may it live on in other VW's some where out there.
  7. 03-04-2012 08:45 PM #77
    Planning to start my electrical revamp of the dash and lights. Also doing the front brakes strut bearings and front wheel bearings. Have all the parts just have no time. I'll post up pics when I start
  8. Member dubsonparade's Avatar
    Jul 3rd, 2006
    Abbottstown, Pa
    1997 Golf 4 door/ 1987 Cabriolet ABA swap/ 2008 civic ex 5speed
    03-04-2012 10:02 PM #78
    Looked at mine sitting in it's upset leaking fuel state. Got a lot of things planned for it over the warmer months.
  9. Member Julianxt737's Avatar
    Sep 8th, 2011
    Alhambra,CA
    '90 VW Cabriolet
    03-04-2012 10:20 PM #79
    Was more yesterday night and in the morning today lol
    Replaced Brake Booster and Master Cylinder...next up, pads and shoes and full brake system bleed
  10. Member mAutopsy's Avatar
    Feb 19th, 2012
    Michigan
    1975 Beetle (x2), 1990 Fox, !991 Cabriolet (Current)
    03-05-2012 01:47 PM #81
    sewed myself a new shift boot
  11. Member MissHood's Avatar
    May 9th, 2004
    York&HarrisBurG,PA
    87cabriolet/ 97pontiac
    03-06-2012 01:22 PM #82
    waxed a bit while having a few cigs!
    You can't expect them to walk to and from school carrying their babies..
  12. 03-07-2012 12:28 AM #83
    Pulled the old fuel pump (external), re did some vacuum lines, and changed my passenger axle!
  13. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    03-07-2012 12:30 AM #84
    92 Cabby was running bad and had idle surges. Replaced idle control valve. Found much valve cover leaks...replaced with rubber valve cover from germanautoparts. found main big air tube practically disconnected from air box. Still have to fix exhaust gasket leaks from head to manifold.
    had a 99 cabrio towed home..so the fun starts on that.
  14. 03-08-2012 07:34 PM #85
    Quote Originally Posted by mAutopsy View Post
    Post up some pics of it. :-)
  15. Junior Member
    Feb 14th, 2012
    Columbia, PA
    1990 Cabriolet
    03-08-2012 08:23 PM #86
    changed my gear oil, cleaned up my battery terminals. And did a little touch up job on some rough spots in my paint.
  16. Member cab89's Avatar
    Jul 25th, 2011
    03-08-2012 09:11 PM #87
    The alloy wheels (actually the clear coating) were dull and nasty. I cleaned them today with brillo pads, then used #400 wet sandpaper on them, cleaned and dried them, then sprayed them with 3coats of a high quality gloss clear paint (Valspar). I didn't even take them off the car, I just masked the tires. The wheels look brand new now and it was totally simple. When the paint cures, I plan to put a silicone spray type auto finish coating on them so the brake dust won't stick.
    That went so fast and well, I then attacked the famous left leg leak by messing with the top, adjusting, and re-doing the silicone sealent areas. We will see.
  17. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    03-08-2012 11:15 PM #88
    Removed damaged top radiator support from 99 cabrio. Found wires to passenger side headlight cut and gone. installed new battery.
  18. Junior Member Stashm2's Avatar
    Oct 25th, 2011
    Albany NY
    03-09-2012 01:24 PM #89
    Cleaned up rear Springs and resprayed with epoxy paint as well as the upper spring seats.. Made new flanges for the lower spring seats as the originals were gone and the KYB's did not fit my new struts... Ordered new engine mounts all around.. New oilpump and windage tray are next on the list. Then fixing windsheild rust... and touching up paint. Should get the rear Struts in tonight (they are in and what a difference that made!).
  19. Junior Member
    Oct 31st, 2009
    Coimbra, Portugal
    '00 mk3,5 Cabrio
    03-10-2012 12:51 AM #90
    Bought a set of Saw-Blades, 16"x9.5" all around, for my mk3.5! A bargain (considering that I live in Europe, and the Corvette C4 wasn't sold in here, eheh)
  20. Member
    Nov 30th, 2011
    Northern NJ
    84 Rabbit Convertible, 1990 Volvo 740 Turbo
    03-10-2012 08:24 AM #91
    Made a whole new wiring harness with relays for my new quad grille! and started cleaning my wheels so they look nice for when the car comes out of paint!
  21. Junior Member
    Feb 27th, 2012
    Fort Worth, TX
    1985 VW Cabroilet Wolfberg Edition
    03-10-2012 10:02 AM #92
    Pulled the dash to change the vacuum servo. Going back in with the dash today after I trace the charge light wire to find the short.
    I will figure out how to post pic's later, out to continue on the job.
    85 Cabriolet
  22. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    03-10-2012 10:40 AM #93
    Picked these up:
    "Zed's dead, baby, Zed's dead."
    RooflessVW
  23. Member Tate393's Avatar
    Jun 21st, 2011
    P-Vegas, Wiscånsin
    Loretta
    03-10-2012 12:32 PM #94
    Quote Originally Posted by s2kvondeutschland View Post
    Picked these up:
    those seats are dope man!! where did u find those??
  24. Member Tate393's Avatar
    Jun 21st, 2011
    P-Vegas, Wiscånsin
    Loretta
    03-10-2012 12:39 PM #95
    Today was a sad day my friends.... I am in school and i daily drive my mk4 1.8t and my mom drives my passat but "Milley the Cabby" sits all lonely in my garage. But to get to the point, my family sold our house and we are movin over 1,500 miles away so it was time to downsize the inventory... so yes, i unfortunately had to sell my baby. my first ever VW that i bought salvaged and fixed up. RIP babe. ill miss you.
    heres an old pic of her.
    [IMG]Image and video hosting by TinyPic[/IMG]
  25. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    03-10-2012 12:43 PM #96
    Buddy of mine in Obernzenn had them in his basement, traded him some Golf 3 GTI reds straight up. I'm going to try to make some bases for them tomorrow while I look for a legit power set from a Jetta.
    I think they're originally out of an E30.
    Edit: From a 911. 993 series.
    RooflessVW
  26. Member Tate393's Avatar
    Jun 21st, 2011
    P-Vegas, Wiscånsin
    Loretta
    03-10-2012 12:46 PM #97
    real sick man. solid grab
  27. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    03-10-2012 01:21 PM #98
    Cleaned the windows, checked the fluids, Rain-ex'ed the Front.... Oh and I drove it to fill the tank.
    24.8 mpg on my Auto.
  28. Member dubsonparade's Avatar
    Jul 3rd, 2006
    Abbottstown, Pa
    03-10-2012 07:39 PM #99
    I got the rest of the parts to fix my fuel leak. That is getting done next weekend. Then focusing on fixing the exhaust and oil leak.
  29. Member 08jettas's Avatar
    Jul 2nd, 2008
    03-10-2012 07:56 PM #100
    friday I started buffing paint and today touching up front end with paint before I install small euro lip and reinstall my front bumper .
  30. Member
    Jun 28th, 2006
    Elizabethtown, PA
    '97 Golf daily beater, '82 Rabbit 'vert project/toy, '92 Jetta VRT project/toy
    03-10-2012 08:15 PM #101
    I got and installed the air filters the other day.
    Help save the Boobies!! Dub 'N Rub VW/Audi Show & Shine to benefit breast cancer research.
  31. n00b
    Mar 7th, 2012
    1997 Cabrio
    03-10-2012 09:12 PM #102
    I bought my first car, my first Dub a beautiful new to me 97 cabby with 109,000 miles on it! I'll post an introduction post with pics tomorrow for you guys
  32. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    1988 16v Scirocco 2012 GTI 2003 allroad 1990 Jetta GLI
    03-11-2012 01:17 AM #103
    Installed AC relay PO had removed for some reason; charged system, getting ready for summer
  33. 03-11-2012 09:40 AM #104
    It got dropped off @ the house yesterday. Pulled it in the garage, looked at it, opened the top & went back inside.
  34. Member lil_squeeker's Avatar
    Nov 17th, 2003
    Glenside, PA
    03-11-2012 10:32 AM #105
    clipper.......
    no clipper....
