VWVortex.com - Fuse Diagram for 2012 or 10 AMP fuse diagram
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 26
    Thread: Fuse Diagram for 2012 or 10 AMP fuse diagram
    1. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      2012 Jetta 2.5L SE w/Convenience and Sunroof
      01-09-2012 09:06 PM #1
      Anyone have a fuse diagram for the 2012 SE?
      OR - Does anyone know what all of the 10 AMP fuses power?
      2012 Jetta 2.5 SE w/Convenience & Sunroof - Platinum Gray Metallic.
      Oct 14th, 2011
      Inver Grove Heights MN
      2012 Passat TDI
      01-09-2012 09:14 PM #2
      Quote Originally Posted by Jettadude1 View Post
      Various parts of the electrical system. jk had to say it for fun.
    3. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      01-09-2012 09:52 PM #3
      Quote Originally Posted by Fussgus View Post
      Good one!!!
      I know it's a stupid question, but this is the first car I have ever seen without a fuse diagram. I've been Googling, searching threads and calling dealerships. Nothing yet.
    4. Member
      Oct 14th, 2011
      2012 Passat TDI
      01-10-2012 10:12 PM #4
      Good one!!!
      I like you am still yet to find one as well. Very annoying not knowing what all those fuses are for.
    5. 01-11-2012 01:45 AM #5
      I recently blew a fuse doing an HID retrofit and ended up buying a multi-meter at home depot to test all the fuses. It only took 2 minutes to check all the fuses after I got the multi-meter but it set me back $40.00
      I can tell you where the high and low beam fuses are if that's what you're looking for (they're 15A fuses).
    6. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      01-11-2012 07:39 AM #6
      Quote Originally Posted by California_TDI View Post
      Wow - that would be cool if you could help. I think that I was able to locate the a 10 amp fuse for the Right Steering Column (fuse #10). I'm hoping that one would be safe to use via a fuse tap.
      A side note - VW is REALLY big (surprise) about keeping what powers the fuses a big secret. In one case I called a dealership in Kentucky and they told me that tapping into a fuse could cause serious problems. Granted, I'm not a mechanic but it's only a radar detector.
      Oct 14th, 2011
      2012 Passat TDI
      01-11-2012 04:30 PM #7
      That seems a little extreme to buy a multi-meter, I just got a fuse tester that lights up when you touch both ends of a working fuse.
    8. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      01-15-2012 08:47 PM #8
      Look here.
      Click the BLUE download button 2/3 down the page.
      For 2011 Jetta
      2011 and 2012 service diagrams for fuses are identical, not sure if actual vehicle fuse configurations are identical however.
      http://www.2shared.com/document/iJIY...DI_Fuse_03.htm
    9. Semi-n00b
      Nov 22nd, 2011
      Louisville
      2011 Jetta TDI
      01-15-2012 09:04 PM #9
      More locations
      Again, BLUE download 2/3 way down the page
      http://www.2shared.com/document/O89F..._units_01.html
    10. 01-24-2012 04:39 AM #10
      did you find out about turn signal fuse for sidemirror or is it only one for all of the turn signal including front and back? what color and what amperes?
      1999 CIVIC EK
      2004 S2K SIL/RED
      2004 BMW M3 AW/IR
      2012 PASSAT SE BoB
    11. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      01-24-2012 09:10 AM #11
      Quote Originally Posted by mf1160 View Post
      More locations
      Thanks! This matches what I have.
    12. n00b
      Jan 24th, 2012
      DFW Area, Texas
      2012 Jetta TDI DSG w/Premium
      01-24-2012 10:20 AM #12
      Just did this on our new '12 Jetta TDI. I'd use the 12V socket fuse #30, 6th slot from left on top row at the dashpanel location. It's a 20A.
      Fuse taps are ok when used properly. The risk with the ones that slide over the leg of one fuse comes from folks putting them on the supply side of the fuse, and then not separately fusing the new circuit. Something goes wrong in that case, and you have crispy car. Put it on the load side, fuse the new circuit and make sure the female blade connector you use is insulated so the live blade is completely covered. Couple bucks gets you a 4 pack usually.
      The other add-a-circuit types are ok, and you don't risk widening the clip in your fuseblock trying to jam more stuff in there. Still try and make sure the new circuit gets added on the load side. I found these are $5-6 each.
      When I add a bunch of equipment, i'll do fancier wiring, but for just hardwiring a radar detector both of them are acceptable IMO.
    13. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      01-24-2012 02:21 PM #13
      Sorry - I'm not using a fuse tap, I'm using the Add-a-circuit.
      It states on the back of the box for it that you cannot exceed 10 AMPS. I was going to place it into the fuse for the 12V, though it's more than 10 AMPS. I even called the radar detector manufacturer and they said not to exceed 10.
    14. 01-24-2012 06:31 PM #14
      I have found that fuse #6 (first 10amp)...is for the interior map / dome lights.
    15. Member Jettadude1's Avatar
      Oct 21st, 2011
      Hawaii
      01-24-2012 08:39 PM #15
      Quote Originally Posted by SanJoseJetta View Post
      Yes, that is 100% correct though those still have power after the car is turned off, right? If that is the case then unfortunately it won't work. I need a fuse that cuts power once the car is off.
      I'm thinking about trying the fuse for the right steering toggle switch (i.e. - the switch that controls the wipers). It's 10 AMP and it cuts power when the car is off.
    16. n00b
      Jan 24th, 2012
      DFW Area, Texas
      01-26-2012 02:38 PM #16
      If you are using an add-a-circuit, you are putting a 10A fuse on for the detector anyway - i'd still suggest using the 12V socket circuit. If something goes awry with your detector in your scenario, it draws 10A there's no guarantee which of your 10A fuses it will pop. In mine, the 10A pops and the 20A and your 12V sockets are still runnning. Just sayin'.
    17. Member
      Jul 6th, 2011
      Irvington, NY
      2011 VW Jetta
      01-31-2012 12:15 AM #17
      Anyone have a fuse diagram for a JETTA SE not a tdi?
    18. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      2007 Passat Wolfsburg (Sold) - 2011 Jetta SE (Sold) - 2014 Tiguan SEL (Current)
      01-31-2012 01:45 AM #18
      It's the same.
    19. Member asusc's Avatar
      Oct 22nd, 2004
      Phoenix, AZ
      2015 GTI
      01-31-2012 02:05 AM #19
      Quote Originally Posted by jettsy View Post
      It's the same.
      LOL
      Matt / 2015 Pure GTI / AWE / APR
      Hit me up if you need a VAGCOM in Phoenix.
    20. 09-16-2012 08:40 PM #20
      Hi need help in Scottsdale abs light and brake light stays on
      interested
      Frank
    21. Junior Member
      Aug 23rd, 2012
      Utah
      2012 CW GLI ATB
      10-05-2012 01:35 AM #21
      Sorry to bump this, but I cannot seem to locate the fuses for passenger side low beam!!
      2012 VW GLI - GIAC Stage 1 ECU - GIAC Stage 2 DSG - Carbonio Intake - All things LED
    22. 10-05-2012 03:59 AM #22
      just tap into the radio fuse. I hard wired my radar into there and have had zero issues been about 8 months too
    23. Member
      Oct 25th, 2011
      Seymour, CT
      2011 Jetta S
      10-05-2012 10:15 AM #23
      Complete fuse diagrams in the, "everyone need to look at this" thread
    24. 05-14-2013 12:40 PM #24
      The fuse for my cigarette lighter blew and I cannot determine which fuse it is! I can't find a fuse diagram anywhere either. Please help!
      2012 Volkswagen Jetta 2.5 Sportline
    25. n00b
      Jul 3rd, 2013
      2012 Jetta TDI w/nav
      07-03-2013 02:43 PM #25
      Quote Originally Posted by Verebs1 View Post
      Which is found........?
