STICKY-FIED!!!!![]()
#36
New guys: READ THIS FIRST. | 8V Society: #369 | VW / Audi & BMW Indy Technician (PM for VCDS / GT1 Coding) | I know Jett Daley.
#37
2012 MKVI Jetta GLI / 2008 Civic Si Sedan / 2007 Mazdaspeed 6 / 2004 MKIV Jetta GLI (1.8T) / 1996 MKIII Jetta GLX VR6
https://twitter.com/Flyin18T
#38
#39
Their is a beep if the temp drops below 4 degrees, VW and many other car makers do this to warn the driver of potential black ice conditions.
If you or the dealership turn on the snow tires setting in the MFD , there will also be another beep if you exceed the speed set (which you can change)
#40
Do you guys do this ?
Does it really make a difference ?
On a side note, I noticed that the design of the hood prevents the driver's side wiper from being lift up completely. wtf.
#41
What's the weight of a 17 inch OEM Joda wheel which comes with the Jetta?
This wheel is also known as "Queensland" outside of the US.
I can't find OEM wheel weights for the MK6 Jetta anywhere.
#42
#43
#44
How do you jack up the rear of the car, and put it on jackstands, without damaging anything?
#45
You wipers need to be put into Service Mode in order to remove the wiper blades, well they don't NEED to be, but to get to service mode, turn off the car and tap the wiper stalk down once before you pull out the key. The wipers will make half a sweep and stop. This will allow you to move the wiper arm without hitting the hood.
#47
if you look closely at the rocker panel there is a dimple in each corner where you should jack up the car. make sure you put the jack on the pinch weld not on the rocker panel itself. the pinch weld will be thicker at this spot. put the jack stands under the rear axle.
#48
#49
#50
#51
#52
#53
#54
Fuelly info:
http://mefi.us/images/fuelly/sig-us/84732.png
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
#55
#56
#57
Any way to disable the temperature warning? It is so irritating to hear it beep just because it went from 40 degrees to 39. It wouldn't be so bad if it would return to the desired display info I had it on once it is done chiming. I have been meaning to check my manual but always forget once I get home from work. Probably a vcds change huh?
#58
What's the reason for the gas cap tether? Is that part supposed
to be anchored into the car, and it's just popping out
and sticking to gas cap? Do I need to go to
the dealer?
#59
Fog lights - How do I turn them on?
My switch has 3 positions, on, off and Lights with squiggly lines on it - I think it is the fogs. But my switch will only go in two positions. On & off, it will not budge into the fog position....
#60
#61
Matt / 2012 Candy GLI / AWE / APR
official mk6 Jetta/GLI DIY guide
Hit me up if you need a VAGCOM in Phoenix.
#62
That was the first question where I was hoping someone would have let him sweat it out a little just for kicks. It's just like when I couldn't figure out how to close the sunroof from the tilt position. I tried everything from twisting and turning and pushing but nothing would do it. I wanted someone to slap me when I was told you have to pull it in the opposite direction of how you push it. Was so bad on my part it was funny.
Sent from my HTC_Amaze_4G using Tapatalk
#63
cant find it in my manual.
#64
#66
#68
I lost one of my key fobs the other day? What is the process I should go through? I am unsure of where it is and am afraid someone may find it and be able to access my car.
A. Is there a way to disable the key fob from the dealership by telling them the serial number?
B. Do I need to get a new set of keys with a different frequency?
C. Something else?
#69
#70
