any pics of your new stat set up?
#141
Great work man!!! Just wondering if you will have enough clearance for your thermostat housing?
#143
#144
sub'd.![]()
#145
#146
whats your major problem? have you looked at the vr6 vanagon tstat housing? it sticks out about as far but has a 90 degree turn on the end. not sure if that helps you, it did not for me. i basically made my own flange and had a 90 welded on it so it sits closer to the block.
Adaptec Speedware
775.530.2483
#147
Def wont help me. This is my clearance to the crossmember. Im in the works of notching that beam to fit the housing in. The motor is exactly in the spot I want it but the bus says noI saw the cradle that james did and he did a great job. I am looking to do something a little different on mine.Check my sig for my bus build.
#148
#149
Adaptec Speedware
775.530.2483
#151
Adaptec Speedware
775.530.2483
#152
Looking at 1974 911... if the plan moves forward it would be done as a reversible swap and I would put the air cooled engine in dry storage. That way from a collector standpoint I wouldn't be hog tied if a time to sell came along. Would likely do a full rebuild on the aircooled engine if the vr6 did find it's way in.
#154
Plan is to pick up tomorrow... I'll start a thread if / when I start this winter. Have a lot of plans for reversible mounts looking at the flat six in there. I really like the flat six but the cost to operate or repair for many might cost a few of these cars their lives...
#155
I don't know what your project list looks like but mine is estimating the cost down to the last nut and bolt of approximately $13,440.44 without the cost of the car or labor... for built engine, garrett t04z on standalone. Phew!
Mechanical/Mounting
5,920.00
Cooling
1,020.00
Oil
74.65
Intake
1,070.00
Exhaust/turbo
2,334.79
Electrical
1,121.00
Fuel
1,900.00
#156
In my professional experience multiplying your best estimate by Pi (3.14159) tends to be a good out the door number at a project closes.![]()
-Paul
#157
I'm pretty close now as I have ~$10g of this in my Jetta that I'm about to raid... just waiting for the salt and snow to fly so I have an excuse to be in the garage.
#158
Originally Posted by skin1488760
SCAMMER skin1488760 Christopher Heiser Escondido Ca951-756-5977 .http://forums.vwvortex.com/showthrea...4-looks-SO-CALhttp://forums.vwvortex.com/showthrea...e-intake-socal
#161
#162
Adaptec Speedware
775.530.2483
#163
sbscrb!
What is something you learned last year that you are going to do differently this year?
#164
Keep the progress pics comin' even if it's swapping door seals instead of firing this beast up.![]()
#165
Finally on the ground. Will let the suspension settle then lower it and add some spacers.![]()
Adaptec Speedware
775.530.2483
#168
Amazing how much room there is behind the motor without the cooling fan that would normally be there.
#169
Looking good![]()
#171
#173
Why yes; that she tropper has sideburns...
#174
Ok back on this. Moved the car back from my buddies who did up all the fab work. sending the cradle and a few other things to powder coat. Will get some updated pics up soon![]()
Adaptec Speedware
775.530.2483
#175
