Page 5 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 1235
Thread: What did you do to your cabby today?
  1. Member BIGDAVE1050's Avatar
    Sep 14th, 2003
    Fort Mill, SC
    2005 Golf TDI, 1999 Carbio
    03-23-2012 04:13 PM #142
    Thanks to a quick (but strong Thunderstorm) the glue on the back of my top gave way. So I put black Duct tape on my black top. (Does that count as a mod?)
  2. Member 18t papa's Avatar
    Dec 28th, 2009
    Orange County, NY
    Stage 2 '03 Passat 1.8t, '91 Passat 16V Variant, 1977 Jawa 350
    03-23-2012 05:26 PM #143
    Quote Originally Posted by BIGDAVE1050 View Post
    Id say its preventative maintenance hahahaha
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    03-23-2012 07:19 PM #144
    got pulled over for not having a sticker (which i dont need for another few days since i just registered it. ) got pulled over last night for having non working tail lights.. which i wasnt aware of ..
    so today i replaced the tail light fuses and they instantly popped .. time to make a post with pics and hopefully someone can give me a hand or point me in the right direction.
  4. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    1988 16v Scirocco 2012 GTI 2003 allroad 1990 Jetta GLI
    03-23-2012 11:19 PM #145
    Replaced EGR tube with good one I got from scrap yard, and installed antenna base so no more floppy antenna.
  5. Junior Member
    Jun 13th, 2010
    2001 Cabrio
    03-24-2012 12:23 AM #146
    Mounted my freshly powder coated wheels and went down to summer height 👍
    I am here: http://tapatalk.com/map.php?draaeu
  6. Member
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    03-24-2012 02:43 PM #147
    restored tail and brake light functionality!
    one step close to inspection possibilties! (if they ignore my ride height )
  7. 03-24-2012 05:53 PM #148
    Doing wheel bearing
  8. 03-24-2012 11:14 PM #149
    And wheel hub previous one was smoked. Got it all don't took it for a spin and I had too much camber my inner tire was rubbing coil. Plus my brakes were air locked. So I fixed all that too. Back in the road again.
  9. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    03-25-2012 02:57 PM #150
    Installed new upper transmission mount and replaced shifter bushing.
  10. Member
    Aug 29th, 2010
    Rio Rancho NM
    Horse drawn buggy
    03-25-2012 05:00 PM #151
    Re-wired the PO's awesome radio installation and installed a new jvc head unit with new boston rears, I need to get something for the fronts so the new speakers will fit properly.
    I'm really thinking that new Vw owners need to be tested and quizzed on owning and maintaining a Vw, so much crap on this poor car was Jerry rigged and thrown together you would have thought it was an old Chevy
  11. 03-25-2012 07:19 PM #152
    Washed the engine & now the hvac blower doesn't work. Have to yet to investigate. So I broke it today.
  12. Member KnuckleUp2's Avatar
    Jan 3rd, 2011
    Wingate, NC
    92 vw cabriolet
    03-25-2012 07:40 PM #153
    just made a custom adapter so i can rock a nice brand new K&N cone filter right off the mass airflow sensor
  13. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    03-25-2012 07:50 PM #154
    #2 91 Etienne - Installed new shifter kit. Installed new rubber valve cover gasket.
  14. Junior Member
    Sep 22nd, 2011
    ABQ, NM
    88 Mk1 Cabriolet
    03-25-2012 07:50 PM #155
    A/C delete, P/S belt delete. Cleaned engine. Now to find a fuel distributor and install new injector seats. Should be running soon.
    I am here: http://tapatalk.com/map.php?1u5hye
  15. Member mAutopsy's Avatar
    Feb 19th, 2012
    Michigan
    1975 Beetle (x2), 1990 Fox, !991 Cabriolet (Current)
    03-25-2012 08:33 PM #156
    finished up the p/s and a/c delete. wired the headlights on relays, and changed my radiator hoses.
  16. Member BIGDAVE1050's Avatar
    Sep 14th, 2003
    Fort Mill, SC
    03-26-2012 11:06 AM #157
    Used mine to haul lumber. Who needs a truck?
  17. Member 18t papa's Avatar
    Dec 28th, 2009
    Orange County, NY
    03-26-2012 06:06 PM #158
    Re-screwed in the screw that holds the lower center console thing down, and cleaned out the glove box
  18. Member
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    03-26-2012 06:57 PM #159
    put the fan control knob on the console and the cabriolet eblem on the back.
  19. Member lil_squeeker's Avatar
    Nov 17th, 2003
    Glenside, PA
    03 ranger, 92 cabriolet carat
    03-28-2012 05:29 AM #160
    does what a co-worker did to my cabby today count?
    "subculture refuses to let this model vw fade away......they are cherished and preserved in spite of logic and economics."
  20. Member
    Jun 1st, 2011
    Holiday FL.
    1988 cabriolet
    03-28-2012 10:36 AM #161
    AMAZING...hahaha
  21. Member mAutopsy's Avatar
    Feb 19th, 2012
    Michigan
    03-28-2012 11:31 AM #162
    went to the local u-pull yesterday, and found a 85 Jetta GLI- Promply removed door handles and gaskets. (I remember from my fox that michigan winters are harsh on the VW handle). also removed a mirror, and should go get the other one so mine match. Installed the mirror today and tightened up my window so it stops rattling.
    Also, looked at the Audi TB on my bench and pondered that for a while...and didnt install it
  22. Member 87CabrioSK's Avatar
    May 27th, 2010
    S'toon, Sk, CA
    1987 Cabriolet (5 speed)
    03-28-2012 11:41 AM #163
    Also picked up a used drivers side mirror, in great shape and installing today. Found some outer door handles on an old Jetta that have chrome/metal finger pully thing, haven't seen that before. Might grab those this week.
  23. Member
    Jun 1st, 2011
    Holiday FL.
    1988 cabriolet
    03-28-2012 11:50 AM #164
    just finished painting my new wheels red.....heehee
  24. Member KnuckleUp2's Avatar
    Jan 3rd, 2011
    Wingate, NC
    92 vw cabriolet
    03-28-2012 02:14 PM #165
    Quote Originally Posted by mileycyrus View Post
    when are they going on the car i really wanna see how it looks with the paint should be dope
  25. Member Sean A's Avatar
    Sep 8th, 2011
    Red Lion, PA
    87 Cabby
    03-28-2012 02:28 PM #166
    Quote Originally Posted by KnuckleUp2 View Post
    +1
    Taking it parallel parking...License test Friday!
  26. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    03-28-2012 02:50 PM #167
    Quote Originally Posted by Sean A View Post
    +1
    I took my son to a parking lot and set up cones cabby size to parallel park, I made him practice until he got the hang of it. When I took him to get his license, the DMV tester said he has never seen a 16 yr old get a 98 on the test, and that he paralleled park better than some old drivers. When he came out he said that parallel parking was a breeze... He had so much room... I smiled and said we practiced for a cabby, they have it set for SUV's... But the DMV guy as he was walking out to the car he said which one is yours, I pointed to the totally cleaned and waxed topless Cabriolet, and he said "75 degrees, sunny Friday afternoon, and this is my last test for the week, and an Convertible..." I knew my son was going to pass....
    Good Luck...
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  27. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    03-28-2012 03:05 PM #168
    Not a damn friggin' thing.
    Quote Originally Posted by briano1234 View Post
    Did the same thing with cones, only in front of my parents' house due to the curb. Don't know about now, but back in my day the CA DMV required either parallel parking or a K-turn during testing. I took the test in my Cab and had to do the K-turn, which I preferred! I got a 97 on the test; dumbass evaluator took off 3 points for going the road's speed limit in a school zone, after school hours. I was going to argue about it because the signs clearly say "15 MPH WHEN CHILDREN ARE PRESENT"; it was around 4:30pm, no kids around and school was out at 3:00. But my little voice said, "It's only 3 points, who cares?! Grab your license and run!"
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  28. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    03-28-2012 03:26 PM #169
    True story, young driver in 92 cabby...taking driving test.
    When instructor asked what kind of car was going to be used and heard it was a 92..she made comment like 'must not be in good shape'.
    by the time the test was over, she was smiling and enjoying the weather..
    "man that car sure is fun and drives well".
    100% passed.
  29. Member
    Mar 7th, 2011
    Everett
    1989 Volkswagen Cabriolet, 1999 Volkswagen Cabrio
    03-29-2012 04:40 PM #170
    Put some coilovers on it the other day and I'm getting new tires and an alignment today. Maybe wash and wax if it stops raining.
  30. Member
    Aug 29th, 2010
    Rio Rancho NM
    Horse drawn buggy
    03-29-2012 07:02 PM #171
    New door handles and a idle screw this car is coming along nicely. I'm picking up a new techtronics exhaust this weekend. I'm having a blast working on this damn thing.
  31. Member Sean A's Avatar
    Sep 8th, 2011
    Red Lion, PA
    87 Cabby
    03-29-2012 07:42 PM #172
    Good Luck...
    Haha, I love parallel parking in that thing so easy, couldn't imagine doing it with anything else. I put one of those small mirror things on my right mirror so I can see if my back tire is near the curb, hopefully he allows that lol. Thanks!
  32. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    03-29-2012 08:34 PM #173
    Ordered a new instrument cluster with the white gauges, partially because the temp gauge on mine doesn't work and partially because I just like the white gauges
    Car is starting to feel like home
  33. Member mAutopsy's Avatar
    Feb 19th, 2012
    Michigan
    03-30-2012 12:56 AM #174
    repainted the badges on the back with some touchup paint.
  34. 03-30-2012 05:46 AM #175
    Got tired of the Cabriolet leaking oil. Installed a Schrick oil pan I'd had sitting on a shelf along with a new pan gasket/windage tray. Now all four vehicles (two VWs, a BMW Baur TC and a Kawasaki) in my "two-car" garage are oil tight!
