VWVortex.com - MK 6 Jetta VCDS Mods
    Page 4 of 15 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 351
    Thread: MK 6 Jetta VCDS Mods
    1. Member ehWudupdoc's Avatar
      Nov 9th, 2007
      North Jersey
      R.I.P 2007 Rabbit, 2012 Candy White GLI, Vag-Com
      04-14-2012 09:53 PM #76
      does anyone know what the hardware issue is for the mirrors not tilting when in reverse? i have the option selecting using vcds and even on my mfi shows up checked marked on but nothing
      J.Rabbit
    2. Member vw_freak7's Avatar
      Apr 11th, 2002
      Fort Worth, TX
      1981 Scirocco S-Mars Red; 2014 Jetta TDI-Reflex Silver, 2015 Golf R-Lapiz Blue Metallic
      04-15-2012 05:11 PM #77
      Does anyone have the proper coding for a '12 GLI with the functionality Jettadude1 described?
      Quote Originally Posted by Jettadude1 View Post
      I had mine installed at the dealership, so while I did pay a little more, at least I can tell you how it's supposed to be via OEM:
      - The alarm horn does honk. It's very easy to tell as you can hear the sound coming from right under the windshield cowl. It's also a higher-pitched sound.
      - The car horn is separate. The only time you should hear that is when you honk it (it has a louder sound).
      - Parking lights should flash when you arm/disarm the system.
      - The alarm should go off if you access a car door, the trunk or the hood. The alarm will rearm itself if you unlock the doors with the fob, but fail to open any doors within 30 seconds (maybe 45).
      I searched the forum and couldn't find it. I don't want to buy the kit and not have it function how I think it should. This website specifically say GLI coding not available, but who knows how old that info is...
      http://www.vwpartsdepartment.com/par...catalogid=5496
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      04-17-2012 01:57 PM #78
      Has anyone found the option for curb assist (side mirror angles down for parking) in vag-com? If so and you haven't been able to get it to work, have you tried this?
      "I have folding mirrors and I discovered that if the switch is set to L and I select reverse it auto dips the near side mirror so that you can see the curb. If it is set to 0 or R it doesn't dip. Its amazing what you find out by accident" - http://www.vweosclub.com/forums/show...4&postcount=13
    4. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      12' Jetta S, 95' Passat GLX, 93' Corrado SLC
      04-17-2012 02:05 PM #79
      Quote Originally Posted by Verebs1 View Post
      I have seen the option on VCDS. But it wasn't clickable!
      R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
      Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
      Instagram- @mr_toffee
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      04-17-2012 02:11 PM #80
      Quote Originally Posted by EuRoGTI86 View Post
      ehWudupdoc seems to think otherwise?
      Quote Originally Posted by ehWudupdoc View Post
    6. 04-17-2012 08:17 PM #81
      I saw someone do this to their jetta via vag com in a pic on ebay (after he installed the right hand side buttons on his SE)... anyone know where to find it in vag com?
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      04-17-2012 08:21 PM #82
      What were they selling?
    8. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      2007 Passat Wolfsburg (Sold) - 2011 Jetta SE (Sold) - 2014 Tiguan SEL (Current)
      04-17-2012 08:27 PM #83
      Quote Originally Posted by NADERJ123 View Post
      Let's see a link
    9. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-17-2012 09:12 PM #85
      Wow that is extremely interesting. I have an SE with conveinance and I have right side controls since I did a gli mfsw swap. Maybe we should post this in the vcds section..let me do some research...
      Edit: I don't have any reason to believe that our cars lack the hardware to pull this off seeing as how the car already monitors fuel electronicaly. Going to poke around in vagcom. What would help probably is a TDI scan which has a similar cluster and has these functions.
    10. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      2012 Jetta 2.5L SE w/Convenience and Sunroof
      04-17-2012 09:17 PM #86
      Now that is SWEET! If you figure this out then I have got to know!!!
      Sent from my iPhone 4 using Tapatalk, yo!
      2012 Jetta 2.5 SE w/Convenience & Sunroof - Platinum Gray Metallic.
    11. Member
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      04-17-2012 09:28 PM #87
      Would this work on my Jetta a Jettsy? I don't have a mfsw currently
    12. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-17-2012 09:59 PM #88
      as it currently is no but that doesn't mean its completely eliminated. :thumb up:
      First thing you would need is a new steering wheel. I believe the cluster in the s,se, and sel are identical. Hard part is figuring out the coding but I'm already in the works with that. I keep this updated:thumb up:
      Edit: cluster in S might actually be different seeing as how they have different engines. But coding wise should not matter
    13. 04-17-2012 10:01 PM #89
      I asked the seller on info about the features as well
    14. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-17-2012 10:07 PM #90
      haha i just did the same, he said he didn't know so i asked for the persons contact info haha!
    15. 04-17-2012 10:13 PM #91
      he wouldn't give it up. great orlando minds think alike
    16. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-17-2012 10:37 PM #92
      Didn't know you were from Orlando haha! Cheers
    17. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-18-2012 12:15 AM #93
      I have the guys contact info.
    18. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-18-2012 12:49 AM #94
      Holy s-h-i-t check the new thread I'm about to post.
    19. Semi-n00b
      Oct 19th, 2011
      DcMdVa
      04-19-2012 11:44 AM #95
      How about ALL doors unlock at once with one press on keyfob. Anyone do that?
      Don't want to press unlock twice to unlock the passenger doors. Want it all with one click.
      2012 Jetta Sedan TDI - Tempest Blue
    20. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-19-2012 11:46 AM #96
      Quote Originally Posted by Ahujadaddy View Post
      It can be done.
    21. 04-19-2012 02:59 PM #97
      Can you make the car start with one press of the start button instead of having to hold it down?
    22. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      04-19-2012 03:11 PM #98
      Quote Originally Posted by Shafted33 View Post
      Not possible as far as I know
    23. Junior Member
      Apr 17th, 2009
      Buffalo, NY
      2012 GLI Autobahn w/Nav 6MT
      04-22-2012 10:44 PM #99
      I had an '11 SEL with KESSY and it needed to be held down, but on my '12 GLI, it's just a single press and does not need to be held down. Not sure if it's a MY change or the different electronics in the GLI that support it...
    24. Member
      Jul 8th, 2003
      South Korea
      2007 Z06, 2006 V8 4Runner
      04-29-2012 05:57 PM #100
      Quote Originally Posted by 1Afly View Post
      3) Turn ON Remote (convenience windows) with Sunroof OPEN and NOT TILT as well as close them from key fob Located in 09- Cent. Elect. Coding, Long Code Helper, Byte 3, Check Bits 0 and 5. NOTE I can confirm that the windows AND sunroof will TILT OPEN and CLOSE via key fob (no option to check to have sunroof slide open, only to tilt)
      FYI, my '12 SE auto conv/sun does NOT tilt the sunroof, it slides it as far back as you want (by holding the unlock/lock button.)
      Thank you for this thread, btw.
