VWVortex.com - A6 Q 2.8 V6 head gasket
    Results 1 to 16 of 16
    Thread: A6 Q 2.8 V6 head gasket
    1. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      95 Jetta III GL, 96 Jetta GLS, 95 Jetta III, 81 rocco S, 69 St. Bug, 86 Jetta GLI, 99 A6 Q, 02 GTI
      01-04-2012 09:12 PM #1
      i have a chance to get this A6 for 'nothing' and wanted to know if anyone has done head gaskets on the 2.8. i havent done much with this engine other than the reg things... oil leaks and service things. this car is really nice and has had tranny put in it about 6 months ago. got about 160xxx on it.
      just dont want to get into this thing and then find that these engines are like the E46 BMW engines and rip the treads out when put the head back. or that the head cant be faced without problems....
      any info would be great!!!!!!!!
    2. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      01-05-2012 07:38 PM #2
      well its good to see we dont have any good techs in this forum! hahahaha
      FYI i talked to the guys at the dealer today and they said they havent had any problems when doing a head gasket.
    3. 01-22-2012 05:58 PM #3
      If you do this project you should replace the plastic pads on both camshaft tensioner/adujsters.
      I bought just the pads on line and also do the water pump, tensioner, idler, damper and timing belt.
      If you don't have the special timing bar and camshaft sprocket puller you can rent them.
      You should also follow the factory procedure to tension the timing belt which requires that the cam sprockets be loose on the camshafts.
    4. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      01-22-2012 07:20 PM #4
      thanks for the reply. I've done tons of timing belts on these engines at the shop. but I've never done a head. as for the timing belt, if i do a job i try to always do it "right"! the best that i can with the info that i have at hand. so with that said the timing belt and water pump with all other goodies is a must. i always say "if your there"....
    5. 01-23-2012 10:46 AM #5
      Quote Originally Posted by volkswjetta3 View Post
      In the category of "if you are there" the plastic pads on the adjuster/tensioner assemblies can
      also cause misfiring at low speed if the adjuster gets jammed in the advanced position. I worked on a 99 A6Q Avant that misfired like "crazy" with 200 plus misfires during the counting cycle on all bank 2 cylinders. The engine ran completely free of any misfires above 1600 rpm. The owner refused the repair of the broken cam adjuster and drove for another 3 or 4 weeks until the engine "blew up". The misfires were so unusual that I watched them with VCDS at least 10 times to prove to myself that over advanced cam timing at idle could cause that problem! Also, the cylinder head bolts use a flank drive bit to remove them not a Torx or triple square.
    6. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      01-23-2012 01:41 PM #6
      Quote Originally Posted by Peter Badore View Post
      is this the same as the 1.8T's? if so i have it.
      and this part you are talking about.... have you got any pictures? idk know that i know what it is that you are talking about. and if i do i can't place it...
    7. 01-23-2012 04:00 PM #7
      The 1.8l turbo head bolts also use a flank drive bit. There is a special Audi VW flank drive tool
      of the correct length but I think you can find other tool suppliers that will also provide the correct bit.
      The adjuster/tensioner pad for the 2.8l 30V V6 is very similar if not the same as the 1.8l turbo.
    8. Member tryin2vw's Avatar
      Dec 29th, 2006
      Greensboro, NC
      99 MK3 2.0, 01 B5.5 1.8T; 02 MK4 TDI
      01-23-2012 04:07 PM #8
      Yes, it is the same on the 1.8T and 2.8L (mine anyway). Even if it is not, I can loan you one, as I am in SE Greensboro, NC.
    9. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      01-25-2012 08:53 PM #9
      thanks for all the help guys! i have the tool from the dealer for the 1.8T so if its the same then I'm all set.
    10. Junior Member got_a_vdub's Avatar
      Sep 6th, 2004
      Key West, FL
      '06 VW MKV GTI, '11 VW Routan SE
      02-10-2012 05:33 PM #10
      Ok, so about how much to have this done at the dealer? Same car, A6 quattro with the 2.8L 6... Actually, pretty similar sounding situation. 1998 for sale and just needs a new head gasket..... Thanks!!
    11. 02-13-2012 09:03 PM #11
      Quote Originally Posted by got_a_vdub View Post
      You should try to find a good independent tech. In my experience and others the VW and Audi dealership personnel just throw a "ton of parts" at the cars they work on. This is one Michigan VW parts manager's statement since I do all my own mechanical work and only see the results of their handiwork on others' cars.
    12. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      02-13-2012 09:31 PM #12
      if you have any idea on how to work on an engine the job isn't that bad.... just need the time
    13. Junior Member got_a_vdub's Avatar
      Sep 6th, 2004
      Key West, FL
      02-19-2012 10:40 AM #13
      Yeah, i know the dealer is gonna be more expensive and that they may throw extra parts in.... I should have been more particular with my words. I should have said, how much does it run in general to have this done in a shop....? Was just wondering if this A6 wagon was worth the price if the head gasket needs to be changed..... Thanks though, appreciate the "insider's opinion"....
    14. Junior Member got_a_vdub's Avatar
      Sep 6th, 2004
      Key West, FL
      02-19-2012 10:42 AM #14
      YIKES! If that is what changing a head gasket on a 2.8 V6 looks like, then that is best left in more qualified hands.... I have changed a head gasket on 4-cyl Honda engine, but it didn't look anything like that mess.....
    15. Member volkswjetta3's Avatar
      Jan 24th, 2008
      Greensboro, NC
      02-20-2012 10:01 AM #15
      MESS.... very good word to use here! its a hell of a job, but when you get the car for $650 it pays to take a little time. i mean ill have about $1500 in it when its done. and ma'am will have a sweet ass car to drive!
    16. 04-01-2015 11:26 PM #16
      Was there a trick to removing the exhaust manifolds? I'm trying to change the head gaskets and am struggling getting the exhaust out.
      Thanks.
