Results 1 to 15 of 15
Thread: Is there MK2 coilovers without a fixed perch?
    Dec 16th, 2011
    Middletown, NJ
    '87 GTI 8v 95' Suburban
    01-12-2012 06:30 PM #1
    I could have the wrong idea of how most coilovers work, I was looking at the KW Variant 1s and I don't want to adjust the height of the car using the springs. I'd like to use the springs for dampening and adjust the perch for height. Thank you
    Dec 16th, 2011
    Middletown, NJ
    01-12-2012 06:38 PM #2
    *are there
    Dec 16th, 2011
    Middletown, NJ
    01-13-2012 02:12 AM #3
    Bumparoonie
  4. Member cool white98's Avatar
    Apr 23rd, 2005
    baltimore
    98 jetta aba-t/89 gti/92 yota pickup
    01-14-2012 08:42 PM #4
    b&g or k sport
    BeMoreEuro - Northeast Baltimore European Car Enthusiasts
    GTG's every first and third Tuesday in Parkville at Racers Cafe
    ---------http://autos.groups.yahoo.com/group/BeMoreEuro/---------
    ****http://forums.vwvortex.com/showthrea...e-Tuesday-GTG!****
    Dec 16th, 2011
    Middletown, NJ
    01-15-2012 01:03 PM #5
    It doesn't really matter the company, I was looking at Koni and KW and they both have fixed perches. I just dont get how you could lengthen the spring travel when lowering the car, it doesn't sound like a good system
  6. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
    01-15-2012 02:21 PM #6
    The primary purpose is corner balancing not lowering.
    Dec 16th, 2011
    Middletown, NJ
    01-15-2012 08:39 PM #7
    But when you lower these cars, doesn't the suspension get looser? I want it to corner better, sure, but not ride the same height, but if I lower it, the springs will travel longer make them loose and having the car bounce more.
  8. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    01-16-2012 12:59 PM #8
    Read the FAQ's at the top of this forum; although based on the MkIV the principals still apply. Lowering ruins suspension geometry and makes the car handle worse.
    If you use quality parts and stay in the manufacturers recommended adjustment range the ride should not be significantly affected.
    Dec 16th, 2011
    Middletown, NJ
    01-16-2012 02:28 PM #9
    Thank you, I'll read along
  10. Member
    Dec 16th, 2011
    Middletown, NJ
    01-16-2012 11:10 PM #10
    So what exactly do coilovers do? Just stiffen your suspension? Isn't lowering beneficial to lowering your center of gravity?
  11. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    01-17-2012 11:48 AM #11
    They only stiffen the suspension if they use higher than stock spring rates.
    They allow adjusting the suspension for setting the corner weights.
    Yes, lowering drops the center of gravity, but it also changes the roll center, camber curve, and other aspects of the suspension geometry in ways the cause more harm than good.
  12. Member littlebill86's Avatar
    Apr 13th, 2008
    lancaster, ca
    85 GTI
    01-17-2012 03:18 PM #12
    fortune auto
  13. Member
    Dec 16th, 2011
    Middletown, NJ
    01-19-2012 10:59 AM #13
    Quote Originally Posted by littlebill86 View Post
    fortune auto
    It says that all coilovers from them aren't for use on street, but then says that you have a choice of different valving for different applications including street.
  14. 02-21-2012 07:53 PM #14
    Hey try tein
  15. Member
    Dec 16th, 2011
    Middletown, NJ
    02-24-2012 04:26 AM #15
    Quote Originally Posted by 16v Drakes View Post
    Hey try tein
    They dont carry MK2 coilovers
    My girlfriend and I may have broken up after three years, but then again, I have the MK2<3
