VWVortex.com - The Official Mk.VI Jetta "Ask a Stupid Question" Thread
    Page 5 of 256 FirstFirst 1234567891555105 ... LastLast
    Results 101 to 125 of 6392
    Thread: The Official Mk.VI Jetta "Ask a Stupid Question" Thread
    1. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      2007 Passat Wolfsburg (Sold) - 2011 Jetta SE (Sold) - 2014 Tiguan SEL (Current)
      01-20-2012 10:34 PM #101
      Quote Originally Posted by CWVWJ View Post
      OK, here is my stupid question... I want to add the chrome accent strip to the lower grille without replacing it. I've seen a couple people doing this and I wanted to know what millimeter chrome strip I need?
      can someone answer this please?
    2. 01-21-2012 11:06 AM #102
      Does the SE have ESP, or any kind of stability
      program. I'm thinking no, because of the rear drums brakes.
      Please let me know if I'm wrong. It's snowing out and I'm really missing
      my Quattro that I had since 2003.
    3. Junior Member
      Aug 9th, 2011
      Charlotte, North Carolina
      2011 MK6 Jetta
      01-21-2012 12:25 PM #103
      Very stupid, how do you change the headlight bulb?
    4. Semi-n00b DINAN E93's Avatar
      Jan 16th, 2012
      NC
      2011 Jetta TDI Sedan 6MT
      01-21-2012 05:30 PM #104
      Quote Originally Posted by simonrjones View Post
      Silver is safer, plus you'll have less chance of buyers remorse after the fact. Gold at first was striking, but i fear it could get old fast. gun metal?..IMO..why bother?
      +1 for silver
      Garage List:
      2011 Jetta Sedan TDi 6MT
      2013 Touareg TDi Exe
      2007 Toyota Tacoma 6MT
      2013 BMW M3 Convertible 6MT
    5. Member Apk_Joe's Avatar
      May 14th, 2009
      Melbourne, FL
      2012 VW Jetta 2.5 SE
      01-21-2012 05:57 PM #105
      this really isn't stupid but I know it can be answered here...I need to buy some wiper blades I've tried the two that wal-mart' applicator said would work on the 2011 VW Jetta SE 2.5L it was the michelin and the rain-x latitude, neither one of the PTB applicators will fit on the new arm they are made for the mk5 arm. So who has ever replaced their wiper blades with non OE wiper blades please tell me what you used.
      Oct 14th, 2011
      Inver Grove Heights MN
      2012 Passat TDI
      01-21-2012 06:40 PM #106
      Quote Originally Posted by JohnIBarr01 View Post
      DPF delete FTW.
      Quote Originally Posted by gruven_diesel View Post
      soot (black smoke you see on old diesel) gets trapped into the particulate filter right after the turbo. as more soot gets trapped into the filter it becomes filled (clogged) there are two pressure differential sensors on before and one after the DPF to determine exactly how full it is.
      so in order to empty the filter, the vehicle goes into a regen mode which is done at highway speeds. on this engine i believe a late fuel injection cycle is fired into the combustion chamber to super heat the dpf and burn off all soot inside. and it gets really really ****ing hot!
      so thats why all new diesel exhaust tips with a dpf system are clean! no carbon, no soot.
      also these engines are meant to be driven not over idled or city driving. they need a good highway blast to clean the filter out. if not than they will eventually clog the dpf and thats big money to replace.
      The regen cycle doesn't just work at highway speeds it can be done at an idle too mind you.
      when my warranty expires so does the dpf lol
      ditto
      Quote Originally Posted by Apk_Joe View Post
      lolrg by Mk4_Joe, on Flickr
      don't like?
      Ugliest Effin VW I have ever seen.
      Quote Originally Posted by jettsy View Post
      Do you not know how ridiculously easy it is to remove that lower piece? Total time to replace is about a min.
    7. Member Apk_Joe's Avatar
      May 14th, 2009
      Melbourne, FL
      01-21-2012 07:04 PM #107
      ok what about this one..
      Oct 14th, 2011
      2012 Passat TDI
      01-21-2012 07:07 PM #108
      Much better but something needs to be down to the lower grille. Looks very bland for a GTI/GLI look
    9. Semi-n00b DINAN E93's Avatar
      Jan 16th, 2012
      NC
      01-21-2012 09:11 PM #109
      My turn:
      Recently bought my '11 Jetta TDi and I am seriously considering a HID projector swap. Before you reply with the "search" responses...I have searched across TDi Forum, VWVortex, VWOC, YouTube, Google, etc...and have found conflicting information on the subject...
      Is there a detailed step by step write-up on how to pull the grille and headlight housings off the car?
      Garage List:
      Oct 14th, 2011
      2012 Passat TDI
      01-21-2012 10:02 PM #110
      Quote Originally Posted by DINAN E93 View Post
      My turn:
      Not that I know of but the front bumper needs to come off before the headlights can be taken out and are held in by 8+ screws, the front grille is super easy to take off.
    11. Member Apk_Joe's Avatar
      May 14th, 2009
      Melbourne, FL
      01-21-2012 10:07 PM #111
      My turn:
      there should be somewhere. I know theres about 10 bolts or screws you have to take off under the hood, then theres a couple of screws in the wheel well holding the front bumper those come off then you have 2-4 more bolts to take off when you remove the front bumper then the whole headlight assembly unplug and ready to do whatever...what I have heard tho if you are doing yourself its not like the old days where they just simply come apart..I wish someone would just start mass producing out of their garage...
      Think about it you buy the actual headlight online somewhere OEM replacement $564.64
      then you get the complete HID parts from TRS - $335
      so that total comes out to $900.00
      then charge for labor and knowledge
      sell retrofit HID on ebay for $1,200
      if you send out your headlights then could be somewhere like $600
    12. Junior Member CWVWJ's Avatar
      Sep 7th, 2011
      OH
      2011 VW Jetta SE
      01-21-2012 10:10 PM #112
      Quote Originally Posted by Fussgus View Post
      I know its easy, I just don't want to spend $100+ for some chrome when I know there are other options.
      2011 CW Jetta SE w/ Conv. & Sunroof. OEM lip spoiler. ECS Fog Light Kit/Euro switch. ST Coilovers. VMR v701 Gunmetal, 225/40/18.
    13. Semi-n00b DINAN E93's Avatar
      Jan 16th, 2012
      NC
      01-21-2012 10:32 PM #113
      Thanks for the reply - my follow-up question/comment:
      I have seen several threads where the grille is off without the bumper being removed. I really prefer to not remove the bumper just to pull the headlight assembly. I know of the 4 torque bolts on top of the grille and the remaining bolts on the headlight assembly, just need to know if the grille comes out without bumper removal?
      As for the costs - i'll be buying the light assembly after it has been done, i.e. The Retro-fit Source, so it will be a swap out of the OEM lights.
      Garage List:
    14. Member Apk_Joe's Avatar
      May 14th, 2009
      Melbourne, FL
      01-21-2012 10:35 PM #114
      I don't know maybe there is all i know is when I was installing all my LED up front in the headlights I just took the whole assembly out to make it easier and I remember taking off the bumper I just wish I had a lift...I did it all while it was on the floor..
    15. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      01-21-2012 11:09 PM #115
      I didnt ask how to take the lower piece out. I asked for MM of chrome stripping...
    16. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      01-22-2012 12:01 AM #116
      You dont have to remove the bumper, but it makes things easier and ensures that it lines up better and installs easier. Idk why people are always willing to take shortcuts and not willing to do it comprehensively.
      Do it right or dont do it at all, especially considering you intend to spend hundreds on a retrofit.
      •|Sent via Tapatalk Android. Likely pooping or stuck in traffic.|•
    17. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      01-22-2012 12:03 AM #117
      Regardless, I am swapping a ballast and have removed both the grille and entire front bumper before. I will make a video for you all tomorrow.
    18. Semi-n00b DINAN E93's Avatar
      Jan 16th, 2012
      NC
      01-22-2012 02:35 AM #118
      Quote Originally Posted by SimpleStaple View Post
      Thanks for your input - FTR, I am not looking for any shortcuts, I simply ask the question as I cannot find a consistent response and just want to make sure I am not removing any part that is unnecessary. I too firmly believe in the "do it right" motto...or as we here in the hills say, "measure twice, cut once".
      Garage List:
    19. Member
      Oct 14th, 2011
      2012 Passat TDI
      01-22-2012 10:03 AM #119
      I was stating how it would be quicker to remover it and replace it with a different one genius. :face palm: I'd rather do that than adding some shatty chrome crap you would come up with...
    20. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      01-22-2012 01:35 PM #120
      Again not the answer to my question. I didn't ask for an alternate method, I asked for mm of chrome trim...dozens of people of people have used this method and it looks great. If you aren't going to answer the question its best not to reply. It's a stupid question thread, not a stupid answer thread. Thanks for your help anyways and still looking for an answer to this.
    21. Member dh71704's Avatar
      Nov 2nd, 2011
      Illinois
      A Mexican made German car and an American made Japanese van
      01-22-2012 01:48 PM #121
      Call me stupid but what to all the acroymns that everyone posts stand for? I am to lazy to go thru a bunch of threads to find some examples, so if you could just respond with some and what they mean thanks.
    22. Member zack718's Avatar
      Apr 2nd, 2011
      New York
      Mk6 Passat, Mk1 Jetta Coupe
      01-22-2012 02:53 PM #122
      Is it just me or does the jetta s not have a low windsheild washer fluid symbol? Had nothing on my dash this mourning went to check my fluid and it was bone dry.
      Bigman Vinyls - Contact for custom vinyl and decal work !
      Instagram: @Zack_Yoo @Bigman_Vinyls
    23. Junior Member
      Dec 17th, 2011
      ATL
      2012 Jetta TDI Premium w/ Nav & Appearance
      01-22-2012 08:16 PM #123
      Has anyone been able to get the heated drivers seat memory to work in VCDS? What about teardrop wipe? If so what version of VCDS did you use?
    24. Junior Member
      Nov 13th, 2011
      India
      VW Jetta MKVI, TDI H'line DSG
      01-22-2012 11:12 PM #124
      Quote Originally Posted by dh71704 View Post
      FTR = For The Record
      FTW = For The Win
      RTFM = Read the e'Ffing Manual
      IDK - I Don't Know
      AFAIK = As Far As I Know
      IIRC = If I Remember Correctly
      IMHO = In My Humble(? ) Opinion
      Those are all I can think of.
    25. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      01-23-2012 06:42 PM #125
      FACT: Front bumper does not need to be removed to remove the headlights. You will, however, need to remove the screws in the wheel wells in order to pull/pry the bumper forward to get them out successfully.
      I have both removed the bumper and headlights and also done the aforementioned method as well.
      I have to swap a HID ballast out some time this week so I will concoct a video on my GoPro for you all... just be patient! I've been busy with classes and what not.
