VWVortex.com - ABS Module Recoding
    Results 1 to 11 of 11
    Thread: ABS Module Recoding
    1. 01-06-2012 06:49 PM #1
      Can anyone explain how I can reocde my New(used) ABS module.
      I looked at the instructions on Ross-Tech but am quite puzzled.
      I have a 2002 VW Passat 1.8 L Turbo.
      Is there a way to tell if I have a 5.3 or 5.7 module on it. My New(used) module os off a 2000 passat.
      I don't want to install it and find it's not crackin.....
      Mine took a crap a few weeks back. (ABS, BRAKE light ON).
      Any help is greatly appreciated.
    2. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      01-06-2012 10:23 PM #2
      That's probably not the right module. The part number has to match exactly; it's more than just "is it version 5.3 or 5.7?"
    3. 01-06-2012 11:02 PM #3
      Thanks for the reply,
      Both parts numbers match.
      I have a 5.3 in my car. Part number: PBT GF30
      The module in my car won't even respont so i can get the coding from it, once I figure out how to code it, then just apply that to the new one, bangggg. done.
      I looked at the coding on ross-tech webcite but it I was lost.
      If anyone could explain how to do it, much appreciate it.
      This is what VCDS came up with:
      VCDS Version: Release 11.11.1
      Data version: 20111209
      Friday,06,January,2012,19:58:23:56259
      Chassis Type: 3B - VW Passat B5
      Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
      VIN: WVWPD23B72P349954 Mileage: 224200km/139311miles
      Address 01: Engine Labels: 06B-906-018-AWM.lbl
      Part No SW: 4B0 906 018 CM HW: 8E0 909 018
      Component: 1.8L R4/5VT G 0006
      Coding: 0016501
      Shop #: WSC 93246 999 00990
      VCID: 6ED9D7D07A8C254
      1 Fault Found:
      18057 - Powertrain Data Bus
      P1649 - 008 - Missing Message from ABS Controller
      Readiness: 0110 1101
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 1C0 909 605 B
      Component: 0B AIRBAG VW51 04 0004
      Coding: 12354
      Shop #: WSC 00028
      VCID: 234FF6E4B1CED8C
      No fault code found.
      Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
      Part No: 3B0 920 827 C
      Component: KOMBI+WEGFAHRSP VDO V06
      Coding: 07335
      Shop #: WSC 93267
      VCID: 244DF5F8B4C0DF4
      WVWPD23B72P349954 VWZ7Z0A4685092
      1 Fault Found:
      01316 - ABS Control Module
      49-00 - No Communications
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 00028
      VCID: F0E549A8B0B8B34
      1 Fault Found:
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 C
      Component: 08 Komfortgerát HLO 0001
      Coding: 00258
      Shop #: WSC 00028
      VCID: 377732B41556A4C
      Subsystem 1 - Part No: 1C1959801
      Component: 08 Tõrsteuer.FS KLO 0004
      Subsystem 2 - Part No: 1C1959802
      Component: 08 Tõrsteuer.BF KLO 0004
      Subsystem 3 - Part No: 1C0959811
      Component: 08 Tõrsteuer.HL KLO 0004
      Subsystem 4 - Part No: 1C0959812
      Component: 08 Tõrsteuer.HR KLO 0004
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: Radio NP2 0055
      Coding: 00401
      Shop #: WSC 00028
      VCID: DDBB001C572A2EC
      1 Fault Found:
      00880 - Connection to Speaker Rear Left
      36-00 - Open Circuit
      End ---------------------------------------------------------------------
    4. 01-06-2012 11:03 PM #4
      Forgot to mention, Both part numbers match...
    5. Member tryin2vw's Avatar
      Dec 30th, 2006
      Greensboro, NC
      99 MK3 2.0, 01 B5.5 1.8T; 02 MK4 TDI
      01-07-2012 09:13 AM #5
      Sounds like either: the k-line is improperly on an after market radio installation or you have a replacement module that is also bad. Why not send the original module out to one of the repair shops? The cost is anywhere from $50-200, depending on warranty level.
    6. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      01-07-2012 09:26 AM #6
      Quote Originally Posted by tryin2vw View Post
      I think that readout is with the original module in the car. But I agree it's far better (less expensive, more reliable, no re-coding) to have the original module repaired than experiment with a used one.
    7. 01-07-2012 10:46 AM #7
      Quote Originally Posted by scotts13 View Post
      Yes you are right, the readot is from my original one. Being the start of winter and snow, I don't want to really drive without ABS. So what I thought was install and recode the used one (I got really cheap at the yard) so when the rebuild one comes back, I just slap it on, done deal.
      Can anyone explain the recode steps that are in Ross-Tech. It's just a bunch of x's ?s and single numbers.
      Thanks
    8. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      MKVI Jetta & MKIV Golf
      01-08-2012 02:54 AM #8
      I had mine re-coded by my independent VW/AUDI mechanic. Took him 2 minutes. I have no idea what he did, he wouldn't show or tell me. He used a really old VAG scan tool to do it.
    9. 01-09-2012 06:49 PM #9
      ok, So I installed the replacement ABS Module (What a Pain in the WAZOOOO), I like it tight, but not pain in the ASS tight
      I tried recoding it with no luck.
      Can someone send me the link to a DIY or the right login information.
      I tried entering 00022 in the coding tab but once I hid DO IT! it closes that screen and I'm back to the previous screen with the exact same values as before (Softcoding:00000, I need it to go to 00022 and Shop#: 00028)
      Any help appreciated.
      I have a 2002 VW Passat 1.8L T, Manual Transmission.
      Thanks,
    10. Member tryin2vw's Avatar
      Dec 30th, 2006
      Greensboro, NC
      01-09-2012 07:41 PM #10
      What version of VAGCOM/VCDS is being used?
    11. 01-09-2012 08:18 PM #11
      VCDS Release 11.11
      Here's some more info.
      I need help loging IN because I guess I need to be logged in for it to store whatever codes are changed on coding.
      Here's some more info on the car that might help:
      2002 VW Passat 1.8 L T AWM
      Production code:
      WVWPD23B72P349954
      3B34K1
      3B34K1PASSAT LIM GLS 125KW
      EZG L041 SG5 AWM
      X9B B0E C5E G0C H5B J0R MW9 Q2J
      V0A 1AJ 1G2 1PQ 5RR 5SH T6V
      3S0 8T1 QG0 8US 8GD
      8R1 1LE 0JH 0YD 1BA 0GN
      thanks,
