Page 17 of 83 FirstFirst ... 7 13 14 15 16 17 18 19 20 21 27 67 ... LastLast
Results 561 to 595 of 2899
Thread: The Official Mk.VI Jetta "Ask a Stupid Question" Thread
  1. Semi-n00b
    Apr 17th, 2012
    Milwaukee,WI.
    2012 Jetta SE WITH CONVENIENCE
    06-02-2012 06:31 PM #561
    Quote Originally Posted by BHump View Post
    Ive been using meguiars ultimate black protectant cream.
    That rubber trim drives me nuts. Keep it as dry as possible when washing, probably keep a towel nearby.
    Thanks for answering.
  2. 06-02-2012 06:32 PM #562
    Are the rear brakes on the 2012 TDI drum brakes or disc brakes? Just a curious bystander that apparently sucks at using search engines.
  3. Member SLeePeR_GTi's Avatar
    Jul 13th, 2004
    Vancouver BC Canada
    2012 GLI 6speed BASE
    06-02-2012 06:35 PM #563
    Jetta's started recieving disc brakes on the rear somewhere towards the end of the 2012 MY. Ive been at a dealership and seen both on the same cars with the same options.
    2013 = Disc rear on higher trim cars.
    2012 Tornado RedGLI 6speed BASE
    Miro 111
    ST's.
  4. 06-03-2012 10:44 AM #564
    Quote Originally Posted by SLeePeR_GTi View Post
    Thanks for your help man.
  5. Member BHump's Avatar
    May 18th, 2012
    wichita falls TX
    '92 Caprice Classic white, '12 Jetta GLI M/T PGM
    06-03-2012 09:47 PM #565
    I complained about the dealer installing the plates with big screws on the online survey. These screws actually went into the paint and pushed the bracket outward and tore up the bracket's screw holes .
    Will VWoA help me at all? maybe send me a new bracket and appropiate sized screws?
    Nov 2nd, 2011
    Washington, Illinois
    Black '12 Jetta SE Convience w/sunroof
    06-04-2012 09:53 AM #566
    I complained about some pdi scratches on my survey and after a phone call from vwoa asking me about my experience with the dealer they sent me a check for a hundered dollars.
  7. Member BHump's Avatar
    May 18th, 2012
    wichita falls TX
    06-04-2012 06:11 PM #567
    Quote Originally Posted by dh71704 View Post
    interesting....
  8. Junior Member DasJunk's Avatar
    Mar 5th, 2012
    Providence, RI
    MkVI Jetta SE
    06-06-2012 05:28 PM #568
    Does anyone know where I can buy OEM emblems and badges? I'm considering trading my SE in for a GLI and I don't want to show up with it having painted emblems and a broken E in the jetta portion of the badges. I haven't seem anywhere that actually has OEM so they give this warning that it "might not fit by like 2-4mm" and I don't want that garbage. Any idea apart from VW, let me know. Thanks.
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    06-06-2012 05:39 PM #569
    Quote Originally Posted by DasJunk View Post
    what did you paint them with?
  10. Junior Member DasJunk's Avatar
    Mar 5th, 2012
    Providence, RI
    MkVI Jetta SE
    06-06-2012 06:03 PM #570
    Spray paint. don't remember the brand right this second. i sanded the font chrome before I painted it and the black plastic behind it. for the rear I sanded the texture off the back plastic piece. I wish I waited till i found plastidip for the front but i got antsy. I had no intention of looking at a gli but i found a deal and I'm tired of drooling.
  11. Junior Member
    Sep 6th, 2011
    Chicago
    2012 VW GLI
    06-07-2012 11:20 AM #571
    How do people on this forum get that information on the bottom of their entry. That information that is specific to them. People put catch phrases, their make and model, and other random info/quotes there. It's in the account/profile settings? but where exactly?
  12. Junior Member
    Oct 19th, 2009
    La Crosse, WI/ Des Moines, IA
    2012 Jetta GLI Frost Silver Metallic
    06-07-2012 11:22 AM #572
    why are there a ton of badgeless grills for mk6 Golfs, GTIs, and Rs, but no one makes one for GLIs?
  13. Member
    Feb 21st, 2012
    Ypsilanti, Michigan
    2010 Jetta TDI DSG
    06-07-2012 11:50 AM #573
    Quote Originally Posted by JorgePerez
    Go to My Settings and click Edit Profile. On the left side click Edit Signature.
  14. Junior Member
    Sep 6th, 2011
    Chicago
    2012 VW GLI
    06-07-2012 12:01 PM #574
    Quote Originally Posted by cd_booth View Post
    Thank you sir.
  15. Member
    Oct 25th, 2011
    2011 Jetta S
    06-07-2012 12:43 PM #575
    Quote Originally Posted by Alex_715 View Post
    Because they all use the same style grill that has been used since 2003 in some cases while the GLI grill is since 2010
  16. Junior Member ehg's Avatar
    Dec 23rd, 2011
    Los Angeles
    2012 Volkswagen Jetta GLI
    06-13-2012 05:27 PM #576
    I've searched, but couldn't find what i was looking for... I know there was a thread about this a little while back but I can't find it... Anyway:
    I have a GLI with the RCD-510 in it. I had heard about an update for it, that would allow for the BT audio to show information and be able to control the bluetooth connected device. Is this an update that I could get? My VW dealership is full of idiots, so if i asked them I wouldn't get an answer.
  17. Junior Member feuerwehr's Avatar
    Dec 30th, 2009
    South Carolina
    06-20-2012 09:13 PM #577
    Here are a few stupid questions...serious, but still stupid
    1. How long do coilovers and springs last?...Under normal conditions, on a relatively smooth road?... i went over 100k mi on a 2002 frontier with stock shocks, and my o7 Passat still has factory shocks after 100k mi
    2. Is using lowering springs with oem shocks not recommended? or will the wear and tear increase?
    '07 Passat Wagon 2.0T Candy White
    '11 Jetta SE 2.5 Tempest Blue
  18. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    06-20-2012 10:42 PM #578
    Quote Originally Posted by ehg View Post
    That update is likely not possible. It's more of a hardware update and not software
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
  19. n00b
    May 21st, 2012
    Michigan
    2011 Jetta SE
    06-21-2012 02:29 PM #579
    Better not crack up your Jetta with State Farm as your carrier. If you do be ready for the cheapest possible repair utilizing the cheapest aftermarket and used parts possible.
  20. Member
    May 19th, 2012
    North Carolina
    2008 BMW 335i coupe & 2012 VW Jetta SE
    06-21-2012 03:40 PM #580
    Quote Originally Posted by feuerwehr View Post
    Very curious about this myself.
    2008 BMW 335i 6MT coupe - Montego Blue Metallic | ///M-Sport package | 19" BBS RS-GT
    2012 VW Jetta SE - Reflex Silver Metallic | bike rack, tint, powdered Detroits, '13 Hybrid/GLI rep headlights
  21. Junior Member NJA Pilot's Avatar
    Apr 27th, 2012
    S. FL
    2012 GLI DSG Autobahn
    06-21-2012 09:38 PM #581
    this is my serious stupid question:
    If I de-badged the "GLI" badge, can I use the same badge later if I change my mind? If so, what should I use for adhesive?
  22. Member
    May 19th, 2012
    North Carolina
    06-21-2012 09:59 PM #582
    Quote Originally Posted by NJA Pilot View Post
    It'd be easier to get a new badge.
  23. Junior Member BenzoSyndrome's Avatar
    Jun 14th, 2012
    Texas
    2012 VW Jetta SE
    06-21-2012 10:12 PM #583
    I have a 2012 jetta se 2.5L, divi have front and rear disc brakes?
  24. Member NotLowEnough's Avatar
    Mar 23rd, 2011
    Blount County, TN and Chatham County, NC
    Mk.6. Mondeo Hybrid. E46 ZHP. Jeep 4x4.
    06-21-2012 10:35 PM #584
    Quote Originally Posted by BenzoSyndrome View Post
    Possibly. Go look. That's the only way you'll know.
    New guys: READ THIS FIRST. | 8V Society: #369 | VW / Audi & BMW Indy Technician (PM for VCDS / GT1 Coding) | Help find Grant's pictures.
    Quote Originally Posted by DownhillA4 (re: SoWo 2013) View Post
    Props to HelenPD and all the enthusiasts who didn't do burn-outs, litter, and rev their little 4 bangers.
    GirlsLoveIt.
  25. Member 15inches's Avatar
    Mar 21st, 2010
    Fort Polk, LA / Dallas, TX
    '96 B4 1Z TDI sedan, '12 Jetta TDI 6spd manual
    06-22-2012 08:33 AM #585
    What are the specs for the stock Turbo on the TDIs? Anyone? Thanks
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  26. Member LoDub1.8T's Avatar
    Jan 18th, 2008
    Nashville, TN.
    2L 16v mk1 scirocco, on digi
    06-22-2012 09:22 AM #586
    Ok so here is my stupid ? for the mk6 fitment gurus.
    I am a old school water cooled guy an my knowledge of wheel fitment for those models are strong, HOWEVER we picked up a mk6 TDi jetta in toffee brown metallic for the Mrs. She has decided she wants 19x8.5 / 19x9.5 BLQ's for her jetta. I know they offer a few different offsets in both sizes.
    What are recommendations for offsets for a mk6 in those widths? There will be slight stretch for tires an she is a fan of flush or barely poked.
    Thanks for your help in advance!
  27. Junior Member BenzoSyndrome's Avatar
    Jun 14th, 2012
    Texas
    2012 VW Jetta SE
    06-23-2012 11:15 PM #587
    Thanks man, good idea. I have steel wheels and hub caps, so it will kind of be a pain.
  28. Member SinlessVillainy's Avatar
    Apr 24th, 2011
    Dragging around Texas
    2011 Jetta TDI
    06-23-2012 11:34 PM #588
    Quote Originally Posted by LoDub1.8T View Post
    19x8.5 ET35 is as flush as you can get...
  29. Member LoDub1.8T's Avatar
    Jan 18th, 2008
    Nashville, TN.
    06-25-2012 08:51 AM #589
    Quote Originally Posted by SinlessVillainy View Post
    Is that a square set up? 19x8.5 et 35 all four corner? What tires you running?
  30. Junior Member rob6188's Avatar
    Jun 25th, 2012
    MD-VA-DC Metro
    2012 Jetta TDI Black, RIP 98 Beetle
    06-25-2012 10:26 AM #590
    What does the little arrow to the right of the fuel icon below the fuel gauge mean? If anyhting?
  31. Member SinlessVillainy's Avatar
    Apr 24th, 2011
    2011 Jetta TDI
    06-25-2012 10:38 AM #591
    Yes, all 4 corners, no camber. 215/35 Falken 452 tires. Gives just enough stretch to pull it off. Fronts tuck fully.
  32. Junior Member amg12gli's Avatar
    Jun 24th, 2012
    Columbus, OH
    2012 cw gli
    06-25-2012 10:46 AM #592
    fuel door on right side of car. . . .as a reminder when fillin up!
    Quote Originally Posted by rob6188 View Post
  33. Member
    Apr 12th, 2012
    Orlando, Fl
    2009 Jetta 2.5 SE, 2012 GLI
    06-25-2012 12:58 PM #593
    I feel like this is a stupid question so ill ask it here. Will putting lowering springs on my car affect the ride quality? And whats the better option to lower with, coilovers or just springs?
  34. Junior Member rob6188's Avatar
    Jun 25th, 2012
    MD-VA-DC Metro
    06-25-2012 08:12 PM #594
    Quote Originally Posted by amg12gli View Post
    Thanks for fillin me in!
  35. Member
    Feb 3rd, 2011
    Chesapeake, VA
    '12 GLI Platinum Gray
    06-25-2012 09:15 PM #595
    for GLI owners, can you actually hear your turbo? I've had mine for almost two months, driven almost 3,000 miles and I swear today was the first time I could actually hear the turbo and the diverter functioning. The music was pretty low, AC was on, cruising at 65ish in 6th. If I gave it some gas, I could hear the pressure build and then the woosh of the diverter/BOV releasing pressure. When I got home, I actually looked to see if something had become disconnected or loose, but all looks good.
    '12 Jetta GLI Platinum Gray
