VWVortex.com - FSB and air on MKV
    Page 4 of 4 FirstFirst 1234
    Results 76 to 95 of 95
    Thread: FSB and air on MKV
    1. Member ripNdip's Avatar
      Aug 6th, 2010
      McLean,VA
      Bagged MKVI Jetta
      02-13-2012 02:25 PM #76
      Quote Originally Posted by itzkv View Post
      How did you adjust it? Did you just go for the shortest length of the endlink?
      yea you can just spin them up or down and i put them on and then spun them all the way down and you can see them pull the sway bar up off the lower control arm.
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      02-13-2012 09:34 PM #77
      I just placed an order for mine with BSH. They gave me the best price on them!
    3. Member staygold89's Avatar
      Apr 17th, 2010
      LKWD
      Scoobie
      02-17-2012 11:23 AM #78
      Quote Originally Posted by Andrew@ORT View Post
      powergrids all the way
      Im stuck debating between powergrids or ksports.
      What makes the powergrids worth the extra ~$100?
    4. Junior Member absence's Avatar
      Jun 30th, 2009
      BKLYN
      08 GTI/05 S2K/02 Ranger/things with two wheels
      02-17-2012 01:00 PM #79
      Quote Originally Posted by staygold89 View Post
      i can't speak to the ksports as i have never ran them.
      i ran powergrids given their years of experience modifying just about every front and rear link setup out there, and that all the track and auto-x guys on the mkv platform run them (or fab their own).
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      02-17-2012 01:55 PM #80
      this may cause debate but I'm going to post my thoughts anyways.
      this thread is for FSB on air. for that reason, people are going with shorter end links to compliment the air ride ( I assume to avoid contact when airing out?) So does it matter which endlonks to go with? I know there are quality concerns but, is there any real benefits of going from ksport or powergrid?
      Also, since setting up endlinks requires almost zero stress to the bar does setting it at the shortest length effect our FSB capabilities at driving/raised heights?
    6. Member staygold89's Avatar
      Apr 17th, 2010
      LKWD
      Scoobie
      02-17-2012 10:06 PM #81
      Well... I bit the bullet. Just ordered powergrids. Figured why skimp out on my setup now. Can't wait to get them in.
    7. 02-18-2012 12:25 AM #82
      Here ya go, Will
      will thies work on supreams?
      addicted to switches
    8. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      02-18-2012 12:34 AM #83
      No sir, but we've been talking to Dorbritz about making some for the BagYard line.
      Shoot me an email, we need to catch up!
    9. Member giusep4's Avatar
      Jun 4th, 2009
      Des Plaines
      MkV GTI
      02-18-2012 01:51 AM #84
      Is the bagyard strut design similar to the mason tech?
      Sent from my phone while I should be working or paying attention in class.
      GET LOW
    10. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      02-19-2012 03:36 PM #85
      Just cut the sway out. It's not noticeable
      2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
    11. Member MoWsE's Avatar
      May 14th, 2007
      SoCal (Oxnard)
      Current: 2008 MKV .:R32 Old: 2000 B5 Passat
      02-19-2012 09:39 PM #86
      Quote Originally Posted by chadone View Post
      It is noticable if you're doing any spirited driving and taking corners at a decent speed.
      Sent from my fingers to your brain
    12. Member OVRWRKD's Avatar
      Jul 1st, 2010
      Toms River, NJ
      08 CW GTI
      02-19-2012 10:54 PM #87
      Andrew, you should have an email from me on this very matter, haha.
      Quote Originally Posted by giusep4 View Post
      Is the bagyard strut design similar to the mason tech.
      The strut body will be similar, internals are different. I believe the mason-techs were built with bilstein struts. The outside diameter of the body is what differs between the bagyards and airlifts becuase they use different strut bodies. If you have a caliper handy, take a measurement and I'll check my bagyards for comparison.
      MKV Accuair E-level Install Guide
      PM about air/suspension installs, frame notches, etc.. Flickr
    13. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      02-20-2012 03:55 PM #88
      Jared, you'll have a response today
    14. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      02-23-2012 09:55 PM #89
      Quote Originally Posted by MoWsE View Post
      I only notice it at 50 mph tight turns.
    15. Member
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      02-26-2012 11:53 PM #90
      Anyone done FSB & Frame Notch? Will the FSB allow that..?
    16. Member Keden's Avatar
      Jan 31st, 2005
      Toronto, ON
      06 GTI MK5
      03-31-2013 02:45 PM #91
      To anyone running Ksports endlinks with Airlift XL's - can you lay frame with this setup?
      Or do you have to get Powergrids to lay frame with the swaybar in?
      Quote Originally Posted by Thomas Jefferson
      If the American people ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and corporations that will grow up around them will deprive the people of all property until their children wake up homeless on the continent their Fathers conquered...
    17. Member
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      03-31-2013 03:03 PM #92
      Quote Originally Posted by Keden View Post
      I lay frame with XL, Dorbritz Mounts, and KSport links.
    18. Member cldub's Avatar
      Jul 2nd, 2010
      Stafford VA
      2006 Audi A3 2.0T (sold)
      03-31-2013 09:20 PM #93
      Yup!
      Notched, FSB still in, Airlift XL's w/ Dorbritz mounts, and ksport endlinks
    19. Member Keden's Avatar
      Jan 31st, 2005
      Toronto, ON
      06 GTI MK5
      03-31-2013 09:39 PM #94
      Awesome, I'm getting KSports then!
    20. Member jun_1.8T's Avatar
      Oct 31st, 2003
      Brampton, ON
      '02 Jetta 1.8T(gone), MK6 CW Golf
      04-01-2013 11:27 AM #95
      Where do you exactly put the dorbitz brackets? I mean i know it slides onto the struts...but im wondering the exact spot you guys put it in? How far is it from the lower part that holds the air bag itself...2-3 inches?
      Thanks...
