VWVortex.com - Brake lines distance ?
    Results 1 to 5 of 5
    Thread: Brake lines distance ?
    1. 01-14-2012 08:31 PM #1
      Hi
      Why some brake lines are in spiral from the output of the brake cilinder? is this because of the distance of the brake line ? i think left and rear lines need to be exactly the same distance ,or how does this work talking about fluids?
      When i press the brake pedal and the master cilynder delivery the brake fluid to the rear brakes if the distance its not the same will one side brakes more than the other ?
      Example
      MASTER CILYNDER (PRESS)
      _________________________________ SHORTER LINE
      ______________________________________ LONGER LINE
    2. 01-15-2012 11:10 AM #2
      in theory the hydraulic fluid free of air should compress at the same time since pressure from the master cylinder will be exerted equally. that distance shouldnt really matter.
    3. Member greyhare's Avatar
      Dec 23rd, 2003
      Corvallis, OR
      '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
      01-15-2012 01:41 PM #3
      The spiral is to allow a small amount of flex.
    4. 01-15-2012 03:08 PM #4
      Ok thanks
      REGARDS
    5. Member GTijoejoe's Avatar
      Oct 6th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      01-16-2012 10:47 PM #5
      Quote Originally Posted by greyhare View Post
      This guy is good
      It has also been known to help reduce NVH from a modulator.... if that vehicle even had one..... but what he said ^
      2.0T+034efi+meth = 300+whp = RIP
      FS: 2015 Honda Civic Si
