VWVortex.com - Turn signals not working.
    Results 1 to 20 of 20
    Thread: Turn signals not working.
      Oct 23rd, 2009
      Virginia Beach, VA / Williamsport, PA
      84 Jetta GLI
      01-13-2012 06:06 PM #1
      Switch seems to work fine, the light glows steady green. No ticking sound.
      I tore apart the tails, used lots of contact cleaner and all brand new bulbs. I even went as far as to replace all spade terminals. The parking and brake lights work fine; no reverse lights, but that's another issue.
      Would the relay cause this? I figured that'd just handle the flashing.
    2. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Almost the Arctic, Alberta, Canada
      Because MK1
      01-13-2012 06:08 PM #2
      I think this is leading back to another ground issue.. The turn signal system also grounds to the fusebox.. Hmm, I would also check your hazard switch, the 4 way switch in the dash. The turn signal power runs through it.
      Oct 23rd, 2009
      84 Jetta GLI
      01-13-2012 06:17 PM #3
      Yeah, no hazards either. The switch doesn't even light up, but I wasn't sure if the relay could cause that too.
      I don't think it's a ground, my charging issue is resolved now.
    4. Member 8v-of-fury's Avatar
      Jul 14th, 2008
      Because MK1
      01-13-2012 06:19 PM #4
      Quote Originally Posted by Schpamb View Post
      check that switch, I dont think it can be tested.. may have to just swap it out.
      Your charging woes were fixed, but i still don't like that fact that there is no other ground wire on your battery negative than the one coming from the engine mount.
      If it is all relying on finding some small source of ground here or there instead of having a designated ground to the battery things wont function properly.
      You need to find if the fuse box ground is making its way back to the battery.
      Oct 23rd, 2009
      84 Jetta GLI
      01-13-2012 06:23 PM #5
      The fuse box ground is attached to the bar under the dash, I noticed it earlier. I could run one from there to the battery.
      I guess I'll hunt down a switch.
    6. Member
      Jun 28th, 2002
      harrisburg pa
      13 vw gli,08 wolfsburg, 84 vw rabbit gti
      01-13-2012 06:29 PM #6
      my brother is having the same issues..... ill be watching this post. good luck! ill post again if we get his figured out
      May 25th, 2007
      Central Calif
      1981 Caddy
      01-13-2012 06:35 PM #7
      Here's a westy wiring diagram that helped me get mine to work. Notice the error at thelamp connection.
      the Left rear and Left front hould be connected together, and the right rear and right front too.
      Oct 23rd, 2009
      84 Jetta GLI
      01-13-2012 06:46 PM #8
      All wiring is stock and looks solid.
      I will just start with the switch and go from there! If I'm lucky that will just be it.
      Oct 23rd, 2009
      84 Jetta GLI
      01-14-2012 01:31 PM #9
      I bought a hazard switch (Which turns out it's for a Cabby, and doesn't sit inside the dash) and that did nothing.
      Hitting the switch turns the indicator light on, still no flash.
      Next is the relay.. Do the 3 prong relays from Advance and Autozone work? Mine is 4 prong but the only ones they show are 2 or 3.. Such as:
      http://shop.advanceautoparts.com/web...AMPAMS_____BBV
    10. Member VWCaddy's Avatar
      Jun 25th, 2001
      SF Bay Area, CA.
      1982 VW Caddy
      01-14-2012 01:42 PM #10
      I put one of these in my '82 Caddy when the flashers stopped working:
      - http://www.superbrightleds.com/cgi-b...2Fflashers.htm
      Works great and flashers the proper speed with LED bulbs.
      '82 diesel pickup, Missing LinkZ custom shift linkage, Quaiffe transaxle, Bilstein shocks F/R.
    11. Member
      Oct 23rd, 2009
      84 Jetta GLI
      01-14-2012 02:29 PM #11
      I get no turns at all, not even a steady glow. The indicator light on the dash does glow steady green for both directions for turns and when the hazard switch is on. The hazard switch does not light up though. Could a bad relay cause that still?
      Also, how would I go about getting a replacement light for the hazard switch?
      Sep 25th, 2010
      wilmington DE
      1964 corvair spyder, 1975 bmw 2002, 1976 bmw 2002 rally car, 1994 bmw 530it, 2001 C5
      01-14-2012 03:51 PM #12
      when i got my gti, the turn signals would light up but not flash, same with the hazards, i replaced the relay, and they worked perfectly after that.
    13. Member
      Oct 23rd, 2009
      84 Jetta GLI
      01-14-2012 03:56 PM #13
      Mine don't light up at all, though.
    14. Member
      Oct 23rd, 2009
      84 Jetta GLI
      01-14-2012 04:37 PM #14
      The bulbs I used were 1156LL for all the rear sockets, minus the running lights. Those I left alone since they work fine. These are the bulbs they told me to get on Advance's website. The front bumper lights glow fine when the headlights are turned on.. Aren't those supposed to work as blinkers also?
    15. Member
      Oct 23rd, 2009
      84 Jetta GLI
      01-14-2012 06:29 PM #15
      Could anyone give me a quick rundown of the relays and locations they go in on a 79? I can't find anything about it in my Haynes.
      I want to make sure they're all there and in the right places, it looks like someone was in there before.
    16. Member
      May 25th, 2007
      Central Calif
      1981 Caddy
      01-14-2012 06:50 PM #16
      Try this.
      OOps! upside down!
    17. Member
      Oct 23rd, 2009
      84 Jetta GLI
      01-15-2012 06:10 PM #17
      Thanks guys!
      I replaced the relay and they now work fine!
    18. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      D-Town REPRESENT : Texas
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      01-15-2012 06:47 PM #18
      Thanks guys!
      yep, thats what i did also
    19. Member
      May 26th, 2010
      South Shore, MA
      81' 1.6d rabbit
      01-15-2012 08:41 PM #19
      im having the same issue. i got the led flashers for some blinkers that i made (motorcycle blinkers) i believe my relay crashed too. im guessing yours will crash again in a while. The fast rate of the blinking is caused because theyre led. and they burn out relays fast. superbright led sells led safe relays
    20. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      01-15-2012 09:33 PM #20
      Quote Originally Posted by karcher View Post
      who has led?
      if you switch to LED you require the LED flasher because the ampere to activate the flashing is super low compared to regular bulb
      the one i was referring to replacing was the factory flasher with stock bulbs
      replacing that with a spare i had fixed my odd flashing problem
      upgrading to LED with LED flasher had nothing to do with my orig problemo
